Question about Sony CDP-CX300 CD Player
Will not open does not turnmakesmload nose
When I turn it on it makes a loud noise the door will not open on its own the carasel does not turn
Very loud whining nose on front end ..
if it is a wheel bearing it should make more noise turning one way or the other,if it doesn't make a difference which way you turn it's not the wheel bearing
Jan 29, 2014 | 2004 Dodge Ram 1500
Loud, grinding noise from garage door opener
Remove the cover from the motor housing and check the drive gear.
Jul 09, 2012 | Sears Craftsman LiftMaster Chamberlain...
I hear a noise when i close the freezer door or when i push the light switch light in
how loud is this nose. most refrigerators are designed to stop the fan when the doors are open. and start again when the doors are closed. when u push the light switch in the fan thinks the doors are closed.
Feb 04, 2011 | Kenmore Refrigerators
Some fan making a loud noise. When open either
It sounds like it is probably your evaporator fan, seeing as that fan will cycle off when the door is open, and resume when you close the door. Either some how something got in to it, or it is going bad. Hope this helps
Oct 07, 2009 | Refrigerators
Freezer making a loud noise.
Sounds as if the evaporator fan has shaft play or the blades are out of balance or striking something. When you open the door the pressure is equal but with the door closed the fan needs to push the air through the evaporator and return again and circle through fan again. I think soon would be a good time to unplug the refrigerator and remove the back panel covering the evaporator and fan motor to inspect the fan, shaft play and the evaporator for frost buildup or any obstruction of air flow. Thanks, sea Breeze
Jun 17, 2009 | Samsung RS2630WW Side by Side Refrigerator
Making virbrating nose
believe it or not, most noises that start and end and start again are sometimes very easy to fix. next time you hear it open the refrigerator doorand see if your ears can pick up the sound. usually it is two bottles in the panel of the door vibrating against each other. if not thencheck your fans especially the condenser fan next to th compressor, something may be caught in the fan blade. unplug unit if you find noise and give the coils a good cleaning while you are down there anyway. let us knowhow you did
May 01, 2009 | Refrigerators
Very loud humming or whirling noise
it could be the motor starting to seize or the windings in the motor could be going bad either way it should be serviced
Jan 13, 2009 | Bosch 24 in. SHU66C02 / SHU66C06 Built-in...
FREEZER SOUNDS VERY NOISY
that because the internal fan is hiting the ice or has bad bushings you can hear the noise just with the door close because when you open the door there is a switch the one turns off the internal fan so when you close the door it turn on the fan again if you wants to hear that with the door open just open the door and push the botton swich with your fingers and you'll hear the noise
Dec 29, 2007 | Freezers
Sony CDP-CX300 CD Player Logo
67 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
