Question about Canon PIXMA MP970 InkJet Printer
While trying print my documents the black just stopped working and the cartridges are new what can I do? it worked yesterday but not today.
  • 6 Answers
SOURCE: Use of black ink
My husband answered this for me- it takes different colors to make black, therefore it uses some of the color ink
Posted on Jan 31, 2007
jtra
  • 8 Answers
SOURCE: black not printing
I just ran into a similar issue with my MP390. Actually both the color and black inks were not printing very well. I would get very inconsistent printing. Fixed the problem very easily and quickly as follows: On the top of each print cartridge, there is a small hole. Remove the print head (lift the gray bar at the front of the print head and lift out the print head) with the cartridges still in place. Holding the print head over a piece of paper/paper towel, blow into the holes on the top of the cartridges (either directly or using a straw/tube of some kind). You should get ink coming out of the botton of the print head, both color and black. Replace and print head and test print.
Posted on Jun 08, 2007
Joed911
  • 4338 Answers
SOURCE: new cartridge won't print
  1. Make sure you removed the tape from the ink cartridge.
  2. Press the <Menu> button on the printers operation panel.
  3. Press the left [<] or right [>] arrow buttons to select [MAINTENANCE].
  4. Press the <Set> button.
  5. Press [<] or [>] to select the cleaning setting you want. Select [HEAD CLEANING] for normal print head cleaning. Select [HEAD REFRESHING] for deep print head cleaning.
    Note: [HEAD REFRESHING] uses more ink than [HEAD CLEANING], so perform [HEAD REFRESHING] only when necessary.
  6. Press <Set>.
  7. Print a Nozzle Check Pattern and perform at least two Head Refreshing if the pattern is not correct.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Posted on Nov 26, 2008
SOURCE: won't print with just black ink cartridge
A part solution is print/properties/maintenance/ink cartridge settings/select black only.
You do initially have to buy another color cartridge but you won'thave to buy another expensive color cartridge again in the future.
I
Posted on Jan 12, 2009
  • 164 Answers
SOURCE: Coloured printer with black not printing?
Breath and Relax... this should resolve your problem.
Routine maintenance and keeping full ink tanks will prevent this problem, however if you have the problem you can resolve it by doing the following:
1. Clean your ip3000 print head using denatured alcohol solvent which can be purchased from most hardware stores. If unavailable, use 91% Alcohol (isopropyl alcohol (first aid antiseptic) which is available for less than a dollar at most Walmart pharmacy departments.
*Warning: You may want to use a pair of latex exam gloves as this is a messy process and can stain your fingers.
Supplies needed:
Isopropyl Alcohol or denatured alcohol
paper towels
latex gloves
sink, bowls and or basin
can of compressed air
very small screw driver
tablespoon or baby bulb type syringe
warm water
Time necessary 45-50 minutes
1. Lift print head from printer. It pulls out easily because it is held in with the same down lever that holds the cartridge in place.
2. Put two layers of paper towels in the bottom of a dish to protect sensitive sprayer heads.
3.Put enough solvent in dish to cover the screens on which the cartridges sit when in use.
4. Take the two small screws out that hold the white ceramic piece
5. Gently, pry the ceramic piece back and away , to reveal the underside (No need to pull away the glued points on the sides.)
6. Gently, move head up and down to slosh solvent around it the best as you can. Use a table spoon or syringe to pour solvent over all orifices in the print head, turning it upside down and then back a few times.
7. Use canned air with a plastic straw to blow into and through all orifices, alternately sloshing/swishing and pouring solvent over head (be careful not to touch any of the holes, screens, or sprayer heads with anything)
8. Empty dirty solvent from bowl and replace with paper towels and clean solvent. Soak for approx 10 minutes. Rinse again with clean solvent poured directly on all parts, letting solvent overrun and fall into dish or basin.
9. Gently shake the solvent off the head, take it outside and spray with compressed air into all orifices to clear out and help evaporate any remaining solvent. Let sit on a clean paper towel for approx 20 minutes. (There may be a little ink bleeding out of the head, but once it dries completely it does not present any problems.
10. Reinstall head, cartridges and it will print like a new printer.
SUGGESTION: For many years of problem free printing, keep a double set of ink cartridges, one set full at all times. Whenever a cartridge runs out of ink, replace it IMMEDIATELY, with a new one or a refilled one. This gives the print head no chance to dry out and create clogged heads. Routine maintenance of cleaning the heads every 24 months does wonders for keeping your ip3000 in new condition.
Happy Printing .
