Question about Ice O Matic Complete Units ICE0250FA Cube Ice Maker Machine 336 lb/day
Ice does not make completly in cycle
Not enough water on cooling mechanizm
    Prodigy:
    An expert who has answered 500 questions.
  • 512 Answers
Be sure your water level sensor is not corroded and dump valve not leaking
Posted on Apr 07, 2014
I worked on a hoshizaki km-500mae when i turn it on the first cycle it makes good ice but after the first cycle it makes little pieces. why?
time the cycle. if it is only running about 5 minutes and going into harvest, look for sump loosing water. Look at where the unit drains (like a floor drain) while the unit is running to see how much, if any water is draining. does not take much to make an early harvest. also, sump may not be filling up completely but with just enough water to satisfy the float.
Feb 16, 2015 | Hoshizaki Freezer Commercial Ice Machines...
GE ice maker
If the freezer is cold enough to freeze food hard, look for a problem in the water line, water inlet solenoid valve, or possible ice build up on the ice maker itself that does not the allow the ice maker to complete it eject cycle and start a new ice making cycle.
Jul 14, 2014 | GE (PSS26MSRSS) Side by Side Refrigerator
Its a 450 mah hoshizaki, it keeps jumping from freeze cycle to harvest cycle without giving it enough time to make a load of ice
usually, if it does not stay in the freeze cycle long enough to make ice or it just makes slivers of ice, it is loosing water. during the freeze cycle, look to see if water is draining down the drain from the machine. If not, I would look at the float position. it should be almost completely in the lower, down position. give that a shot.
May 31, 2014 | Hoshizaki Cubelet Ice MakerDispenser Water...
I have a KitchenAid Side by Side with a stubborn ice maker (modular). It seems to make ice, but it won't complete the full harvest cycle for some reason. I can mess around with it (basically warm it...
Hello Tom,
I see where ya said the water dispenser works good and thats cool! when you do get the i/m to run the ice harvest cycle are the cubes full size? if yes the water supply can be ruled out as a possibility. Besides the water not seeming as cold are other things in the fresh food compartment NOT as cold as they are not as cold as in the past,if yes try removing the grill below the doors and clean the dust from the coil there,if it isn't there its the rear of the ref. by the compressor. One of the first things to be affected when a ref is working hard to keep things cool due to a dusty coil is going to be the icemaker,it will freeze the ice but the internal thermostat inside of the i/m module isn't satisfied its cold enough to start the harvest. When jumping out the T&H what exactly your doing is jumping the t-stat regadrless of the temp. of it ,causing it to run a harvest cycle
I hope this answer helps you,
Gene
Aug 05, 2011 | KitchenAid KSCS25FKSS Side by Side...
I have a Whirlpool refrigerator with the ice maker inside the freezer. It does make ice, but a lot of the ice bubes are either hollow or partly formed. I took the filter off completely and it not help. Any...
Good day,
Sounds like your not getting enough water on the fill cycle.
Unlike a washing machine, you have 7 seconds for a fill cycle to complete. Period.
It's either the water valve on the bottom rear of the machine not opening completely and must be replaced since it's a non-repairable item, or the house water supply system is corroding and slowing the water down.
Sep 13, 2010 | Whirlpool 25.6 cu. ft. Side-by-Side...
Slow ice cycle
Are you having any temperature related symptoms, i.e., soft ice cream that appears to have melted slightly and refrozen, soft breads in the freezer, warm or hot outer surfaces anywhere? If cooling is not a problem whatsoever, are any of your ice cubes smaller than normal, or do you have hollow ice cubes; you would be able to crush the cubes in your hand? If either of these pertains to you, you have not enough water coming to the ice maker, due to a faulty water valve not opening completely, or your water source pressure is low. disconnect your water line from the fridge, test pressure of the water line by placing end in a bucket, turning water on. It will be obvious how the pressure is. if pressure is good to really good, you have a bad water valve on the fridge. If pressure is so-so to bad, change source water valve.
If cubes are not small nor hollow, but rather normal full size cubes, just not enough, you probably have an intermittent problem with your icemaker, replace that.
Mar 31, 2010 | Avanti Freezer Compact Ice Maker - 12 lbs....
Ice maker is not making ice
Subzero ice makers arent all cut and dry. You could have an intermittent issue with either the ice maker itself, or the solenoid valve. SZs also often utilize a door switch which prevents the ice maker from operating if the door or the basket which the ice bucket sits in are not closed or in the proper position. If you have had other what would seem minor problems, that you have lived with, they can inadvertently affect different things. Most sub zero ice makers you can start manually by rotating the ejector comb clockwise as you look at the front of the icemaker, when the icemaker completes its cycle, do you get water to the ice maker, and do you get enough water, usually 140-150 ccs. If the ice maker continues rotating on its own after your initial start up, and receives the proper amount of water, either you have a cooling problem, a door or something is not in the correct closed position, you have a bad switch, or the ice maker is bad. If you receive little or no water at end of cycle, you have a bad valve.
Mar 25, 2010 | Sub-Zero 15.3 cu. ft. / 433 liter Upright...
Ice maker makes very little Ice and the cubes are small.
The amount of ice is not dependent upon water flow, well as long as you do have flow, when enough water is in the maker it will shut off the supply.....ice quantity is dependent upon the length of the freezing cycle, the shorter the cycle the more harvests per hour. Adjust the timer so that you get complete freezing, but just barely
Jan 16, 2009 | Whirlpool GS6SHEXNL Side by Side...
Ice Maker not going through complete cycle
what kind of unit is it? there are several possibilities
May 07, 2008 | Refrigerators
Ice O Matic Complete Units ICE0250FA Cube Ice Maker Machine 336 lb/day Logo
60 people viewed this question
Top Ice O Matic Complete Units Kitchen Appliances - Others Experts
robert
Tom Chichester
marlin siecinski
Are you an Ice O Matic Complete Units Kitchen Appliances - Other Expert? Answer questions, earn points and help others
