Question about Kidde i12040 Hardwire Smoke Alarm with Hush Feature and Battery Backup
Left freezer door open all day,now its beeping
Left freezer open long time now frigerator is beeping
Fridge is constantly beeping at around about 2-3 second intervals and whenever I open the door the sound continues and the light inside flashes to the beeping sound.
most of the time the beep comes from the door being ajar i just finshed a chat with a gentlemen that because he had to much on his door he bent his hinges which caused a 1/8" gap in the seal of the door best thing to do is get some vaseline go over your entire seal if the seal is in good condition if its not replace the seal also check your upper hinge to make sure if it has an adjustment to move the door in closer if it doesnt then you would have to replace the hinge like the other gentleman i just finshed with has here is a complete schematic of your frigerator if you have any further questions message me back and if the door seal and hinged is ok message me back as well thanks again Rick
Jan 11, 2011 | Whirlpool GR2FHMXV Top Freezer...
GE profile freezer door pops open
If you close any refrig door " fast " , the other will pop open . These magnetic door gaskets , are designed for lighter holding power now , than they used to be , due to children getting caught inside . I would suggest lowering the front legs slightly , so that when you let go of the door , it will close slowly on its own .
Sep 29, 2009 | GE Profile PFS22 33" Artica French Door...
Fridge temp goes up and ice forms in fridge
CHECK THE BAFFLE IT MIGHT NO BE OPENING OR CLOSING PROPERLY, THAT`S THE SMALL DOOR LOCATED @ THE LEFT UPPER CORNER OF THE FRIGERATOR
Aug 19, 2009 | Samsung Refrigerators
Refrigerator freezer
If you open the door and push the door switch in and then hear the noise , then the problem is the evaporator fan motor .
Jul 11, 2009 | Refrigerators
Fridge/freezer beeping
There is a lever switch usually above the door (when door is in open position) on the fridge cabinet. Not on the actual door. The beeping should stop if this lever is pressed. If the door is positioned correctly it would depress this lever when closed. It may be that the door adjustment is slightly out. If the beeping does not stop when depressed, then your printed circuit board (located usually above the door) is faulty and needs to be replaced.
Mar 04, 2009 | Refrigerators
Refrigerator will not get cold, but freezer works
Make sure your fan is working ,its located behind the freezers back wall. If it is working the vent from the freezer down to the refrigerator may be blocked (usually with ice).With out a fan you have no circulation but your freezer may look likes its working,it may last 3 days.Also if you can move everything out unplug it turn it off w/ doors open untill all traces of ice are gone this will free up any clogged tubes. Good luck.
Len West
Feb 27, 2009 | Amana ABB1927DE Bottom Freezer...
Annoying beeping of the Kenmore refrigerator!!!
I don't believe this model has an alarm in it. The beep you hear maybe the evaporator fan motor, also if there is an icemaker in the frig be sure it is turned off
Jan 24, 2009 | Whirlpool ET1FHTXM Top Freezer...
Maytag Rerigerator
Something has stopped the cold air being ducted from freezer side to refrigerator side of things. Possibly duct blocked due to ice build up, evaporator not self defrosting etc. Turn unit off for a few days till it melts and then turn back on. If it was because a door has been left slightly open you will be ok. If for any other reason you will want to have it serviced in the next week or so.
Jan 09, 2008 | Maytag MZD2766GES Side by Side...
Samsung RS2556SH Freezer left open. compressor does not come on.
if door was left open for some time, there may be excess ice build-up on the evaporator which may take more than 2 hours to clear. two methods to cure switch off and leave for 24 hours with doors open. or remove back panel in freezer and carefully melt ice off with a hairdryer
Jun 16, 2007 | Samsung RS2556 Side by Side Refrigerator
Kidde i12040 Hardwire Smoke Alarm with Hush Feature and Battery Backup Logo
32 people viewed this question
Top Kidde Home Experts
Tre Elkins
 Mikey
Mikey
Are you a Kidde Home Expert? Answer questions, earn points and help others
