Question about LG DLE2516 Electric Dryer
Where is the back venting system at
Where the back venting system at
Clothes dryer temp gets to hot at times
The problem is either in the vent system or in the dryer. First check your vent system. If it is not in the vent, you will need to have a qualified person remove the back of the dryer and clean inside the back of the dryer.
Dec 18, 2017 | Dryers
2005 Ford Focus. Air is blowing out of the floor vents and defrost vents but not dash vents. Also the knob will not go onto the dash vent option it's like it just springs back up.
A failure has occurred in the HVAC system, legally, when a fault happens the hvac system will default to defrost/floor. Further diagnostics will be needed to determine issue.
Jun 05, 2015 | 2005 Ford Focus
Check dryer vent light comes on
check the back venting system and the front system still can be clogged by particals getting past the screen look inside the fornt system with screen out.
Apr 09, 2013 | LG DLE2516 Electric Dryer
I replaced evap vent solenoid & dtc came back
Here is the definition of the code and possible causes.
P0449 PONTIAC Description The Engine Control Module (ECM) monitors the Evaporative Emission System (EVAP) Vent Valve/Solenoid system wiring for opens or shorts.
When is the code detected?The Engine Control Module (ECM) has determined that a malfunction exists in the electrical circuit for the vent valve/solenoid in the evaporative emission control system.
Possible causes - Vacuum leaks, damaged hoses or improper routing
- EVAP system - Check fuel cap, canister, valves or components
- Faulty purge or vent solenoids
- Check connector and wiring
- Fuel saturated vapor canister
- Failed EVAP vent solenoid
Read more: http://engine-codes.com/p0449_pontiac.html#ixzz2M1YJd7DU
Feb 26, 2013 | 2002 Pontiac Grand Prix
PS3 turned off on its on, now won't turn back on
"When the power status light flashes red after using the PS3 system for 3 or more minutes and shuts off, the PS3 system has possibly over heated. This may be caused by poor ventilation or the vents may be blocked."
"If this happens:
• Check to see if the vents are blocked. If the vents are dusty, vacuum the vents to remove the dust.
• If the PS3 system is in an enclosed area like a bookshelf or entertainment center, move it to a more open area.
• Leave the PS3 system off for 30 minutes to let it cool down.
• If you continue to have issues, you will have to send the system in for service."
Hope this will help...
May 31, 2010 | Sony Playstation 3 (PS3) Console
Turns on then it turns right back off
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} "When the power status light flashes red after using the PS3 system for 3 or more minutes and shuts off, the PS3 system has possibly over heated. This may be caused by poor ventilation or the vents may be blocked."
"If this happens:
· Check to see if the vents are blocked. If the vents are dusty, vacuum the vents to remove the dust.
· If the PS3 system is in an enclosed area like a bookshelf or entertainment center, move it to a more open area.
· Leave the PS3 system off for 30 minutes to let it cool down.
· If you continue to have issues, you will have to send the system in for service."
May 26, 2010 | Sony Playstation 3 (PS3) Console
My dryer is saying to check filter but the fileter is clean, the vent hose in the back is clear and it is still not drying the clothes. The dryer is putting out heat, but the clothes are still wet after a...
There is a restriction in the dryer venting system. If the moisture is not removed from the dryer thru the moisture vent then the clothes will get hot but not dry. You will need to remove the vent hose at the back of the dryer and look inside the vent pipe and see if it is restricted with lint. You might need to reach up inside the vent with your hand and pull out the lint. Also some of the newer dryers have a fan assisted venting system and if the fan stops working that can cause this issue.
Dec 07, 2009 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
Nothing blows through front vents on any setting; back vents work fine
The motor that changes the vent settings is either bad or something has jammed up the system. Mice have been known to make nests in the vent system. Either way this is a job for a professional.
Oct 12, 2009 | 2005 Chrysler Town & Country
Internal air vent only working on upper screen
The cable from the vent control knob is probably broken or come off somewhere, you'll have to trace it from the back of the knob onwards.
Oct 10, 2009 | 1997 Ford Escort
Fan vents
Most microwave oven fan systems can be rotated for either back or top venting.. This can be done by removing a few screws and rotating the blower housing to the position you need and screwing it back in place.. Hope this helps..
Aug 30, 2008 | GE Microwave Ovens
LG DLE2516 Electric Dryer Logo
16 people viewed this question
Top LG Dryers Experts
Tim Whalen
Dan Webster
Dan Webster
Mike
Mike
Are you a LG Dryer Expert? Answer questions, earn points and help others
