Question about Lexmark "x548de multifunction laser printer"
What is the key sequence on POR to access diagnostic mode on a lexmark printer?
What is the key sequence on POR to access diagnostic mode in lexmark printer?
Can I check how many copies I have made on my printer
Please access the Diagnostics Menu.
To enter the Diagnostic Mode:1. Turn the printer off.2. Press and hold the Go and Return buttons.3. Turn the printer on.4. Release the buttons when "Performing Self Test" displays onthe operator panel.
Once you are in the Diagnostics Mode, choose Printer Setup and then select Permanent Page Count.
Aug 01, 2012 | Lexmark Optra S 1855 Laser Printer
I have replaced my photoconductor in my Lexmark x464 and I still have a warning notification comming on. How do I reset it?
Try:
To restore factory defaults:
1. POR the machine into Configuration Mode.
2. Use the down navigation button to scroll to the RESTORE
FACTORY DEFAULTS item on the menu.
3. Press Select. The machine performs a POR.
4. The RESTORE FACTORY DEFAULTS sets the MFP non critical
parameters back to the factory settings.
Note: Some settings are not affected: panel language, energy
conserve, paper prompts, registration margins, and page count.
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
May 20, 2011 | Lexmark X464DE Mono Laser MFP, 38ppm A4...
Hola como etas soy Liz, por favor necesito ayuda, tengo un plotter Designjet T1100ps, estaba imprimiendo normalmente, se termino el rollo cuando lo cambie se atasco el papel, y segui las instrucciones del...
Issue When the printer comes up with an error code on the front panel, we may have to perform the service test(s) related to the error code. Sometimes when we enter into service/diagnostic mode and try to perform a test, the printer may come up with system error 79:04 (non-continuable generic error). When this occurs in diagnostic mode, it is not likely possible to analyze it by pressing front panel keys (e.g., up arrow and cancel); the printer will likely be hung/stuck with the error. Solution To overcome this issue, ensure that no data cable is connected to the printer (Network/USB/Fire Wire). For proper use of the diagnostic menu, the printer should be in a stand-alone state (only connected to power). Once it is confirmed that the printer is in stand-alone mode, then enter back into service/diagnostic mode and perform the test(s) required.
Dec 15, 2010 | HP Designjet T1100ps Printer
I AM TRYING TO FIND THE STEPS FOR A FAX QUE CLEAR FOR A LEXMARK X342N. CAN YOU HELP?
To clear the fax flash memory you will need to enter diagnostic mode. Use the following steps.
1. Press the menu key, the * key, and then the # key. The LCD will read SERIAL NUMBER. 2. Press the up arrow once. The LCD will read UTILITIES. 3. Press the checkmark button. Press the down arrow until Erase EFS. Then press the chechmark button. 4. The unit will now erase the fax memory then reset itself to a ready state.
This will erase any faxes that may be blocking the memory.
Aug 20, 2010 | Lexmark X342n All-In-One Laser Printer
How do i reset me lexmark 5070 printer after i used a refill for ink
  • Launch "Printer Solution Center." You should have installed this program when you installed your Lexmark printer. Click on the Start button and selecting "All Programs." The menu command or shortcut for this program is located under the "Lexmark" folder. Click on it. If you do not see this program for some reason, insert the installation CD (provided in the printer box) into the CD/DVD-ROM drive. Follow the on-screen prompts to install the program.
    Step 2
    Click on the tab that says "Maintenance" on the top menu.
    Step 3
    Click on the button titled "Install a new printer cartridge."
    Step 4
    Hit "Next" to launch "Print the Alignment page" window.
    Step 5
    Hit the "Print" button. This will reset your ink cartridges. You should be able to see a correct reading of the ink levels on your Lexmark printer.
    Step 6
    Repeat this process until you successfully reset the ink cartridges. Sometimes, it may require multiple attempts to complete this task
    if you want to know how to reset the complete thing then...
    Resetting a Lexmark printer
    You will firstly need to switch off your printer. Then simultaneously press the RETURN and READY keys while switching the printer on. This will take you to the Diagnostics Mode. The display unit will show the message 'Performing self test'. Choose 'Maintenance count'. Reset the count to make it zero. Then select the RETURN key and go back Diagnostics Mode. Then you can reset the printer to go back to the normal mode.
    hope this works for you...
  • Aug 07, 2010 | Lexmark X5070 ALL-IN-ONE InkJet Printer
    Prints one or to pages then stops. Have to reset computer to get it to work. No test doesn't work. It is like it runs out of memory.
    Try to run a test for continuous print test page in diagnostics mode. To enter the Diagnostics mode:
    1. Turn off the printer.
    2. Open the front access door.
    3. Turn on the printer while pressing and holding Cancel .
    4. Close the front access door once the Error light displays. Print the menu page by pressing and holding Continue until all of the lights flash. Follow the instructions on
    the menu page to access the menu items.
    Continuously print pages containing cross lines, printer information, and margin settings. Press and hold until the Continue button lights flash to begin. Press Cancel to stop.
    Make sure he selects the "Cont Prt Simplex Tray 1" option
    If problem persists, contact Lexmark at 1-800-LEXMARK()1-800-539-6275.
    Apr 21, 2010 | Lexmark E260dn Laser Printer
    Need trouble shooting proceedure to enter self diagnostics for maytag neptune
    From the service manual there is more to it but that was all I could put here.
    Accessing Service/Diagnostic Mode:
    Pressing down the damp dry and time (-) keys
    for 5 seconds places the machine in the
    diagnostic mode.
