Question about Craftsman Tools & Hardware - Others
Sander motor Turns on but smokes a lot
Sander doesn't spin
YOUR BALLBEARING where the disk is on mounted is the right bearing that have the problem for shure it is full of dust or completely dry it will not turn anymore SIMPLY TO CONTROL IF YOU MOVE YOUR DISK NOW ON YOUR MACHINE YOUR ARMATURE TURNS DIRECTLY WITH THE DISK thats not good the armature must stand still , replace the ballbearing or remove it and open it with a very little sharp screwdriver on the both sides solvent it out try to turn the bearing carefully until its turns without problems dry it or blow it out with a compressor and if its dry lubricate with ballbearing grease close it again and mount it again
Nov 13, 2013 | Metabo SXE450 00458 6'' Random Orbit...
Craftsman Sander 315.117120 has begun smoking after mere minutes of sanding and sounds much weaker than it once was. Is this definitely a motor burnout issue, the motor is no longer sold by sears for this...
Brush failure usually doesn't produce much smoke--check the motor windings for apparent overheating. Replacement of the machine appears to be the best solution. Good luck!
Sep 11, 2010 | Garden
The sander heats up an smoke comes out of the housing. Can it be fixed?
If it smoked, then it's probably toast. These only cost about 70.00 hard to repair at that price.
Aug 18, 2010 | Black & Decker BR300 3''x18'' Belt Sander
Porter cable sander lost power.
Similar problem with my 7500 2x18" belt sander. Replaced the brushes today (didn;t look bad{ had sander 3 months to sand pistol grips. Sparks were flying from motor so replaced the brushes. Skil runs very slugis like its booging down, I think the only other possible solution is new bearings for me and perhaps you..
Apr 08, 2010 | Porter Cable 505 Factory Reconditioned...
Bosch 3283 dvs sander has unbalanced spin
This means the sander has been droped and the pad support and/or the bearing orbit has been bent, maybe even the motor shaft. Never leave any power tool sitting on a bench, always set it on the floor, it will end up there at some time anyways. You can try replacing a part at a time and spend a lot of money and time, but is it worth it?
Jun 02, 2009 | Tools & Hardware - Others
Electric Bosch hand held orbital sander belt not rotating properly
My guess is that your sander got gunk in the belt and other rotating parts and you are either burning up the belt, or (hopefully not) the motor windings. Rick
Apr 13, 2009 | Air Tools & Compressors
Sander failure when using honda generator
If you are using a 220 volt 4 hp floor sander, which is 95% of all floor sanders. you CANNOT use a generator less than a 25KV, which is about the size of a van. All Floor sanders draw over 80 amps at start up and during floor sanding all sanders run around 25 amps. If your motor is a Capactor style motor you can do detrimental damage to the motor. Many of my customers have done it in the past.
Dec 24, 2008 | National Tools & Hardware - Others
Makita sander polisher 7"
Well as they say "when you let the smoke out you know its broke"
but it my just be the motor itself or the ,,,,brushes witch you can buy your self..prob time to look for that warranty .
Jan 13, 2008 | Makita 7" Electronic Sander - Polisher...
Tools & Hardware - Others Logo
32 people viewed this question
Top Craftsman Tools & Hardware - Others Experts
Dusty Ryan
Level 1 Expert
Mike
John Trevino
Are you a Craftsman Tool and Hardware - Other Expert? Answer questions, earn points and help others
