Question about HP Officejet 5610 All-In-One InkJet Printer
HP5610 all in one, error message oxd0620230, reset power. I reset power, but it will not print, starts printing then I get the same message again.
This happens to me when my kids try to print something and it gets stuck in the print log and I can't delete it...I am not a cpu guru by any means, but I found these steps easy to do and it works....
1. control panel>admin tools>services> right click on Print spooler in list> press stop (leave this window open).
2. go to Cdrive>windows>system32>spool>printers>select all>delete
3. go back to print spooler in list from #1 and right click start
4. restart computer
There is almost always a "flash" off the page that the kids tried to print that "hangs" up the printer. I hope this helps.
Posted on Jul 09, 2009
  • 102 Answers
HP Officejet 5610 All-In-One InkJet Printer has few common problems. Such as Driver CD lost,Scanner does not work, Connection problem etc. For find all these software solution just clickhere....
http://www.hp.com/printer/prob676ijt65/solution
ab26
Posted on Jul 17, 2009
  • 33 Answers
Hi there, " Unplug the printer cable from the computer. " Unistall the printer drivers from Device manager and also unistall the all the printer appications " restart the computer " try to download drivers from the website " after installing drivers and software it will ask you to connect the printer. " then you can connect the printer and and try to Print the test page.
Thank u Thiru
Posted on Jun 15, 2009
  • 355 Answers
0x errors mean that the printer has an internal error within the firmware of the printer. There are not many steps to try except for a reset. This is a document from hp that you can use to do the reset and hopefully it will clear the error.
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00489814&cc=us&lc=en&dlc=en
I installed a new cartridge in Brother MFC-7860DW after the old one was getting light. It's very new but the message "Replace Drum" is on and the printer won't print. Drum counter shows 12,022 pages. I...
You must reset the drum counter in order to print again. Here is the method http://support.brother.com/g/b/faqend.aspx?c=us&lang=en&prod=hl2280dw_us&faqid=faq00002837_000#instruction
Jan 07, 2018 | Brother MFC-9840CDW Laser Printer
How to reset a brother mcf-7420 printer?
  1. Start the BRAdmin Professional utility, by clicking Start => All Programs or Programs => Brother Administrator Utilities => Brother BRAdmin Professional Utilities => BRAdmin Professional.
  2. From the main BRAdmin screen double click the appropriate printer.
  3. Enter the print server password (The default password is "access").
  4. Click the Control tab
  5. Click the Restore Factory Defaults button
  6. Click the OK button when you have read the warning message.
  7. The print server will then reset back to its default values.
  1. Start the BRAdmin Professional utility, by clicking Start => All Programs or Programs => Brother Administrator Utilities => Brother BRAdmin Professional 3 => BRAdmin Professional 3.
  2. From the main BRAdmin screen double click the appropriate machine.
  4. Click Network Configuration tab, Control Panel and select Set Default.
  5. Click on Submit button.
  6. The print server will then reset back to its default values.
Via a web browser
Because web based management requires the TCP/IP protocol for communication, any reset option you see when managing the machine with a web browser, will not reset the IP address details that are set. If you wish to totally reset all the print server parameters we recommend you reset the print server by using the BRAdmin application.
To reset the print server (excluding TCP/IP parameters) follow these steps:
  1. Connect to the printer using a web browser.
  2. Click Network Configuration.
  3. Enter the print server password (the print server password is detailed in the user guide for the print server) if it's applicable.
  4. Click the Set Default link or Reset Print Server.
Via the control panel (only for network ready models)
  1. Make sure the machine is not operating, then disconnect all the cables from the machine (except power cable).
  2. Press the Menu or Menu/Set key on the control panel.
  3. Press up or down navigation key to select LAN or Network and press Set, Menu/Set or OK.
  4. Press up or down navigation key to select Factory Reset or Network Reset and press Set, Menu/Set or OK.
  5. Select Reset.
  6. Select Yes.
  7. The machine will re-start, re-connect cables once this is complete. please rate it
Nov 29, 2010 | Brother MFC-7420 Printer
I installed a new color cartridge in my printer but it comes up with cartridge missing and i can't get to print in color
Power off the All-In-One and remove the power adapter (brick) from the back of the unit. Wait 20 seconds, reinsert the adapter, and power the unit on.
Did the error message return?
Yes: Continue to step 2.
No: Print a test page. If the test page prints, the error is resolved. 2
Reset the All-In-One's factory defaults (click here for instructions).
