IPF 8300 hardware error 03800500-2f42
I have a IPF 8300 and everytime i try to print it gives me this error code: 03800500-2f42. It says that it is a hardware issue and that I should shut it down and try again but the problem persists.
SOURCE: Cannon PIXMA MP520 Problem: Error code
I had this problem with the ink carriage jammed at the left hand side of the printer. I operated the lever in a hole on the top left hand side and eased the carriage along to the middle and pushed it back onto it's runners. All OK now.
Posted on Jun 29, 2008
  • 79 Answers
SOURCE: Canon iPF 8000: Hardware Error 03800500-2F2F and 03800500-2F30
it's a multiple problem....there is no enough ink for the head managment sensor to understand the good function of the print head.
Print a nozzle check to see what is going on
Then come back for more information
Posted on Mar 17, 2009
SOURCE: Hardware I/O error
I had the same problem and found no solution on the net, so I sent Samsung an email. Turns out I did not have the right driver (the original model on the printer says SCX-4521F, but there was a sticker in the box where the model shows SCX-4521FG. The Samsung help desk told me to install the scanner driver for the FG model and sent me print screen of the Printer Settings Utility. You have to set the output type to Grayscale (8bit mono) and the resolution to 150dpi.
Anyway, it works now. I had tried just about everything, I was about to put the printer back in its box...
Posted on Nov 10, 2009
SOURCE: Error code 03130031-2F13
We have an IPF700 and have been getting the 031300312f26 error alot upon warm up. We have found to fix this problem the best option is to push the print head back to its home position (far right) and unplugging the printer for 1 min or so (just to make sure its memory has lost all awarness we messed with it). Then plug it in and it goes fine... The problem we used to have is the same many of you are complaining about it drains ink like a vampire whenever you have to restart it. To cope with this we have upgraded our firmware which has drastically decreased the amount of ink we waist due to less cleaning and agitating functions. Hope this helps out someone it took us a while to get back any love for the canon but we are comming round again (I mean it worked great for 3 years why give up on it now).
Posted on Nov 17, 2009
  • 79 Answers
SOURCE: Canon IPF 700 with a hardware error 03800500-2f30.
this means that you have no ink flowing from the nozzles.
1.st if possible print a nozzle check from test print menu an see the result.
the other issue i can imagine is that you replace the print head without perform firmware update.
It is very important before replacing the print head to perform firmware upgrade (cd incl. inside the head box)
Also try a head cleaning B twice or more
Posted on Jan 04, 2010
I have an error msg E161-403E on an IPF 655 and cannot remove it to access the settings menu.
my kodak esp 7250 printer will go through all cycles but will not print anything. it does not give any errow codes or messages.
Sep 14, 2013 | Office Equipment & Supplies
My print head on my canon ipf 605 wont clean??
Hello!
I have printer Canon ipf 605 , on display is displayed print head error, I have put new print head, and the problem is the same, I tryed several print heads , most of them new , and it dont want to start....again and again printhead error is displayed...
Dec 11, 2010 | Canon imagePROGRAF IPF605 Printer
I have a Canon ipf 700 and am getting a code: 03800500-2F2F hardware error. Could someone please help me. Thank you.
03800500-2F2F Head management sensor error
The head management sensor detected an ink discharge error. A sensor sensitivity error was detected during head management sensor position adjustment.
Print head, head management sensor, or main controller PCB
1) Start by replacing the print head.
2) Visual check for any foreign substances around the head management sensor.
3) Replace the head management sensor.
4) If continuity of the cable between the head management sensor and the main controller PCB is abnormal, replace the cable.
5) Replace the main controller PCB.
I’m happy to help further over the phone at https://www.6ya.com/expert/jeremy_69f3cc28d95bf514
Jul 05, 2010 | Office Equipment & Supplies
WE HAVE A IPF 700 AND IT PRINTS FOR 10 SECOND AND THEN COMES UT WITH HARDWARE ERROR 03130031-2726 CAN YOU HELP
when i start my Canon ipf700 it comes upwith error message hardware error 03130031-2618
Jul 01, 2010 | Canon iPF700 InkJet Printer
Canon ipf 8000s
Over heat of the print head.
Turn off - Turn on the machine, if this will not work try to access the service mode update to the latest firmware version and replace the print head
Dec 25, 2009 | Canon imagePROGRAF iPF8000 Printer
Canon IPF 700 with a hardware error 03800500-2f30. Please help
Oct 29, 2009 | Canon iPF700 InkJet Printer
Error code E141-4046
Hi we have a big problem with our Canon IPF 8100 printer. We use it since 1, 1 and 1/2 years. We print 2500 A1 pages every week.
Today the following error appeared:
Error E141-4046
Call for service
We read another post about IPF 5000 and it was written, that it is a page count error.
We entered Service Mode but we don't know what and how to reset.
P.S. the problem is that it's Sunday in our country and none of the service companies work. We have a lot of copies to print.
Please help. And thanks.
Sep 19, 2009 | Canon imagePROGRAF iPF8000 Printer
Feb 10, 2009 | Canon Office Equipment & Supplies
197 people viewed this question
k24674
jasbo
jasbo
