Question about Maxi-Cosi Priori
Lost Maxi cosi recyning rod
In between grandchildren I have lost thee reclining rod in my Maxi-cosi prioro car seat can I get a replacement.
  • Maxi-Cosi Master
  • 1,629 Answers
Hi
Which model Maxi-Cosi Priori is it?
The original Priori was discontinued some time ago and we can no longer support this product for spare parts or repairs. We would advise that this particular seat is replaced.
The Priori SPS, PrioriXP and PrioriFix carseats are still part of the current range so can be supported for spare parts and repairs. If you visit www.maxi-cosi.com and select which country you're in you'll find a Contact Us tab on the right side of the page where you can click to send your enquiry to the customer care team in your country.
Replacement Recommendation for Older Carseats Carseat Bases
Posted on Aug 17, 2014
SOURCE: maxi cosi car seat cabriofix
What seems to be a sewn-up loop, is actually easy to unattach, but the trick is not explained in the manual.
Where the end of the strap seems to be holding to the seat's plastic shell, the plastic is not completely connected, there is a break in the plastic. Just move the strap left/right a bit and you will see that you can unattach it there. Then you can unthread the loose end of the strap and completely remove the cover.
Credits for this go to my wife who figured it out after I already thought we should return the seat to the shop. :p
Posted on Jun 07, 2008
  • 48 Answers
SOURCE: Finding a replacement cover for MAXI COSI PRIORI XP/FIX CAR SEAT
no but you can try this ebay store they sell covers
http://stores.ebay.com/safe-your-kid
or contact the manufacture with model number and date of manufacture they can get you one. this would be the cheaper of two options
Posted on Aug 20, 2008
SOURCE: maxi cosi belt protectors
The supplier to John Lewis, Dorel, will ship the maxi cosi loose belt protectors out to you at a cost of £10.
Contact Dorel at:
http://www.dorel.co.uk/contact-us/
Alternatively, call your local John lewis branch and they will be more than happy to contact their suppliers for you.
I called mothercare, and they were not too helpful - the fobbed me off and said call halfords or John Lewis.
Posted on Jan 30, 2009
SOURCE: Where to get a maxi cosi sun canopy from?
hi if the car seat you have is the cabriofix it already has sun shade, if you look on the back there is a button under the rim at the top ( on mine the button is silver ) hope this is helpful
Posted on Apr 20, 2009
greenspan
  • 1734 Answers
SOURCE: lost instructions for use manual maxi-cosi cabrio infant seat
Ask here, they can get you most Maxi Cosi manuals.
Posted on Jun 27, 2009
Cannot adjust position
Hi
Grip the carseat on the underside of the front lip, push the button in and lift the front to recline / push down to put in a more upright position.
Feb 11, 2014 | Maxi-Cosi Maxi Cosi Tobi MAGIC ROSE 2008...
Hi, i cannot get my maxi cosi to recline. can you offer any help with ideas?
Hi Lorna - Most commonly this issue is caused by dirt/debris getting caught in the tensioning strap of the harness and gradually pulled into the mechanism of the carseat over time. First recommendation is to remove carseat from the car and remove cover (do not remove harness system from seat) give the carseat fabric and the seat itself a clean and see whether this improves the recline situation. If not, please contact your customer services department - if you're in the UK this is 01284 413 141 Mon-Fri 8.30-4.30
Aug 11, 2011 | Maxi-Cosi Maxi Cosi Tobi MAGIC ROSE 2008...
I cannot get the seat to recline.
Good Morning
The Maxi Cosi CabrioFix carseat does not have a recline option.
Jul 23, 2011 | Maxi-Cosi CabrioFix (Black Reflection)...
Just bought a maxi cosi priorifix car seat and the handle for the recline is very loose and kind of flappy, however it does work (i.e. the seat moves and locks into the 4 positions) is this how it should...
Good Evening
"Loose and kind of flappy" is not how the recline handle on a PrioriFix carseat should be described - Please contact your retailer with your proof of purchase and ask them to compare it to others in store to check whether yours is different. If it is, they will be able to assist from there.
May 19, 2011 | Maxi-Cosi Priori
Pulled tensioner on maxi cosi tobi now i cant release it back
Just did it. It took two of us, but only a couple of minutes and no tools (except a table knife) once we'd worked out what the problem was. The reason the strap doesn't thread easily through the slot is that there is a sprung two-part mechanism that needs to be held open. One person threads the strap through while the other keeps the mechanism open.
Person 1:
1) Find the slot under the chair that the strap goes into - turn the seat upside down; it's a thin gap you can feel with your fingertip when you run your finger along the narrow back of the metal strip under the front of the seat (not the base).
2) Remove the metal rod that attaches the grey reclining lever. The rod is about 20 cm long and can be pushed out without tools. Removing this rod seems to make it easier to open the buckle mechanism. When replacing the rod later, you just have to line it up carefully with holes (we used a torch to help us see them)
3) Make sure the strap passes under the metal rod at the bottom of the seat back (you can see how here in a small photo here: http://www.englishforum.ch/attachments/sale-wanted/37565d1327058634-sale-maxi-cosi-tobi-car-seat-9mths-3-yrs-zh-maxi_cosi_tobu_small.jpg)
Person 2
4) Push back buckle as far as it will go (it goes back past vertical easily, then needs another firmer push,
5) Hold the buckle in this backwards position.
6) Insert a table knife (rounded and blunt, not sharp) into the space under the buckle and push back the sprung, hinged plastic part that the knife touches at the back.
7) Person 1 then threads the strap back through the slot, pushing until then end comes out.
8) Tie a knot in the end of the strap so you don't accidentally pull it through again!
9) Replace the metal rod in the reclining mechanism.
10) Done!
Mar 21, 2011 | Maxi-Cosi Maxi Cosi Tobi MAGIC ROSE 2008...
Can't take off maxi cosi carseat cover, because grey strap at the bottom doesn't come loose.
Slack off the straps as far as possible and recline the seat. Open the strap guard door on the rear of the bit of the seat that reclines (Item 3 on diagram http://www.maxi-cosi.com/media/producthandleidingen/maxicosi/PrioriFix.pdf). The shoulder straps can be released from the metal clasp which is in here.You can now pull the straps through the back of the seatand release the cover.
Oct 20, 2009 | Maxi-Cosi Priori
Lost strap clips?
Try contacting Maxi-cosi through their parent company http://www.dorel.co.uk/contact-us
Aug 11, 2009 | Maxi-Cosi Priori
Maxi cosi xr
You can download the user manual via the link on this page, just below the features listing:
http://www.babycare.nl/maxi-cosi-rodi-black-reflection-2009-p-964.html
Have a look page 3, illustration 10
Hope this helps,
babycare.nl
Erwin de Raad
Jun 03, 2009 | Maxi-Cosi Maxi Cosi Rodi XR 'Phantom'...
How to remove the car seat cover
contact the manufacture at
email Consumer Relations at consumer@maxicosi-us.com, or call Consumer Relations at (800) 951-4113.
they can help
Apr 26, 2008 | Maxi-Cosi Priori
Maxi-Cosi Priori Logo
89 people viewed this question
Top Maxi-Cosi Baby Gear Experts
ray gallant
Douglas Dinnebeil
Douglas Dinnebeil
Marc Cohen CPSTI
Are you a Maxi-Cosi Baby Gear Expert? Answer questions, earn points and help others
