Question about Sony VAIO Computers & Internet
Contrast I can't adjust the brightness contrast in my screen. I've looked up the driver for this applicable model, but not achieved. I hope Fixya will help me getting a available driver. My laptop: Sony Vaio (VPCEH28FG)
    New Friend:
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
  • 61 Answers
Hi, you mean it doesn't give you any option to adjust? (adjustments options are disabled?). have locate under power option menu?
thanks
Posted on Apr 02, 2014
Benimur
  • 6966 Answers
SOURCE: Sony Vaio Display problem
Since the Sony Vaio VGN-CR220E works except that the display is dark, then it would be safe to assume that it is only the LCD display part that is the issue. Often LCD display (of laptops) are working but only that you can not see the actual display. One way to verify is to shine a flashlight at an oblique angle to the screen, semblance or part of the desktop could be seen s what you have done. If the desktop could be seen (albeit very very dark background) then it could either be the CCF Lamps (cold cathode florescent) or the inverter that powers the lamps.
Often, the defective component would be the inverter. It is relatively easy to replace the inverted. It is sometimes more difficult and challenging cracking open the casing of the display panel of the laptop than replacing the inverter. Additionally, inverters are readily available online. It is also not surprising that inverters for other brands/models would also be used in your Sony Vaio VGN-CR220E .
Of course another possibility is that there is just a loose connection or a cold solder in the LCD panel display's circuit boards.
This would be a good place to start for inverter boards. This is a nice tutorial if you are considering a DIY.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
Posted on May 08, 2008
  • 14 Answers
SOURCE: sony vaio vgn-nr160e with vista, function+ keys wont work
To enable the Fn keys functionality, you need to install the "Vaio Event Service" and "Sony Utility Series"
They are available to download as part of a package from the Sony website. Here is the link:
http://esupport.sony.com/US/perl/swu-download.pl?mdl=VGNNR160E&upd_id=3262&os_id=28
Regards,
Purito
Posted on Oct 20, 2009
  • 178 Answers
SOURCE: Sony Laptop Rechargeable Battery Driver Download
I have a SONY Vaio VGN-SZ18GP laptop ,they may use the same oem battery.Get more vgp bps2 battery information from the internet.
Posted on Aug 10, 2010
  • 16 Answers
SOURCE: Hi ! my lap top model
Install the latest Video Drivers from the dell website.
Posted on Aug 24, 2010
  • 207 Answers
SOURCE: contrast is way too bright,
Right click on your main screen. Go to properties, or graphic properties, then you will find there is a contrast adjustment within. Usually under color correction.
Posted on Mar 24, 2011
How to adjust contrast on dell 610
You can only adjust brightness. There is no contrast control.
Jan 17, 2014 | Dell Latitude D610 Laptop Computer -...
CONTRAST ADJUSTMENT
it is best to shut the color level to the lowest setting then try t balance the screens to achieve the best black and white picture. then turn up your color level. Your brightness level should also be set to 50 % then when you adjust for the best B&W picture. You will have better color and brightness when you reset your color and brightness levels.
I am further looking into ur problem..
Goodluck..
Feb 07, 2008 | Hitachi 57F500 57" Rear Projection...
Tip
Projection Screen Tip #3
In front-projection applications, control of ambient light near the projection screen surface will enhance the contrast and brightness of an image being projected. In order to achieve this, place the screen in an area where ambient lighting is low or controllable.
on Aug 16, 2010 | Office Equipment & Supplies
HOW TO SET BRIGHTNESS OF THE SCREEN?
Dear User...
You can adjust the brightness and contrast of your monitor to improve the readability of text and to make digital pictures appear more like they'll look when printed.
To improve the results when adjusting the brightness and contrast settings for your display, use Display Color Calibration. (Display Color Calibration helps you adjust these color settings and others.) For more information about calibrating your display color in Windows, see Calibrate your display.
The way you adjust brightness and contrast varies and depends on your specific display.
Brightness and contrast buttons on the front of the monitor. Some monitors have brightness and contrast controls on the front and use the standard symbols shown in the following image.
