Question about RCA RTD258 System
Need to reset back to factory settings - RCA RTD258 System
  • 93 Answers
You need to go to the Manufacturer's website. There should be a designated area for trouble shooting, or product info. If not look for "Contact us" and go there. Write or call the number listed.
Posted on Jun 15, 2009
I lost my romote to my roku and it got reset. how do i set it up again without the remote
Hello
Reset Roku without Remote:
Soft Reset
From Menus (Newer Models - 4, Premier, & Ultra)
1. From the Home screen, select "Settings" > "System" > "Power" > "System restart".
Using Button (Older Models)
1. Find the "Reset" button on the back or bottom of the device. Some models will require a paper-clip to press the button.
2. Press the button, then release after about one second. The device should reset successfully.
Power Pull If none of the above soft reset options work for you, you may need to disconnect the power cord for about 20 seconds, then plugging it back in.
Hard Reset
A hard reset will clear all settings from the device and reset it to factory defaults.
Via Menu (Newer Models - 4, Premier, & Ultra) If a soft reset doesn't fix your problem, a hard reset may be your only option. This will clear all data off the Roku and reset it to factory default settings.
From the Home screen, select the following depending on your device:
1. "Settings" > "System" > "Advanced system settings" > "Factory reset".
2. "Settings" > "Factory reset" > "Factory reset" > "Yes".
1. Remove all cables except the Power cord.
2. Press and hold the "Reset" button on the back or bottom of the device for about 20 seconds. Some models will require a paper clip to press the button.
3. Continue to hold the "Reset" button, then remove the Power cord from the back of the unit.
4. Release the "Reset" button, then plug all of the cords back into the device.
The Roku should factory reset, then walk you through the setup process again.
For any help Visit us: www Support Roku Com
Mar 21, 2018 | Roku Televison & Video
I factory reset my Wii and need my data back!
It's gone unless you backed it up before! That's what a Factory Reset does :>(
Have a read
Restore Wii U save data backup after factory reset ' IGN Boards ...
www.ign.com > Boards > Gaming > Nintendo Lobby
  1. Cached
  2. Similar
Sep 12, 2016 - Title says it all. I want to know if it's possible to restore the save data on my Wii U from an external hard drive after factory resting it. I know that I can't transfer save data between systems via an external hard drive, but couldn't find anything on restoring save data back to the same system after a factory reset. Does restoring your Wii to factory settings lose all of your Wii ... 19 Dec 2014 Used Wii U Question! 12 Dec 2013 Im trading in my wii. How do i wipe all my personal data off it ... 14 May 2008 More results from www.ign.com
Resetting a Wii to factory settings - Arqade
https://gaming.stackexchange.com/questions/.../resetting-a-wii...factory-settings/19722...
  1. Cached
  2. Similar
Dec 20, 2014 - Remember, the answer is based on this official guideline by Nintendo. Basically, you go to the third page of settings of your Wii and then select 'Format Wii System Memory'. Then press 'Format' and TA-DA! Warm note: after you reset it all the data will POOF gone.
Reseting Your Wii To Factory Settings - YouTube
z? 3:48 https://www.youtube.com/watch?v=vmqzbdecV9c
  1. Similar
Jan 4, 2011 - Uploaded by GSCommander This is a video of me formatting my Wii to it's factory settings which is erasing all of its data. Some people ...
How to Restore Save Data ' Nintendo Support - Nintendo Switch
en-americas-support.nintendo.com/app/answers/detail/a.../how-to-restore-save-data
  1. Cached
  2. Similar
If you have backed up save data from a New Nintendo 3DS XL using a PC, then simply copy your folders back to the system using a PC. Please ... From the HOME Menu, tap "System Settings," and then "Open." Tap "Data Management." Tap "Nintendo 3DS," and then tap "Save-Data Backup." Image; Tap "Restore." Image ...
Jan 04, 2018 | We Video Game Consoles & Games
My computer will not connect to my wndr3800 router but my computer will connect to my neighbors router
The first thing that you need to do is to reset the router. The reason why you need to reset the router because that will help you to fix the problem and to know the main problem/issue.
Steps
To perform a factory reset:
  1. On the back of your router, locate the Restore Factory Settings or Reset button.
  2. Using a paper clip or similar object, press and hold the Restore Factory Settings or Reset button for about seven seconds.
  3. Release the Restore Factory Settings or Reset button and wait for your router to reboot.
    After your router is finished with the factory reset, the Power light stops blinking and lights solid green.
    Note: The Power light on newer router models lights solid white.
    The factory default settings are restored.
  4. or you can visit youtube for the video https://www.youtube.com/watch?v=nUOcjDy02ts.