Yes: Continue to Checking the Cartridges.
Open the top cover of the All-In-One. Remove both cartridges. Close the top cover. 2 Power off the All-In-One and remove the power supply brick from the back of the unit. 3
Reinsert the power supply brick into the back of the All-In-One and power the unit back on.
Does the error message reappear?
Yes: Skip to Contacting Lexmark below. There is a hardware issue with your printer and you need to contact our technical support center.
No: Continue to step 4. 4
Clean the cartridge contacts (click here for instructions) and the AIO carrier contacts
(click here for instructions). Continue to step 5. 5
Power the AIO on, reinsert the black/photo cartridge, and close the top cover. Power the All-In-One off and then on again.
Yes: Power the unit off and try step 5 with another black/photo cartridge. If the error persists with the new cartridge, proceed to Contacting Lexmark.
No: Continue to step 6. 6
Power the AIO on, reinsert the color cartridge, and close the top cover. Power the All-In-One off and then on again.
Yes: Power the unit off and try step 6 with another color cartridge. If the error persists with the new cartridge, proceed to Contacting Lexmark.
No: Try printing a test page. If the test page prints, the error is resolved
Oct 28, 2010 | Lexmark X7170 All-In-One InkJet Printer
Hp5610 all-in-one
see it this site your problem solved
http://cluetechnologies.com/index.php?topic=688.0
Jul 03, 2010 | HP Officejet 5610 All-In-One InkJet...
HP psc 1310 - gave paper jam and print cartridge error. There was not paper jam and paper jam message went off. My son changed one of the print cartridges, although it still had ink in it. The error...
clean the rubber rollers of the printer and try to print. if it is still having the same problem. reset the printer by unplugging the power cord of the printer while its turn on. then plug the power cord back in. once the printer is on press and hold the power/on button and the size button. when the on button is flashing then release the buttons and try to print again
Oct 28, 2009 | HP PSC 2410 All-In-One InkJet Printer
Reoccuring align page error message
Hello sir; Wen you alginedthe you have to pick up the most clear letter then press resume if you don't pick up the number or letter and press resume , he message will come back again.
Aug 02, 2009 | HP Officejet 5610 All-In-One InkJet...
Error message Oxd0620230, hp 5610 all-in-one, i have tried all the power resets. the cartridge stalls when the code comes up but it don't always stall in the same position. lights flash... also have the...
error message Oxd0620230, hp 5610 all-in-one, i have tried all the power resets. the cartridge stalls when the code comes up but it don't always stall in the same position. lights flash...
May 02, 2009 | Office Equipment & Supplies
E3 error message
Dude,
E3 refers to Paper Jam :)
this may come in handy:
Service mode operation procedures -
1) With the printer powered off but connected to a power source, press the Power button while pressing and holding
the Stop/ Reset button.
2) When the Power LED is lit, press the Stop/Reset button two times while pressing and holding the Power button.
3) When releasing the Power button and the Stop / Reset button (regardless of order), the printer will move into a
service mode. (Waiting for menu selection)
4) When the LED lights in green, press the Stop/Reset button the specified number of time(s) according to the
function listed in the table below.(Each time the Stop/Reset button is pressed, the LED lights alternately in
orange and green, starting with orange.)
The number of the Reset
button pressing
LED Function Remarks
0 time Green Power off
1 time Orange Service pattern print
2 times Green EEPROM print
3 times Orange EEPROM reset
4 times Green Waste ink counter reset See waste ink counter reset
procedures below.
5 times Orange Destination setting See Destination setting
procedures below.
6 times Green Print head deep cleaning
11 times Orange Button / LCD checking
12 or more times Returns to a menu selection
îäíàêî, äëÿ ôóíêöèé 4 è äàëåå åñòü ïðèìå÷àíèå : òîëüêî äëÿ àçèè.
à âîò â îïèñàíèè ôóíêöèè 3 åñòü : Reset except for the
followings:
- USB serial number
- Destination setting
- Waste ink counter ...
Turn it upside down and than check.....same error code or diff.
Any help, can buzz me nytime ...
Thnks.
Jan 05, 2009 | Canon PIXMA MP150 All-In-One InkJet...
How to correct error message sram error missing E?
Hate to say this but most likely the Print Engine Control Board has failed.
May 09, 2007 | Xerox Phaser 7300DN Laser Printer
HP Officejet 5610 All-In-One InkJet Printer Logo
622 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
