Question about ViewSonic PJD6251 Projector
Defective fans Projector will not popwer up.
After around 1 minute the lamb goes off and the system goes to standby
the lamp is good one, it is ok .the mother board is ok
it seems like the fans is defective
pls check every fan in the projector
Have a good day!
We supply original projector parts: lamp, bulb, Lcd panel, Lens, DMD chip,color wheel, motherboard, powersupply ... with high quality and competitive price.
Jerry China Lampdeng Limited
Tel: +86 131788 67858
E-mail: lampdeng@hotmail.com
Skype: lampdeng.com
YM: lampdeng@yahoo.com
http://facebook.com/lampdeng
http://www.lampdeng.com
Feb 21, 2014 | NEC M260X LCD Projector
Epson EMP 500 turning off
I believe that's an overheat problem. Check the fan if it's cooling properly. Make sure the unit is in a cool temp room.
Nov 01, 2008 | Office Equipment & Supplies
DMD error code
the DMD is good ,
the Projector will still start up,even if the DMD is defective.
the lamp ballast or the mother board is defective
Feb 20, 2014 | Vivitek H1080FD DLP Projector
Sanyo PLV-Z2 flashing then off
1,the fans is good , is ok
there is not an overheating situation ,only 5-10 minutes,
2,seems that the lamp ballast is defective
you need a new lamp ballast, unit price is USD80
Have a good day!
We supply original projector parts: lamp, bulb, Lcd panel, Lens, DMD chip, color wheel,
Jerry Lampdeng Limited
Mobile: 0086-13178867858
Wechat ID: 008613178867858
Whatapp ID: 008613178867858
Skype: lampdeng@hotmail.com
Feb 16, 2014 | Sanyo PLV-Z2 Multimedia Projector
Projector wont power up
Hello :
Check your fans, The projector will not power up if either of the fans have failed . A defective electrolytic capacitor in the power supply can cause the problem also . You could check the lamb also . If the lamb is defective that also can cause the problem .
good luck .
please don't forget to rate !
Apr 04, 2010 | InFocus IN72 Multimedia Projector
Hello, I have a PLC XP45L. As soon as I turn on the projector it goes off. The only light on top of the projector is the READY light. We replaced the lamp last year and probably have around 50 hours on...
good day mr david, just clean the air filter of your projector, check all the fans if working... if this problem occur again your lamp ballast is defective.
jahting
Oct 29, 2009 | Sanyo PLC XP45L Multimedia Projector
Mistub XD450. Bulb relatively new. Projector
Does the projector work normally when sitting right-side up? If yes, something could be interfering when the unit is inverted. The symptom you describe initially sounds like a defective fan (some fans put out a computer pulse telling the main board it's running--they have 3 wires, red, black, yellow(signal)). If the board doesn't get signals from all required components, it's programmed to shut down to protect itself.
Aug 29, 2009 | Mitsubishi XD480U Multimedia Projector
Temperature indicator turns on in my Epson EMP-500
it appears that one of the cooling fans in ur projector is jammed or not spinning at the required speed!
ope the projector & observe the fans as u switch on!!!if the fans seem fine, then it could be a defective thermistor!
Feb 06, 2009 | Epson EMP 500 Multimedia Projector
ViewSonic PJD6251 Projector Logo
27 people viewed this question
Top ViewSonic Office Equipment & Supplies Experts
jasbo
jasbo
Electro Med Services...
Are you a ViewSonic Office Equipment and Supply Expert? Answer questions, earn points and help others
