Question about Philips FWM399 CD Shelf System
Philips fwm200d cd just read no play no spin
Cd just read no play
I am not able to play a video dvd in my philips DVP1120 player. Each time i enter the disc it shows bad disc, I have tried many video dvd's but none of them is working,earlier they all were working...
In most cases when the CD does not play it is possible that the optical head is a suspect. Sometimes it might pick up ordinary audio CD but will not play other formats. This indicates that the optical head is weak and so there is no detection or scanning of the CD . If the optical is working the tracks will be read immediately but with no scanning the laser head can be defective.
The main motor will not work in some cases as unless the tracks are read the drive motor will not work with signal from the processor. Also in some cases the central motor base can shift and so the distance to the disc can be more resulting in low detection. You can pull up the spindle to come closer.
Sometimes certain cleaner disks will not be tracked to run for cleaning as it will not be read and so will reject. Hence it is ideal to manually clean the laser head eye using a cleaning swap /cotton bud with gentle pressure on the lens eye.
If there is no result then watch if the CD spins or tries to spin. If so the board seems to work unless a test is taken on the main board but the possibility of a defective optical head can be the suspected fault.
If any of the above seems otherwise we must recheck with possibilities of a malfunction of the main processor board
Jul 27, 2011 | Philips DVP1120/37x Player
When i put a dvd in you can hear the dish spin then it says to insert disk,when the disk is in there.
Apr 16, 2011 | Philips DCP750
Philips mc235B/37 CD player no longers plays CDs. I get a "No Disc" error or an "Error" message. CD's often don'teven spin. If they do, they spin slowly, then stop, and start spinning in reverse before...
if you can see the laser then gentaly with a soft cloth wipe the lens
and then try
if that doesnt work then i recoment that you call philips and see what they say because it is slightly older than one year they might replace it for free
if not call the shop that you bought it from
May 09, 2010 | Philips MC235 Shelf System
Philips CDR775 2-Disc CD Recorder tray won't read/open
this depends on what make of disc mostly the philips machines only work with their own brand of disc try placing an original disc if thats ok then its the blank cd that you are useing got to be philips brand
Mar 30, 2010 | Philips CDR775 2-Disc CD Recorder
MY MICRO MC235 WONT READ CD. I HAVE ONLY PLAYED ONE CD ON IT AND TODAY IT SPINS BUT STOPS AND I HAVE TRIED OTHER CDS BUT STILL THE SAME PROBLEM. I SEE OTHERS HAVE HAD THE SAME PROBLEM. WHAT CAN I DO. AND...
Is this new? Or still covered by the Philips? If it is you better not touch it. If not then I would clean the laser/lens with a cleaning product that you can get from electrical shops.
Dec 24, 2009 | Philips MC235 Shelf System
The problem is i cant play mp3 or DVD s in my philips dvd player when i insert sometimes it plays but sometimes it says LOAD but doesn't play.product code is philips dvd dvp3268
When the unit does not load any disk, that is usually because of a problem with the optical laser lens that is dirty, faulty or opaque, and will start operating on certain disks better than others.
In that case you will hear disk spinning, whirring and clicking, but the TOC (table of content track at start of CD/DVD will not be read, therefore the error.
Whe this problem is starting you may be able to read only CD, DVD or Blue ray, or for example only DVD-R and not +R , or only to read and not to write and so on. After more prolonged usage , often the unit goes losing the rest of functions, and ends up not reading anything at all.
If instead there is no noise, and disk does not spin at all , then there is a faulty motor, or the motor micro-switch is bad. This situation is far less common than the lens problem.
Try first using a CD/DVD or Blue ray lens cleaner disk to clean the lens. If that does not work you will need to disassemble the drive , and clean lens directly with q tips and isopropyl alcohol, or to replace the CD/DVD lens, or the whole drive unit.
Jul 21, 2009 | Philips DVD625 DVD Player
Technics sl-pg580A
this player uses a philips mechanism, spindle motor failure is very common on these mechanisms, yours may be on its way out. take the lid off and insert a cd and if you can hear the laser trying to read the cd without it spinning, it's definately the spindle motor.
Oct 07, 2008 | Technics SL-PG480A CD Player
TOC READ
I have the same problem... Any solutions?
Sep 21, 2008 | Emerson MS3100 3-Disc CD Changer
Philips FWM399 CD Shelf System Logo
Top Philips Audio Players & Recorders Experts
Gyula Lacz
Are you a Philips Audio Player and Recorder Expert? Answer questions, earn points and help others