    SPECIAL TESTS
    The following table lists the various tests
    available while in the Service Mode, which
    can be accessed by pressing the following
    keys:
    Press Keys Special Test/ Function
    wrinkle
    release Diagnostic Codes
    dryer
    temp(^ )
    Sequences up the
    help/diagnostic code list
    dryer temp(v) Sequences down the
    time (-) Displays Software Revision
    Number
    very dry(< ) View current cycle
    temperature (Co)
    start/pause
    Start or pause cycle running
    but remain in Diagnostic
    mode
    Accessing Diagnostic Codes
    After the machine is in the diagnostic mode,
    a ‘d’ will display and let the technician know
    they are in the diagnostic mode. Pressing the
    wrinkle release key will access the diagnostic
    codes.The diagnostic codes can be viewed by
    using the temperature (^) & (v) keys.
    The down arrow key will sequence down the
    list one each time it is pushed with no wrap.
    The first time the down arrow key is pushed
    the display will sequence to the next code
    logged. The last code being displayed being
    the oldest code. The up arrow will sequence
    up the list one code each time it is pushed
    until it reaches the top code. If there are no
    diagnostic codes available, ‘00‘ will be
    displayed for the diagnostic code.
    There will be no multiple occurrences of
    either a diagnostic code or help code generated
    in the same cycle reported on the list.
    But if the same code occurs in repeated
    cycles, it will be registered.
    To clear the diagnostic code list press
    wrinkle prevent and very dry (>) for 5
    seconds while viewing the list.
    System Check Mode
    While in diagnostic mode, pressing the damp
    dry
    and signal (+) keys for 2 seconds, will
    put the dryer into the system check mode.
    "SC" will display.
    This mode will allow the various inputs and
    outputs to be controlled and viewed by the
    technician by pressing individual keys. If no
    activity is seen for 5 minutes after a key is
    depressed, the control will reset back to the
    normal mode. If no further activity is seen
    after an additional 5 minutes the washer will
    turn off. The following table lists the various
    functions based upon on keys being depressed.
    Membrane Pad Check
    While in system check mode, pressing the
    damp dry and sensor dry keys for 5 seconds,
    will start a membrane pad switch test.
    The membrane check involves turning all the
    embedded LED on the membrane pad on.
    All the LED’s can be toggled off by pressing
    the key associated with the LED. To exit the
    test at any point, press the damp dry (>) &
    sensor dry keys again for 5 seconds or press
    the off key to exit diagnostic mode.
    Key Pressed: Function Performed
    sensor dry
    Enable sensor dry circuit.
    (sense dry LED) When short
    circuit is detected across the
    sensor bars the normal dry
    LED will turn on.
    start/ pause
    Cycles the motor relay
    on/off. When the motor is
    running the start/pause LED
    is on.
    dry temp(^ )
    If motor is running, cycles
    the heater/gas valve on/off.
    When the heater is regular
    temp LED is on.
    temperature (Co)
    www.appliancehelponline.com
    Mar 26, 2010 | Maytag Neptune MDG5500AW Gas Dryer
    I can not get it into service mode.
    There is not a "diagnostic mode" for the neptune washer.
    All tests and functionality are done at each setting using the timer (except the tach circuit)
    What is the problem you are looking to diagnose??
    Thanks!
    Mar 15, 2010 | Maytag Neptune FAV6800AW Top Load Washer
    I have a lexmark x6570 all in one printer. I recently restored my pc and I unistalled my printer. Then I reinstalled it again. Now the WIFI light is blinking orange.
    If the printer is blinking with a orange lights means that the printer is not connected to your wireless network. Some possible solutions:
    Check the wireless connections (If you've restored your computer you have to set the wireless connections again)
    Check the access point
    Move your computer or printer to reach the access point
    Try adjusting the antennas
    Make sure the Key Web keys are correct.
    You will find more help here:
    http://images.lexmark.com/publications/pdfs/2007/6500/v4897402_en.pdf
    SEE PAGE 146
    Another blinking situations (not wireless related)
    If the printer is blinking in a slow mode, then the printer is in a sleep mode.
    Do this:
    1) Unplug the power cable from the wall outlet
    2) Wait 10 seconds and plug the cable again
    3) Press the power button to turn on your printer
    This must be fixing the problem
    Nov 18, 2008 | Lexmark Office Equipment & Supplies
    Printer want print
    OK Try this
    Resetting purge counter:
    1) Enter machine maintenance mode (on MFC210C all four photo/copy/fax/scan lights flash in maintenance mode). Care is needed in maintenance mode, otherwise critical settings may be inadvertently corrupted.
    FAX models with numerical keypads: Press the Menu/Set, *, 2, 8, 6 and 4 keys within two seconds. (if you fail to complete the correct key sequence within two seconds, press the Stop key to try again).
    Other (non-FAX) models: Press the Menu/Set and Black Start keys. Next press the “up arrow” key four times to enter the maintenance mode).
    2) Press the 8 then 0 keys in the initial stage of the maintenance mode to call up the machine's log information list (function code 80).
    3) Press the Black Start key several times to scroll through the log information list to reach the purge counter. The purge counter is the 25th item in the list.
    4) Press the 2, 7, 8, and 3 keys in this order to reset the purge count to zero.
    5) Press the Stop/Exit key to return to the initial stage of the maintenance mode.
    6) Press the 9 key twice to return to the standby state.
    Dec 03, 2007 | Lexmark X5150 All-In-One InkJet Printer
    Lexmark "x548de multifunction laser printer" Logo
    96 people viewed this question
    Top Lexmark Office Equipment & Supplies Experts
    Don  Farrell
    Don Farrell
    Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
