Question about Canon ZR800 Mini DV Digital Camcorder
Driver zr800 get a usb error 43
Error code 43
Code 43 is almost ALWAYS a driver problem, not necessarily an external driver, it could even be one of Windows' own. There is a well-written (in my opinion) page at http://pcsupport.about.com/od/errorc/a/code-43-error.htm which discusses the error and how to fix it in simple, step-by-step fashion.
Code 43 errors can be frustrating and time consuming to troubleshoot, but take you time, work it step by step, and best of luck to you.
Oct 21, 2013 | Western Digital My Book Essential 500GB...
I cannot cannect my 6230i nokia to my computer when connected your device is reported windows error 43
Error Code 43 is a Device Manager error that means the following:
Windows has stopped this device because it has reported problems. (Code 43)
When you get this error with USB devices it's because one of the drivers controlling the device notified the operating system that the device failed in some manner. It will be of issue of the loaded corrupted drivers. You should reinstall the operating system or reinstall the drivers that doesnt have virus or file damages.
Oct 05, 2013 | Nokia 6230i USB
What is USB error 43
This is device manager error. It means One of the drivers controlling the device notified the operating system that the device failed in some manner.
You can visit this link for the solution of your problem.
http://social.technet.microsoft.com/Forums/en/w7itprohardware/thread/6f40e3e8-7283-47e4-a13f-ca6c4f3fae02
Feb 26, 2013 | PQI 512MB Intelligent Stick USB 2.0 Flash...
P5n-e sli usb ports error 43
You get this error code if there is an issue with the drivers.
Look here:
http://answers.microsoft.com/en-us/windows/forum/windows_7-hardware/usb-ports-not-working-error-code-43/ce6662bf-cfad-4380-a274-709bf072e3d7
Here is the homepage:
http://support.asus.com/Download.aspx?SLanguage=en&m=P5N-E%20SLI&p=1&s=22
Please select your windows system.
You probably need to download the chipset driver.
Open the folder, and click on global for download.
Unzip the file before you install the driver.
Look also in the bios setup, for the usb settings.
Try also to download the manual.
Try also to upgrade the bios.
Hope this will help you
Jan 31, 2013 | ASUS P5N-E SLI Motherboard
What is code 43
Code 43 Error Message
The Code 43 error is one of several Device Manager error codes. The Code 43 error will almost always display in the following way:
"Windows has stopped this device because it has reported problems. (Code 43)"
Details on Device Manager error codes like Code 43 are available in the Device Status area in the device's properties: How To View a Device's Status in Device Manager.
Cause of the Code 43 Error
A Code 43 error is generated when Device Manager stops a hardware device because the hardware reported to Windows that it's having some kind of unspecified problem.
This extremely generic message could mean there's a true hardware issue or it could simply mean that there's a driver problem that Windows isn't seeing as such but that the hardware is being affected by.
Error Code 43 Troubleshooting
Restart your computer if you haven't done so already.
There is always the chance that the error Code 43 you're seeing on a device was caused by some temporary problem with the hardware. If so, a restart of your computer might fix the Code 43 error.
Note: Some users have also reported that powering off their computer completely (not just a reset) and then turning it back on has corrected their Code 43 issue, especially if it exists on a USB device. In the case of a laptop, turn it off and remove the battery, wait a few minutes, and then put the battery back in and start the computer.
Did you install a device or make a change in Device Manager just before the Code 43 error appeared? If so, it's very possible that the change you made caused the Code 43 error.
Undo the change if you can, restart your PC, and then check again for the Code 43 error.
Depending on the changes you made, some solutions might include:
Jan 23, 2013 | Lenovo Computers & Internet
How do I fix the msi motherboard windows 7 USB error 43?
How to Fix a Code 43 Error
  1. Restart your computer if you haven't done so already.
  2. Did you install a device or make a change in Device Manager just before the Code 43 error appeared? If so, it's very possible that the change you made caused the Code 43 error.
  3. Reinstall the drivers for the device. Uninstalling and then reinstalling the drivers for the device is a possible solution to a Code 43 error.
    Important: If a USB device is generating the Code 43 error, uninstall every deviceunder the Universal Serial Bus controllers hardware category in Device Manager as part of the driver reinstall. This includes any USB Mass Storage Device, USB Host Controller, and USB Root Hub.
    Note: Properly reinstalling a driver, as in the instructions linked above, is not the same as simply updating a driver. A full driver reinstall involves completely removing the currently installed driver and then letting Windows install it over again from scratch.
Sep 16, 2012 | MSI INTEL G41 INTEGRATED VGA-MATX 2DDR3...
My new computer only has usb - I have firewall cable for this - ZR800 mini digital video that I used with my old computer - what do I do?
Most Windows PCs have USB ports, but no Firewire port. As your PC did not come with this interface, you need to fit an add-on Firewire interface card in one of the bus slots. This will come with a driver for the card. I am assuming a desktop PC, you don't say what kind of computer it is. If it is a laptop, you won't be able to fit a card. You can get Firewire interface cards from Amazon or eBay quite cheaply.
Nov 23, 2010 | Canon ZR800 Mini DV Digital Camcorder
How can I find out if my Canon ZR800 has DV pass-through capabilities?
Yes, it does. According to the manual (found here http://gdlp01.c-wss.com/gds/0/0900000700/02/ZR800NIM-EN.pdf) on pages 42-43, you can hook the camera up to a monitor with an HD (IEEE 1394) connection as seen on page 42. If you are looking for digital pass through to a PC, you'll have to download the drivers at Canon's website to get it to work with a web cam software.
Apr 08, 2010 | Canon ZR800 Mini DV Digital Camcorder
Computer reconized canon zr85, but not the zr800
load or reload the drivers for the zr 800,you should be able to get the drivers off of canons website
Dec 03, 2009 | Canon ZR800 Mini DV Digital Camcorder
Canon ZR800 won't connect
Your saying 4 pin USB firewire. Which one is it?
It should be 4 pin firewire.
What is the error message that you are getting?
Jun 09, 2008 | Canon ZR800 Mini DV Digital Camcorder
Canon ZR800 Mini DV Digital Camcorder Logo
19 people viewed this question
Top Canon Video Cameras Experts
Pieter Vleeshouwers
Pieter Vleeshouwers
Steve Mason
Are you a Canon Video Camera Expert? Answer questions, earn points and help others