On-screen menu. You can change the brightness and contrast settings for some displays by using an on-screen menu, and then setting the brightness and contrast in the resulting menu. Many times, you can view the on-screen menu by pressing a button-possibly labeled Menu-on the front of the monitor.
Thanks....
Feb 07, 2013 | Computers & Internet
Unable to reduce brightness windows7 ultimate hp1670
laptop ot desktop monitor ?
Adjust your monitor's brightness and contrast
Brightness and contrast symbols
Laptop display. Laptop displays don't have brightness or contrast buttons on the front.
For a majority of laptops, there isn't a control for setting the contrast.
However, you can set the brightness of many laptops by pressing and holding the Fn key, and then pressing a function key to decrease brightness ( ) or increase brightness ( ).
http://windows.microsoft.com/en-US/windows7/Calibrate-your-display#
When using Display Color Calibration on a laptop, set the display to the maximum brightness setting.
Adjusting brightness automatically using adaptive brightness
Adaptive brightness is a feature in Windows that uses a light sensor to automatically adjust the display brightness to match the lighting conditions in your computer's surroundings.
To use adaptive brightness, you must have light sensors installed and enabled on your computer.
To determine if your laptop or computer monitor supports adaptive brightness, look for the Enable adaptive brightness setting in Power Options (mentioned in the following procedure) or check the information that came with your computer.
To turn adaptive brightness on or off
Open Power Options by clicking the Start button , clicking Control Panel, clicking System and Security, and then clicking Power Options.
Under any plan, click Change plan settings.
Click Change advanced power settings.
In the list, expand Display, and then expand Enable adaptive brightness.
To turn adaptive brightness on or off when your computer is running on battery power, click On battery, and then, in the list, click On or Off.
To turn adaptive brightness on or off when your computer is plugged into an outlet, click Plugged in, and then, in the list, click On or Off.
Click Apply. Click OK.
hope this helps
Jul 26, 2012 | HP...
My webcam is really dark wene im on to people and they cnt see me on msn
Hello
Typically theres an options section. Maybe an icon that looks like 2 gears, or just go under 'edit' on your program.Hopefully you can adjust the brightness and the contrast manually. make sure if you have a low-light boost its off or on, depending on lighting.
If it is still dark i suggest Uninstall the webcam drivers and applications and reinstall it. you adjust your laptop brightness settings as well
Apr 16, 2011 | Computers & Internet
I am a Toshiba satellite L450 p-18 user; I am using it with windows XP. And now I have had a trouble on how to adjust the contrast and brightness of my notebook screen!!!!!!!! That is how should I adjust...
Always get your drivers and specific software from the manufacturer of your Laptop, Notebook or Desktop.
If you were to log on to the www.toshiba.com web site, usually one is able to download if available, by model number, All available Driver downloads as required.
If the driver is not available, perhaps your manufacturer does not support the OS you are installing.
This is the best way of ensuring up to date drivers for your system and they are free of charge!
It sounds like a driver is missing, check online with toshiba and download the latest updates for your OS and machine.
I hope this helps.
Feb 25, 2011 | Toshiba Computers & Internet
Fine interference lines running diagonally across picture.
Hi There,
Sounds like your Horizontal Output Circuit is leaking current causing diagonal lines across the screen. I hope this will help and thank you for using FixYa!
Mar 29, 2009 | Sony FD Trinitron WEGA KV-36FS120 36" TV
Need help to adjust the colour, contrast and brightness on my CMV
install the monitor driver, you can down load the driver to your monitor manufacturer..
update the video card driver and install the video card application software...the video card application software have setting and configuration options
Mar 16, 2009 | E-Machines eMachines Monitor E15T4
We have an Acer Travelmate 4200 and the screen is too dark how do you brighten the screen??
Most laptops have a function key (F1-12) with a picture that looks like a sun. Press and hold the FN button and the appropriate Function key. You should get a "slider" to adjust the contrast and brightness..
Some laptops also come with a program to make other display adjustments. Look at the Control Panel to see if you have one of those on your list. If not, check the "Display" application on the Control Panel, and under "Settings" see if you can adjust contrast or brightness that way.
Jul 21, 2008 | Acer Computers & Internet
Computers & Internet Logo
94 people viewed this question
Top Sony Computers & Internet Experts
Alun Cox
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