Posted on Feb 07, 2010
How do I get my Lexmark X2600 to print? I got a message telling me that I would soon have to replace the black ink cartridge, and it just stopped printing. I put a new cartridge in, and it still will not...
Try to re-seat the cartridges into the printer. Remove both cartridges from the printer > re-brick your printer. Pull out the power supply, black box where the power cord is plugged in at the back of the printer, and put it back after 30 seconds > when the printer printer turns on, firmly re-insert the cartridges into the printer. Try to print a document again to verify that the problem is fixed.
You can also try to manually clean the cartridge nozzles. Wipe the cartridge print nozzles with a slightly moistened soft cloth to clean it from possible dirt and clogs. Re-insert the cartridges and try to print a document again.
Oct 23, 2011 | Lexmark X2600 All-In-One InkJet Printer
I changed my black ink cartridge and my canon i 70 stopped printing. my computer gives me an error saying there was an error and my document could not be printed. the indicator light is green and then it...
Hi Good day!! did you try to print other documents? if yes try to restart your print spooler Click Start- Setting- Control panel- administrative tools- services now you should be on services box find the "Print spooler" click Print spooler and then restart it by click stop and then start
reply to me for further assistant if my solution did not work thanks
Thank you for using FixYa
Nov 09, 2010 | Canon BubbleJet i70 InkJet Photo Printer
My MFC665CW will not print in black. It does
The printheads go bad on these, when several cleanings don't help, you need a new printhead. the price is more than a new machine since they sell the new mfc490 for about $120.00 and the printhead alone to repair yours is $179.00 from Brother...
Oct 02, 2009 | Office Equipment & Supplies
Black ink cartridge changed on my canon i9950 but it won't print
Your printer will need either a new printhead, or possibly a purge assembly that cleans the printhead. Best to have a shop check it out so
you don't buy a part you don't need. If it can't clean then even a new printhead won't help.
Jun 22, 2009 | Canon i9950 InkJet Printer
I have a Lexmark X1150 printer that is printing purple only.
Try the "better" or "best" print options - They give more ink - might do the trick - (beware it also prints a lot more slowly....)
I have not had that type of problem as such as both my ink slots work, but I did have purple/bluish print instead of black once - It worked for me -
Hope that helps -
I have also found that despite cartridges being new somethimes they are not as full as they should....
May 03, 2009 | Lexmark X1150 All-In-One InkJet Printer
Color Document not Printing in color
yes your printer can print in black if you don't have black ink in the catrige but don't remove the catrige in the printer but it we print in deep arsh not as black.
Nov 13, 2008 | HP OfficeJet 6110 All-In-One InkJet...
Hp officejet 6110 not printing with black ink
Hi lilacky-
Here are some HP support links that might be helpful... and a couple questions to consider.
Q: Is your new cartridge one of these listed below?
"The HP Officejet 6100 series and HP Digital Copier Printer 410 products use the print cartridges listed below:
* HP 56 black print cartridge
* HP 57 tri-color print cartridge
* HP 58 photo cartridge (replaces the HP 56 black print cartridge for six-ink photo printing)" info from: Installing a Print Cartridge
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00004340&lc=en&dlc=en&cc=us&lang=en&rule=12548&product=79477 Is your new cartridge a refilled cartridge? Some times those have special challenges. Has your cartridge been sitting a while in the box, maybe in a warm spot? Some times even new cartridges dry out a little. Was your old cartridge low or completely gone? Just as a test, if you put it back in your printer does the old cartridge work? Any printer error messages? Can you print a test page or an alignment page for your black cartridge? These might be too many questions but here are some HP support links with some How To information for getting more answers. Please let me know if any of these are helpful. see also: Slow or No Response from Printer
http://h10025.www1.hp.com/ewfrf/wc/documentSubCategory?rule=11882&lc=en&dlc=en&cc=us&lang=en&product=79477 -JW
Oct 03, 2008 | HP OfficeJet 6110 All-In-One InkJet...
Not printing after color cartridge ran out - new black cartridge installed.
Yes, this printer has fixed printheads and must have ink in each color to prevent damage to the printheads. Even when printing black only each color is spit in the servicing area to keep the printhead unclogged.
Regards,
Bob Headrick, Microsoft MVP Printing/Imaging
Jul 18, 2008 | Epson Stylus C60 InkJet Printer
Ip4200 stopped printing...help!
dear oceantracks maybe one of the black cartridge chip think that ink is running low or not ink is left in the cartrridge.
Nov 21, 2006 | Canon PIXMA iP4200 InkJet Photo Printer
Canon PIXMA MP970 InkJet Printer Logo
91 people viewed this question
old marine
old marine
