Question about Gladiator Freezerator Top Freezer Refrigerator
Exactly the same.
I defrosted the entire unit and within one hour of restart, the drip and the ice was already starting to form on the floor of the freezer.
  • 4peters Jun 15, 2009
    No Ice maker and not connected to a water line.
The hose that carries the water from the top coil to the evaporator pan is plugged with ice. You need to leave your unit unplugged for a long time so the ice in the drain hose can melt. If you restart it too soon the problem will not be solved.
Posted on Jun 20, 2009
  • 21 Answers
Check the ice maker tray.see if it is over filling,and running into the freezer floor.See if it is a continual overflow or just when the ice maker runs.If it is continual,sounds like the water valve may be stuck open,maybe a piece of trash in the line.If just when the ice maker operates,there is an adjustment screw for more or less water.This is usually located under front cover of ice maker.The water valve is usually located on bottom of refridgerator,follow water line from wall.Hope this helps. Gregg
Posted on Jun 15, 2009
Ice forms at the bottom of freezer. I have defrosted and cleaned ice, but the drain doesn't drain. Is the drain plugged and if so, how do I clean it?
The evaporator coils frost up in normal use and every eight hours or so the entire unit shuts down and the defrost heater comes on to melt the frost. This cycle last about 20 minutes. The melted frost drips into a drain pan and through a drain tube to the drain tray under the freezer/refrigerator where it's evaporated by the condenser fan.
Your drain tube may be stopped up with ice at the upper end because it drains too slow because it's stopped up at the lower end in the evaporator pan under the unit at the floor. It can get dust and mold in it. Once you get the ice out at the top a little pressure with a turkey baster will usually clear it out. Flushing it out with hot water and clorox may help.
Make sure it drains quick enough to prevent refreezing. . The drain should be located below the evaporator coils on the inside of the freezer at the bottom of the rear cover.
Jun 14, 2011 | Amana 22.6 cu. ft. Side-By-Side...
Ice maker leaks and ice forms in bottom of freezer compartment, water runs out onto floor
Feb 08, 2011 | LG LRFD25850 French Door Refrigerator
Water is dripping from the top into the fridge in the back is frozen up and condensation is forming at the top of the fridge ceiling...dripping down.
Make sure it drains quick enough to prevent refreezing. . The drain should be located below the evaporator coils on the back of the freezer.
Aug 10, 2010 | GE 18.2 Cu. Ft. Frost-Free Top-Mount...
Freezer fan malfunction . coils ice over and fan does not run
Unplug the unit, remove the contents of the Freezer section only and place a fan blowing into the freezer section for 90 mins to 2 hours. Note doing this may result in excessive water on the floor so have a mop and rags standing by to tend to the water. Once the water stops dripping the ice in the freezer coils should have melted. Plug in the unit and wait 20 minutes then check to see if the fan is running. If the fan is running you might be ok. However if in 2 days it freezes up again then the unit is not defrosting and will need further service in the form of trobleshooting the defrost circuit and timer.
Jan 03, 2010 | Refrigerators
Our Kenmore side-by-side leaks at the bottom. Ice forms at the bottom, then leaks on the floor. The freezer side drain doesn't appear to be clogged,though
Your evaporator coils frost up in normal use and every eight hours or so the entire unit shuts down and the defrost heater comes on to melt the frost. This cycle last about 20 minutes. The melted frost drips into a drain pan and through a drain tube to the drain tray under the freezer/refrigerator where it's evaporated by the condenser fan.
Make sure it drains quick enough to prevent refreezing. . The drain should be located below the evaporator coils on the lower back of the freezer
Oct 15, 2009 | Refrigerators
I had a huge block of ice on the bottom of my freezer that I got rid of yesterday. Over night the ice started to form again. What could be wrong? The unit is only about 8 years old and we've already had...
This can be caused by the drain hole below freezer coil being blocked by ice. You MUST remove all ice in drain under freezer coil. Use turkey baster to squirt hot water into hole and use hairdryer to defrost. Possible defrost thermostat is defective. Unit never goes into defrost, ice forms on coil and in floor of freezer. After defrosting may work OK for a week or two but gradually gets warmer because ice is blocking ports where cool air gets to refrig. May also have water in refrig box. Can also be caused by defective defrost timer.
Aug 19, 2009 | Refrigerators
Ice forming on bottom of inside of side by side AMANA refrigerator / freezer and leaking on floor
Make sure it drains quick enough to prevent refreezing. . The drain should be located below the evaporator coils on the lower back of the freezer.
Aug 18, 2009 | Refrigerators
Ice forms on the bottom of the freezer and water leaks on the floor water to the ice maker was turned off and that did not solve the problem.
Assuming that this is a self-defrosting freezer (which almost all are today), the defrosting coil or the timer may be bad. The defrosting coil actually warms up the freezer slightly every X hours. This thaws the ice that starts to form in the freezer. The vapor is then evaporated and exists out through a drip tube to the bottom of the freezer/fridge into a pan. The pan usually has the compressor fan blowing over it to evaporate the contents.
Jul 28, 2009 | Frigidaire FRS6R5EMB Side by Side...
Water Freezing in bottom of Freezer and dripping out front of freezer door
this could either be a blocked drain from the freezer not allowing defrost water to escape or the defrost heater failing to turn on due to a faulty defrost heater or defrost timer not enabling the water to escape
Aug 12, 2008 | Frigidaire FRS26KF5C Side by Side...
Gladiator Freezerator Top Freezer Refrigerator Logo
522 people viewed this question
Top Gladiator Refrigerators Experts
Charles T Nevin
Charles T Nevin
christian nielsen
Are you a Gladiator Refrigerator Expert? Answer questions, earn points and help others
