Question about Hoover Vacuums
Handle won't go down to clean under bird cage
Last Saturday I bought a Hoover Windtunnel #UH 70905 and the assistant told me that the handle would go down all the way so that I could clean under my aviary. I cannot get this handle down all the way, it will not go under my bird cage. I have depressed the switch and it will go down a little way but, not all the way. What am I doing wrong? I must have a Hoover that will clean under this cage as my birds are very messy with their seed.
    Sergeant:
    Champion:
  • Hoover Expert
  • 357 Answers
The sales person told you wrong. That machine, and all of the other Hoovers in that body style do not lay flat. If a Hoover is what you want and you need it to lay flat, look at the "Air" series machines. They will lay flat and are a slim build, such as UH72405,
Posted on Jul 03, 2017
SOURCE: Hoover Bagless Windtunnel - Self Propel feature not working
I have the same problem with ours. If you lift the vacuum by the handle it breaks the lever on the transmission. You can find a replacement cable and lever on line for about $16.00 it is somewhat involved to repair but can be done by someone with mechanical ability. You can try and find a repair shop but be careful, they sometimes tell you the part is not available and try to sell you something else. I think they should be able to do the job for aprox. $80.00, but they may want more. I did it myself plus the height adj. knob for $24.00
Posted on Nov 25, 2007
SOURCE: Hoover windtunnel
would suggest the drive belt is stretched and thus is slipping when contact is made with the carpet.
Posted on Jan 14, 2008
reddevil6
  • 1673 Answers
SOURCE: hoover on off switch won't
Don't know what model you have, but sounds like you will need to replace the switch. As far as your question, you will have to contact the manufacture for an answer. We only provide solutions to your problem and a model number would have helped.
Posted on May 01, 2008
  • 4 Answers
SOURCE: How do you remove the Handle from the Hoover Windtunnel Deluxe to replace the switch?
Removing the handle assembly should be easy after removal of the two screws. It may be binding or hanging up on the self-propel cable...or the plastic may just be stuck/binding. Note that the handle slides in and out of the vacuum unit along the same axis as the two screws (i.e. slides straight off the back towards you when you are standing behind the vacuum). Try to pry it off gently w/thin-bladed screwdriver or butter knife (careful now!). Not sure about the smoking issue but you may have a severely plugged filter and the unit is overheating as a result. Check that out immediately/first to avoid fire or expensive motor burnout.
Posted on Jan 02, 2009
  • 294 Answers
SOURCE: Hoover Self-Propelled WindTunnel U6436-900 cable problem
The flat belt should be changed if it has been longer than 9-12 months. Next I would remove the upper handle to inspect the top section of the control cable, sometimes it fray's and has a sponge feel (no positive control) to self propel. To set this adjustment, it is best to do withthe hood off of the lower section. I would also look at the cable jacket in the foot to make sure it is under the metal clamp. It must be under the clamp to work properly. To get it under the clamp loosen one hold down screw at the top and one in the back of the vacuum, remove clamp screws and put jacket into position and then secure all screws. Now set the adjustment, Install upper handle and set self propel to off. loosen cable from arm in foot with torx screw. manually move arm until the clutch is off both drive pads. This is a visual adjustment. then secure and reassemble vacuum.
Posted on Feb 28, 2009
I just bought a Hoover Windtunnel upright with bag, #U6485100. When installing the handle there was tape over the top with instructions do no remove until assembled. After assembling (screwing in the...
Be sure the on/off button and the power drive button are both in the OFF position before installing the handle. The actual switch inside must also be in the OFF position.
Feb 27, 2011 | Hoover U6437-900 / U6439-900 Windtunnel...
Tuned off and won't turn on again
This is a great product. Do not pitch. I've own this same unit for years. Take off the handle. There are four screww located half way down the hanlde. Once the handle is off, you will see the red swtich button. Flip the swtich on/off with handle off and unit plugged. The unit should come on. Put the handle back on and it should operate fine. If it doen't you mjay need a new switch
May 24, 2009 | Hoover U6437-900 / U6439-900 Windtunnel...
On-off switch is stuck on
on the back of the handle down below the grip you will see 4 screws take them out.then slide the handle out towards the back.on the sides of the handle you will see small notches those are the snaps the hold it together.the handle will come apart.feel free to call me if you need help i don't charge just like to help people save money.if there is a cord cradle there you may have to take that off also,held onby 2 screws.314-628-9153
Apr 23, 2009 | Hoover U6437-900 / U6439-900 Windtunnel...
Feb 24, 2009 | Hoover U6437-900 / U6439-900 Windtunnel...
Self Propelled does not work
if you look below the headlamp of your vac you will find a cable that attach's to a piece called the actuator arm. either this piece is likely broke or the cable itself. always work the power drive smoothly or things will break. also could be that the smooth belt is stretched and will cause the same problem. belts should be replaced every 4 months. good news is all parts above should be under $5. dont let anyone tell you that you need a power drive assy, that usually isnt the case. good luck!!!
Sep 24, 2008 | Hoover U6437-900 / U6439-900 Windtunnel...
I have a Hoover Windtunnel Dual V. The vacuum and I did a tumble down stairs and the handle release pedal was broken. Is that something I can order a part for and have my husband put on? If so, where...
http://geeksquad.fixya.com/ThreadView.aspx?prdid=0&thid=627747
Generic problem for all Vacuums
Posted by ekindler on May 27, 2008
I have a Hoover Windtunnel Dual V. The vacuum and I did a tumble down stairs and the handle release pedal was broken. Is that something I can order a part for and have my husband put on? If so, where would I obtain the part?
Thanks. Roxanna Kindler ekindler@bresnan.net
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure.
Yes, you can purchase the part @ any Hoover factory authorized store or your local vacuum dealer in your area and I also will give you some suggestions listed below. If you check your owner’s manual the part can be replaced by your husband if he is handy or otherwise refer to a vac dealer. So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
http://www.hoover.com Telephone
Contact our Customer Service Department at 1.330.499.9499
Monday through Friday
8 a.m. - 7 p.m. EST
http://www.a-1vacuum.com/ 1-800-657-1874 Customer Service
Thanks, Don the Vac Man
Go Ahead. Use Us.
May 27, 2008 | Vacuums
Hoover windtunnel
Jan 14, 2008 | Hoover U6437-900 / U6439-900 Windtunnel...
Hoover Windtunnel
If it goes in just at the bottom of the handle, take off the handle, then remove the tool holder, then you can replace the cord. If it goes in near the bottom, then you will have to remove the motor cover and light to get to the connecting wires.
Oct 11, 2007 | Hoover U6437-900 / U6439-900 Windtunnel...
Vacuums Logo
Top Hoover Vacuums Experts
Gerry Harvey
Gerry Harvey
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
