Question about Bobcat Equipment Skid Steer Flatbed Tractor Trailer
Gauge reads full all the time
The gauge shows full all the time
    Problem Solver:
  • 7 Answers
Sending unit inside tank may be bad or stuck.remove the wire on the top center of sending unit and remove sending unit.make sure it moves free.you can also test it outside the tank by hooking up wires same lacations and move sending unit float up and down slow.
Posted on May 27, 2014
My 2010 Mazda 3 is showing full tank of gas when it's actually almost empty therefore it will not accept more gas.
If you cannot fill the tank because of an erroneous reading then it is time to replace the gas gauge sending unit responsible for the anomaly. Hope fully you can do it from the trunk - otherwise you will have to drop the gas tank to gain access.
Jul 31, 2016 | 2010 Mazda MAZDA3
Gas tank will not fill up on 2001 ford expedition
Gas as in gasoline or gas as in LPG gas? If its petrol, the fuel sender may be out of adjustment. (Usually means a new sender) If its LPG, the fuel stations are set to automatically shut off at 80% full. The gas tank will never actually be full to the brim but the gauge should be showing full if the gas nozzle keeps shutting off. Have a look on the LPG tank itself, they have a little gauge on them which shows how full it is. I have 2 tanks on my car , when "full" or when the pump shuts down, the tank gauges show just under full but the gauge on the cars dash shows full (2005 BA Ford)
Feb 18, 2015 | Ford Expedition Cars & Trucks
The fuel gauge on my 01 caravan 2.4l reads full when running, and only reads 1/4 when off, any ideas what it could be?
Many cars do this to discourage gas theft. If the car fuel gauge only shows 1/4 full, a potential thief may not bother to steal 2 or 3 gallons of gas. This is very normal.
If the gauge is stuck on full and you are sure the tank isn't full, you have a sensor sending wrong information to the dash gauge. Most cars now have a single fuel pump and sending unit that can be replaced by a mechanic.
Jan 09, 2015 | 2001 Dodge Caravan
I have Nissan patrol super safari mod.2005, problem with fuel gauge main tank showing maximum spare tank minimum please help
if you have 2 fuel gauges working of a tank switch there may be some resistance in the circuit of the second circuit that increases the reading of the gauge. Personally I have the tanks balanced out with a levelling hose between them the the gauge reads the capacity left in the tanks IE full-- both tanks-- full, 1/2 both tanks 1/2 With the way you have it set up then if one gauge is faulty and shows full when it is empty you can find yourself in a spot of bother when you need the other tank
Nov 18, 2014 | 2005 Nissan Patrol
Why does my ford 1998 mustang read full all the time?
Definitely a issue with the gauge, or the wiring for the gauge. Sounds like a "dead"short. If the gauge is reading over full, that's indicative of a short.
Oct 07, 2014 | 1998 Ford Mustang
Why does the fuel gauge stay on full all the time?
Fuel sender unit could be faulty and showing a full tank all the time. Basically the gauge is a volt meter and the float arm adjusts the voltage going to the fuel gauge when it moves up and down. If it's stuck for some reason it'll show full when it's at the top.
A local garage or auto centre can fix this easily or if you're good with spanners, it's usually located under the rear passenger seat where you can find the access to the top of the tank.
Oct 07, 2014 | Cars & Trucks
Fuel pump wiring diagram
there is two things : fuel gauge and dash fuel gauge. The fuel gauge in tank rated to 0 to 90ohms.disconnect wire at the tank take a variable resistor connect it to wire .read the dash gauge if it move as you move the resistor. if ok fuel tank gauge is at fault
Aug 09, 2013 | 1998 Chevrolet K1500
2006 Dodge Durango - Fuel gauge stuck on full, and won't move? What's wrong?
Either the circuit is shorted to ground, or shorted to power.
The sending unit in the tank provides ground to the gauge.
I would disconnect the harness at the tank and see what the gauge does. You may need a new sending unit.
Jul 30, 2012 | Cars & Trucks
Fuel gauge reads past full all the time
when the tank is full the resistance is low so the power through the gage make is read full
as the tank empties , the resistance increases so the less current means the gauge reads less until empty there is little or no power , the gauge reads empty
simple check , turn the ignition off, no power , no gauge reading
Sep 09, 2017 | Chevrolet S 10 Cars & Trucks
float may be stuck up;Take tank unit out and check it with power on and observe the travel and relative gauge position.
Bobcat Equipment  Skid Steer Flatbed Tractor Trailer Logo
97 people viewed this question
Top Bobcat Welding Tools Experts
Troy
Troy
Level 1 Expert
Lawrence Oravetz
Timllfixit
Are you a Bobcat Welding Tool Expert? Answer questions, earn points and help others
