Question about Hitachi EC12 Portable Electric 2hp Air Compressor, Oil Lubricated
Compressor attempts to run, trips overload
My compressor is almost brand new in hours however when I try to run it ,it makes a few revolutions, stops, and trips the built in overload switch. I do not use an extension cord so I don't believe voltage drop to be an issue.
  • kris112 Jun 15, 2009
    I have checked the oil and I believe it to be full however I am at work and I will re-check when I get home.
    President:
  • 1,185 Answers
Do you have the facility to top up the oil level on the compressor
If so you may find that the low oil sensor is kicking in and trying to prevent you from running the machine dry.
Posted on Jun 15, 2009
  • Tom
    Tom Jun 15, 2009
    Just had a thought
    Most comressors have a one way valve in the line leading from the motor to the receiver tank.
    This stops the pressure in the receiver tank from blowing back into the compressor motor when it is on full pressure and the motor is stopped by the pressure switch
    If that is sticking the compressor will be trying to pump air to the tank but will only be able to fill the short hose connection until the motor stalls.
    We had lots of problems with an Enotts valve that did exactly that
    Try disconnecting the supply hose and allow the motor to run free
Upright freezer trips circuit after moving across room
If compressor is hot, it could be an issue with the starting components. Let it cool down for about an hour an it is room temperature to the touch. If the breaker trips when the compressor attempts to start, I would look at the start components. It may be just a case of unusual timing that they went bad at this time. Make sure there is nothing else on the circuit you have it plugged into. Could be an overloading issue of the circuit.
Aug 04, 2017 | Refrigerators
Put on a new overload/relay with start capacitor, it failed in 6 hours
Compressor getting overheated, or the replaced part is of very low quality,go for branded parts.
Replacement parts can be purchased at any of the following web sites:
searspartsdirect.com
pcappliancerepair.com
appliancepartspros.com
repairclinic.com
partsselect.com
Before going to buy any parts directly.
Go through this troubleshooting help links.
This is list of refrigerator problems, which is normally faced in refrigerator.
You can go through the details, by clicking the link below:---
Refrigerator is not cooling properly?
http://technoanswers.blogspot.com/2011/06/refrigerator-is-not-cooling-properly.html
Both refrigerator and freezer not cooling properly in refrigerator?
http://technoanswers.blogspot.com/2011/06/both-refrigerator-and-freezer-not.html
The ice maker not working: ---
http://technoanswers.blogspot.com/2011/06/ice-maker-stopped-working.html
Compressor not running on refrigerator?
http://technoanswers.blogspot.com/2011/10/compressor-not-running-on-refrigerator.html
Water dispenser not working on refrigerator?
http://technoanswers.blogspot.com/2011/10/water-dispenser-not-working-on_19.html
Ice maker stopped making ice?
http://alltypesofpartsreplacing.blogspot.com/2011/10/ice-maker-stopped-making-ice.html
Water Overflows in Ice maker and freezes inside?
http://alltypesofpartsreplacing.blogspot.com/2011/10/water-overflows-in-ice-maker-and.html
How to replace Ice maker assembly?
http://alltypesofpartsreplacing.blogspot.com/2011/10/how-to-replace-ice-maker-assembly.html
These will help.
Thanks,.
Dec 22, 2012 | Maytag Refrigerators
Model ffu213caw1: my freezer stopped cooling recently.there is power to the uniti hear a small click down near the compressor like it is trying to start and then it stops.compressor is warm to the touch...
Compressor is bad the clicking noise is the Start Relay/Overload is kicking on and off. compressor is warm because it's trying to start but can't Frigidaire is known for bad compressors. I don't think the Start Relay/Overload is bad because the compressor gets warm.
May 20, 2010 | Frigidaire 21 cu. ft. / 595 liter Upright...
Stop working. stop running. where is the reset button? where is the overload?
It will be very diffilcult for even the most experienced technician to troubleshoot your refirgerator with so little information. No make and model number, no infor on how old it is...therefore start with the basics:
Verify it has power (does the interior light(s) come on?
If so, most refrigerators DO NOT have a reset button. The motor overloads reset when they cool off. If your unit has power and will not start after left alone (unplugged) for a few hours, then either the thermostat controls (most likely), a part of the thermostat controls (some controls use mutilple sensors and control relays), the overload on the compressor is bad or the compressor itself is bad. If the condenser fan runs but the compressor does not...I would suspect a problem with the compressor or it's electricals. If nothing starts except lights...I would suspect the temperature control. Good-luck.
Jan 09, 2010 | Refrigerators
Fridge has stopped working/getting cold
check the relay, the clicking noise is your overload tripping out on overload, the run winding of the compressor are not coming on line, if your relay is good, the ohm out your compressor.
Feb 20, 2009 | Refrigerators
Maytag msd2454gr
The click is not normal. The compressor is not starting and is tripping the overload. There is a chance the start relay on the compressor is shorted, but most likely the compressor will have to be replaced.
Unplug it for several hours until the compressor cools down and then try it again, if it starts up ok when it is cool the compressor is the problem for sure.
If it is less than 5 yrs old the compressor is still covered by warranty and will be replaced free of charge.
Dec 07, 2007 | Maytag MSD2456G Side by Side Refrigerator
Compressor help
If the compressor is real hot, caused by lack of cooling air and the thermal overload is what's tripping try letting it sit for several hours to cool and try again (clean the front lower coils for proper air flow). If that's not it then you likely have a "start device" failure. The kit comes with the overload and starter. Usually this is the problem BUT if you have a "Tecumseh" brand compressor you're toast. Take the back panel off the fridge and look at the compressor, if you have a little sticker on it with an blue indian head... the compressor is locked up (and even a new one is just as junk as this one). But if you have another brand the little white box on the left could be the problem. Unplug the fridge, unplug the little box (starter) and shake it to see if you hear any rattling or if debris falls out... a sure sign the device is bad.
Dec 29, 2006 | Kenmore 73902 / 73904 / 7390 / 673909 Top...
Hitachi EC12 Portable Electric 2hp Air Compressor, Oil Lubricated Logo
674 people viewed this question
Top Hitachi Air Tools & Compressors Experts
John Trevino
Jim Thurston
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Hitachi Air Tool and Compressor Expert? Answer questions, earn points and help others
