Question about Mitsubishi MXZ-2B20NA MSZ-GE09NA MSZ-GE09NA Mr Slim 16 SEER Heat Pump
MSZ-GE09NA top light is blinking on and off and not cooling or heating
What does it mean when MSZ-GE09NA top light is blinking on and off? It works for about 2 minutes, then starts blinking. Have tried turning power off/waiting/ then power on the unit. Other inside unit works fine on same (heatpump) compressor.
5 Suggested Answers
Therinnaiguy
  • 1420 Answers
SOURCE: no cooling after power out, indicator lights pattern not in manual
The Mitsubishi units have to be reset by turning off the indoor units by switching the remote or thermostat to off. Then turn off the breaker to the outside unit(s). After 30 seconds,turn on the breaker and then you can turn on the remote for cool. If no lights come on on the inside units, most likely you have blown a fuse soldered on the main PC board. At this point, call your technician. A goos tech will be able to wire in an in-line fuse holder so if it should happen again, you can easily replace the fuse. If you do see a light or two come on at the indoor unit but the outdoor unit does not start after 3 or 4 minutes, sounds like you will need to call a technician. Most likely you have a blown fuse on the main PC board of the outside unit. It is not an easy one to replace. Good Luck!
Posted on Sep 04, 2007
SOURCE: Inside unit runs left light blinks compressor will not start
In your out door unit you will have a dual capacitor. One side will be used to help start the outdoor fan and the other side is used to start the compressor. I have a fluke 187 volt ohm meter and can read uF. You probably have a bad capacitor. Its easy to change and by far the cheapest thing to do before calling a tech. It is out side where the electrical enters the outdoor unit. Be sure to kill all power to the outdoor unit and ground the capacitor before you remove and test. This has been the summer of capacitors here in SW Missouri. I have replaced several in the area.
Posted on Aug 15, 2009
heatman101
  • 43501 Answers
SOURCE: mr. slim MSZ-GE15NA indoor unit
There is either a problem with the outdoor unit fan or compressor or there is a communication problem between the two....
Did you check the number of blinks and then check the book to see what it means??...
Mitsubishi Air Conditioner Troubleshooting and Repair
heatman101
Posted on Dec 29, 2010
hvac1960
  • 2133 Answers
SOURCE: Hey, i have a MSZ-GA80VA
Is there some error code.? Without knowing error code, chances for yor your problem is:
If indoor working properly, there is communication problem between indoor and out door. Check for power in out door after 3 minutes of a/c switched on. If no power problem with your PCB. Replace it.
Posted on Jan 19, 2011
What does a orange not blinking indcator light mean?
For your TV the power light will be red when the TV is turned off using the power button on the top of the TV. Press the power button on top of the TV if that does not work then try turning the power off at the power switch on the bottom of the TV then turn it back on after a minute ior so and see if you can turn it on using the power button.
Aug 05, 2014 | Protron PLTV-37 37 in. LCD Television
I have Mr. Slim MSZ-GE09NA-8. I have four of these units in different rooms. All but one if functioning properly. The malfunctioning unit is in my office; it will turn on and run for about 45 seconds, then...
try running the unit in the fan only mode. if problem persist this will insure it's an indoor problem. also turn all 3 other systems off and only running problem unit. narrowing down is key
If you need further help, reach me via phone at https://www.6ya.com/expert/thomas_092728000e6acb79
Oct 28, 2017 | Mitsubishi Heating & Cooling
I have a Mitsubishi Mr. Slim MSZ-GE09NA that makes a popping noises when it starts to run. What would cause this to happen?
Have you done the annual maintnance on this unit? i suspect this is a high effiency gas furnace. The poping noise might be due to a dried out drain out tube from drying out . Is it like a gurgling? Checdk your venting if its clear, no birds, nest or rodents.Make sure all panel ,for blower are all tight, there are safety switches that would allow you to hear noises if any problem exists. Or/and, maybe air filters are dirty, and duck work or plenums or poping due to blocked ducts,Since this has just begun after being off all summer, i would check all the aboveIts has to be somethng relatively simple
Nov 11, 2011 | Heating & Cooling
When I attempt to turn on the TV the green power light will stay on for about 2 seconds. Did system reset with paperclip, timer light flashed for 1 minute. Tried again with same result.
STANDARD ANSWER FOR THIS PROBLEM:
MOST OF THESE SETS HAVE A SELF DIAGNOSTIC:
UNPLUG TV AND THEN PLUG BACK IN---TURN ON---GREEN POWER LIGHT COMES ONFOR A MOMENT AND GOES OFF.
PRESS AND HOLD "device" and "menu"buttons on front of tv for at least 5 seconds and then release both together.
Watch for power light to blink in a sequence:
1 blink-then 2 blinks-------no error
2 blink-then 1 blink-------X-ray protection
2 blink-then 2 blink-------SHORT PROTECTION*******
2 blink-then 3 blink---------deflection circuit problem
2 blink-then 4 blink---------vertical circuit problem
******2, then 2 is most common---usually means one of the fuses that protectthe Convergence IC or IC's is blown---set will detect no voltage to convergenceIC and shut down.
SET WILL REPEAT BLINK ERROR CODE UP TO 5 TIMES ANDTHEN TO GET IT TO REPEAT MORE YOUHAVE TO UNPLUG SET AND TRY TO TURN ON AGAIN.
IF IT IS 2 AND THEN 2---USUALLY
CONVERGENCE CIRCUIT PROBLEM
let me know what you find--hope that you find 2 blinks, a pause and twoblinks--this is the most common and easiest to fix.
BEFORE YOU RATE THIS INFORMATION LET ME KNOW WHAT YOU FIND, i AM HERE TOP HELP.
SD TECH
Jul 15, 2011 | Mitsubishi WS-55511 55" Rear Projection...
Misubishi split a c 2 tons green light blinking problems
Please write how many times blinking and with an interval. Depends upon it, we can give solution.
Normally, blinking 5 times means for drain motor malfunctioning. Check drainline, oif blocked clean it. If drain motor not working, replace it.
If blinking 2 times, Indoor room air thermistor defective replace.
Thanks.
Feb 18, 2011 | Mitsubishi MSZ-A15NA Split System Air...
Hey, i have a MSZ-GA80VA and the head unit starts for a few minutes and then stops with the left light blinking. i also noticed that the outside unit does not kick in. Daniel
Jan 18, 2011 | Mitsubishi Heating & Cooling
Aircon runs for a few minutes then shuts down and timer light flashes
when we start the AC indoor working and out door unit compressor working but fan motor not working and indoor timer light blinking
Dec 16, 2010 | Mitsubishi MSZ-A24NA Split System Air...
Nokia monitor doesn't work
Have you tried another monitor connected to the same computer? A blinking light usually means it's receiving no signal from the PC.
Aug 23, 2007 | Nokia 445 Pro 21" CRT Monitor
Mitsubishi MXZ-2B20NA MSZ-GE09NA MSZ-GE09NA Mr Slim 16 SEER Heat Pump Logo
443 people viewed this question
Top Mitsubishi Electronics - Others Experts
Are you a Mitsubishi Electronics - Other Expert? Answer questions, earn points and help others
