Question about Maytag MMV4205 Microwave Oven
It is operating normally except not heating the food
  • 6,784 Answers
The most common problem spot when the microwave will not heat is the magnetron. this is a device that produces the heating effect. you will need to replace this failed component. it has failed. Replace the Magnetron.
Posted on Jun 15, 2009
Electrolux microwave buzzes and food doesn't heat up
If the unit operates correctly except heating the food, then the unit needs a new magnetron.
Aug 29, 2012 | Electrolux EI30BM55H Microwave Oven
The microwave does not heat up the food but everything works except the fact that it don't heat up the food
Hi!
The most common cause of the problem you described is a burned fuse. It is normally located inside the case, directly on a wire leading from the transformator to the magnetron. If you are not sure about those parts, please get a professional to fix the issue.
Aug 20, 2011 | Samsung SMH9187ST Microwave Oven
Our microwave looks and sounds to be operating normally, except that nothing becomes heated despite using different pre-set or manual modes.
If it sounds normal and not heating, you may need to replace the magnetron. this is a very common problem and normally occurs from the overheating of food.
if the microwave is making a gumming noise, then the diode needs to be replace.
Feb 08, 2011 | GE JE1640WA/GA Microwave Oven
Maytag microwave oven model mmv4205bab not heating food
maytag microwave model # mmv4184aaq operates normally but will not heat food or water
Mar 07, 2010 | Maytag MMV4205 Microwave Oven
Have GE JVM2050 over the range microwave, which stopped heating food and water since this morning. All other functions including light, key pad, clock, turntable work normal. The magnetron sound also
if everything works except the heating, it is most likely the mag tube is on its way out.........that is the most common reason for it not too cook.......since the microwave is a GE and it is 3.5 years old, i would say you are better off buying a new microwave, the mag tube starts at around $70.00 and up + the labor it costs too have a service person put it in........around another $60.00
May 02, 2009 | GE JVM2050 Microwave Oven
My micro wont heat the food but everything else seems ok
I have a GE Spacemaker Microwave, model # JVM1650WB008
The lights work and everything runs in a normal operation, it will not heat the food. I have changed the fuse and still the same, no heat.
Oct 05, 2008 | Microwave Ovens
No more heating, GE Profile Microwave JVM 1870CF02
I think its the mag tube, mine went out the same way. GE will provide the mag tube for free just call them...have a local ge certified tech out to put it in.
Aug 31, 2008 | GE JVM1850 1000 Watts Microwave Oven
GE Over range microwave, JVM1660
This just happened to ours as well. Apparently the magnetron (device that creates radio waves that heat the food) is broken. I'm trying to pry the darn thing out of our kitchen now so I can replace the magnetron. Look for this part WB27X10489 on Google. I found it on ebay for $65. If it fixes the problem I'll post again.
Aug 18, 2007 | GE JVM1660 Microwave Oven
Maytag MMV4205 Microwave Oven Logo
248 people viewed this question
Top Maytag Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Maytag Microwave Oven Expert? Answer questions, earn points and help others