Note: Once you reset the router it will be back to factory default settings and you need to setup the internet connection settings on to your router
Once your done with the hard reset try connect your computer and if your computer will have the same issue connecting to the router it only means that the problem is on your computer / try to connect other device first before you reset the router
Feb 05, 2017 | Computers & Internet
Kobo frozen. Willl not respond to touching button
Performing a basic reset A basic reset will force your eReader to restart properly. In many cases, this is enough to restore your eReader to normal.
  1. If possible, turn off your eReader.
  2. Locate the small hole on the bottom of your eReader.
  3. Unfold a paperclip and slide an end into the hole.
  4. Press gently until you feel a click. Your eReader should restart.
Performing a factory reset If a basic reset doesn't work, you can perform a factory reset to restore your eReader to its original settings. After a factory reset, you'll have to set up and sync your eReader again.
If you perform a factory reset on your eReader, you'll:
  • Remove all books from your eReader. Any books you purchased from Kobo can be re-downloaded from the Kobo Cloud after a factory reset.
  • Lose any bookmarks and annotations you made in your books since you last synced your eReader.
  • Sign out of your account on your eReader.
  • Reset all of your settings and preferences.
  • Return your eReader to its original settings.
  1. If possible, back up any books or documents that you added to your eReader using Adobe Digital Editions, or that you manually added using your computer. You do not need to back up any books you bought from Kobo. Any books you purchased from Kobo can be re-downloaded from the Kobo Cloud after a factory reset.
  2. Go to your Home screen.
  3. Tap the ios-menu.svg Menu icon at the top of the screen.
    The Quick Settings panel will appear.
  4. Tap Settings.
  5. Tap Device information.
  6. Tap Factory Reset under Advanced.
  7. Performing a factory reset If a basic reset doesn't work, you can perform a factory reset to restore your eReader to its original settings. After a factory reset, you'll have to set up and sync your eReader again.
    4. Tap Settings.
kobo com help Resetting your Kobo Glo HD
Jun 30, 2016 | Kobo eReader
Router name was reset without my asking. i need to set it back.
how was the name reset and by who??????
if you mean you have to reset your router to the factory default settings
(note all settings will be lost you will need to reconfigure the router)
you will need to reset the device to factory defaults. However, once the device is reset to factory defaults, depending on your router) to reconfigure your router settings or if there is a small hole in the front or back of the router push a hair pin in to reset to factory settings
Jun 26, 2011 | Computers & Internet
My wireless router number is WRT120N but I dont remember my pin number how can I can a new one
You need to reset your router to factory setting.
The reset process will restore your router's factory default settings. All of the customized settings of the router will then be erased and the router's IP address will be reverted back to 192.168.1.1 if you have changed it.
To perform a hardware reset on your Linksys router, follow these steps:
Resetting the Router Using the Reset Button
IMPORTANT: Before proceeding with the reset, take note of your router's current settings. You might need to check with your Internet Service Provider to get settings.
Press and hold the Reset button at the back of the router for ten seconds. It will reset your router to factory settings.
Apr 11, 2011 | Linksys Wireless-G WRT54G Router
Need password to my netgear router n 300
what is the model #?
Most netgear routers default to a username of "admin" and password is either " admin ", "password" or it is just blank. Those are the defaults unless someone changed it.
If you cant get in you can hold down the reset button on the back for 30 seconds (while it is plugged into power) and that will set it back to factory default settings then one of the above should work.
If this was a help please give me 4 thumbs up as I am trying to build up my rep on this site!
Mar 02, 2011 | Computers & Internet
I need the reset code to preform a factory reset
soft resetting :
-Back to factory settings: This should maintain your data (contacts/messages/calendar/notes etc), just returning your N97 back to all previous settings
From menu:
Settings> Phone>Phone Management>Factory Settings
hard resetting:
The traditional method won't work as the N97 doesn't have the old keypad. After you've backed up your data onto memory card/pc/ovi, turn your phone off and simultaneously press these four buttons circled in red.
  • Caps shift
  • Space bar
  • Delete button
  • On button
You'll know it's worked when you see the initial set up screen, asking country of origin.
Nov 08, 2010 | Nokia N97 Cell Phone
Reset to factory specs for blackberry curve 8330
how to reset the Curve back to factory state (a complete wipe-out). Please note if you just want to reboot the device, you only need to take out the battery.
To reset the phone back to factory state:
Go to Options -> Security Options -> General Settings
Press the BlackBerry Menu key and select "Wipe Handheld" and type in "blackberry"
Thanks.
Jun 04, 2009 | RIM BlackBerry? Curve 8330 Cellular Phone
How do i reset blackberry curve 8330 to factory settings
Dec 28, 2008 | RIM BlackBerry? Curve 8330 Cellular Phone
RCA RTD258 System Logo
469 people viewed this question
Top RCA Audio Players & Recorders Experts
Gyula Lacz
Are you a RCA Audio Player and Recorder Expert? Answer questions, earn points and help others
