Question about Whirlpool MH7135XE Microwave Oven
Door I need to replace the door on whirlpool mh7130xez-1
  • 100 Answers
The door part# is 4359542 if you need the part number. If you need to know how to replace the door check up by the upper hinge on the inside of the door should be a plastic piece that you can remove so if you lift the door off of its hinges. You may or may not need to remove the grill above the door to raise the door high enough
Posted on Nov 02, 2007
Where is the reset button on a whirlpool microwave #MH7130XEZ-2
Hello Art. If you want to reset your Microwave, we would recommend resetting it by shutting it off from the circuit breaker for at least a minute.
May 08, 2017 | Whirlpool Microwave Ovens
Whirlpool accubake system E1 - F5 error code
1. If door latched:
  1. Disconnect power from unit.
  2. Check wires and connectors from control to door switch, then from door switch to control. If no damage to wires and all connectors okay, proceed to step 3.
  3. Replace door switch.
  4. Re-apply power.
  5. Press and hold any key down for 1 minute to clear F5 failure code from memory. F2 will appear. Press CANCEL and observe for 1 minute to ensure operation is correct.
You can usually find helpful exploded view diagrams and order parts by entering your full model number with suffix from the tag here.
Dec 10, 2012 | Whirlpool Microwave Ovens
Model MH7130xez won't heat. everything else works. the clock, timer and lights. does this model have a fuse?
if unit won't heat, then there is a problem with either the magnetron or the diode. if its the magnetron, the microwave will sound almost normal. if its the diode, it will make a humming sound
Mar 26, 2011 | Whirlpool MH7135XE Microwave Oven
I need a circuit board for a MH7130XEZ-1
The printed circuit board (PCB) was part number 4359413 then was superseded by part number 8172053.
It looks like it may be no longer available or at least not through usual sources, but sites like and show they can provide it for about $172 to $195.
But depending on the problem, we may be able to repair it with our $39.95 repair service. We repair hundreds on microwave control boards every year.
And we've repaired these.
Jul 02, 2010 | GE JES1289SK Microwave Oven
My microwave stays on while door is open--my right eye has been giving me problems, I am worried about the waves causing me to have flinching eye--it is the right eye that faces the oven whiled it is open...
That is impossible. The doors have at least three microswitch mechanisms to stop the magnetron emitting microwaves when the door is open. When the door is open, just the fan and the light comes on. Microwaves are only emitted when the door is locked, the Cook button is depressed and the turntable rotates.
Your eye twitch is coincidental. Microwaves to the eye cause glaucoma, the surface of the eye becomes cooked and opaque, so you become blind. Also microwave energy feel like prickly pins and needles and HOT. As I said impossible.
No recalls
Dec 05, 2017 | Whirlpool MH7135XE Microwave Oven
Have a whirlpool mh7130xez over range micorwave, everything works great but the suface light? beeps when i push the button? tried 3 new bulbs---please help
The relay for the lights is not working. No board level repairs. You will have to replace the control board to get this feature back.
Sep 01, 2009 | Microwave Ovens
Does not heat food
It could be 3 problems. 1. the part that spits out the microwaves needs replacement, door hinge switch is broken, or circuit board need replacement. First check with Whirlpool and see if it is under warranty still. Call a repair man. See .
Mar 20, 2009 | Whirlpool MH1150XMQ Microwave Oven
Service to Whirlppol MH7130xez-1, circuit breaker popped then unit went dead
water may have leaked inside unit causing a short.the transformer output is about 1400 volts that feeds a large capacitor. a direct short can blow the transformer instantly or any support parts without time to burn something. creating little or no smell. I never sujest that a person
to try to repair a microwave oven because
the capacitor can still be charged and very lethal.
Feb 25, 2008 | Whirlpool MH7135XE Microwave Oven
Whirlpool mh7130xez-1
When you open the microwave door, on the inside of the door there is a plastic trim around the glass called a choke that is clipped in that needs to be removed to get to the screws for your handle
Oct 29, 2007 | Whirlpool MH7135XE Microwave Oven
Whirlpool Microwave Model MH7130XEZ-2
Generally, the most common causes of a failure to heat are:
- bad door switches or door switch mounts
- loose connection at the magnetron
- problem or loose conneciton on the control unit circuit board
- bad magnetron or other high voltage part
At our site, we have critical safety information, info on door switch diagnosis and replacement, and disassembly information.
See our listing here on FixYa:
Oct 14, 2007 | Whirlpool MH7135XE Microwave Oven
Whirlpool MH7135XE Microwave Oven Logo
104 people viewed this question
Top Whirlpool Microwave Ovens Experts
William Miller
William Miller
Are you a Whirlpool Microwave Oven Expert? Answer questions, earn points and help others
