Question about Whirlpool GEW9878LW Electric Dryer
My whirlpool will not start
Control lights come on but won't run
Remote wont work for fan.
http://www.ehow.com/how_6104129_instructions-hampton-bay-fan-remote.html You may need to reprogram the remote
May 15, 2013 | Televison & Video
2006 dodge stratus won't crank and cruise control won't light
Must not have been much of a mechanic. If the engine runs and sounds fine sometimes and other times it doesn't then it does not sound like a mechanical problem with the engine. Sounds more like a issue with either the ignition system or fuel system.
Feb 20, 2018 | 2006 Dodge Stratus
1996 buick riviera heater blower won't run. I jumped the motor and it runs. Turn on the switch and it won't run
you have a piece of solder broken off the controller of your hvac unit, causing power not to get to the blower motor it self. take test light and see if you have power at the blower motor. check and see if you have continuty or brake between the power wire at the blower motor and at the hvac control unit. if wires are good then the problem will lie in the hvac control unit. check and see if the blower is working at all speeds, if it works on some speeds thens the blower motor resistor.
Sep 29, 2011 | 1996 Buick Riviera
I have a deep freezer,the light is on but doesn't freeze. It's only 2 yrs old what could be the problem?I unpluged it and waited 10 mins pluged back in and nothing the red light stayed on but...
Well a freezer is easy to repair. The circuit goes from one side of the power cord to the cold control and down to the compressor then out to the other side of the power cord. Id the control or compressor relay is open then she won't freeze. All the parts to it are listed HERE.
From the list I see an overload for the compressor. If that one is open it won't freeze. Bypass the temp control wires to see if she runs.
Sep 13, 2011 | Magic Chef Chest Freezer MCCF5WBX
Engine light is on code po449
That's an Evap Emission Control System Vent Valve/Solenoid Circuit.
The vent valve for the emission control system is not working.
Usually it is mounted on the charcoal canister. It won't affect the running of the car,but the light will be annoying. Have the vent valve replaced.
Sep 07, 2011 | 2003 Chevrolet Avalanche
If I plug in my trailer and turn on the ref.model 2652 it works fine. I can convert it over to gas with no problem when it has been running off electric but if I try to light it on gas first it won't...
http://www.gasrefrigeration.net/dom_techdata/26121_2852SM.PDF
Your problem seems to be in the control circuitry but I don't think it is a true fault. I would suspect corrosion on the connectors of the upper and lower control boards instead of a faulty control board.
I use a combination of scouring pad and #2 pencil eraser to clean the contacts.
Sep 06, 2011 | Dometic RM2652 Refrigerator
How do I change the pilot light as it is not working anymore.
It won't be the pilot light, It will be the gas valve control, if the pilot light actually lights but the burners won't light,, then you need to check the thermocouple , its that little round thing that sits inside the flame of the pilot light, and has (usually) a copper tube that runs back to the actual gas valve, If its gone bad, the signal to the gas valve is lost so the gas never gets released so nothing lights
Jul 07, 2011 | DeLonghi DEFSGG36-SS Gas Kitchen Range
Daytime running lights won't shut off on 2001 grand am
check the drl 9daytime running lights0 relay under the hood. I could be stuck in the on position.
May 29, 2011 | Pontiac Grand Am Cars & Trucks
Whirlpool GEW9878LW Electric Dryer Logo
14 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal De
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
