192 168 1 1 admin password
How to changing new password
How to change my password
In your internet browser navigate to 192.168.0.1, username/pass is admin/admin or admin/password - Wireless settings - Change the SSID text and enter a new password in the WPA encryption
Sep 25, 2014 | NetComm Telstra Bigpond 3g9wb 3g Wireless...
Forgot my administrative password
Creating a new Admin on Mac Os X:
Here's how to reset your OS X password without an OS X CD.
the Working solution for me was to create a new admin
you can create new admin like this by deleting a specific file.
You need to enter terminal and create a new admin account:
1. Reboot
2. Hold apple key + s key down after you hear the chime.
(command + s keys on newer Macs)
3. When you get text prompt enter in these terminal commands to create a brand new admin account (hitting return after each line):
mount -uw /
rm /var/db/.AppleSetupDone
shutdown -h now
4. After rebooting you should have a brand new admin account. When you login as the new admin you can simply delete the old one and your good to go again!
Mar 30, 2014 | Apple MacBook Air
I installed handycafe software on my computer and i forgot the password what can i do
You can easily change Admin password from Server.
  1. Click Options
  2. On the left menu double click Operators (Or click + sign to expand)
  3. Click Administrator
  4. Enter the new username if you like to change the username too
  5. Enter Admin Password and re-enter the same password in "Re-enter Password" field
  6. Click Apply button
  7. Enter your current password
Your Admin password is now changed.
Oct 25, 2013 | Computers & Internet
Forgot ip address and password
To re-enable the Console access requires the SW2900 series to be reset to its default settings via the WEB INTERFACE
- Web Interface
- Device >Configuration >Initialize To change the Default User "ADMIN" password it is necessary to use the Console connection
-Console Interface
-Once the unit has successfully booted and the prompt presented
-Enter "password" (without "")
-Enter "admin" when the system prompts for User
-Press the "Enter" key when the system prompts for "Old Password" (the ADMIN password was reset by the Web Interface commands)
-Enter "" when the system prompts for the New Password (where "" is the new product ADMIN password)
-Enter "" when the system prompts to confirm the New Password In order to complete the configuration it is necessary to save the configuration via the WEB INTERFACE
-Web Interface
-Device > Configuration > Save
Symptom:
SW2900 Baseline Switch - Default console access disabled following password change
From the web interface, the default user "admin" password is changed and console access is disabled
Cause:
When applying the new password, by default the service-type is set to "telnet". When applied, the default "terminal" setting is removed thus disabling console access.
Apr 20, 2013 | 3Com Baseline Switch 2924-SFP Plus
What is routee password
Default password is "admin" (without the quotes, all lowercase) unless you have changed it with the configuration program on the CD. Leave the username field empty.
Apr 12, 2011 | Linksys Wireless-G WRT54G Router
How will i change my password
First: Navigate to the router's web admin page by going to it's IP address, this is usually 192.168.1.1, but you can look it up in your computer's network settings. The IP address of your router is called the "Default Gateway". If the Default Gateway is not 192.168.1.1, use what is there.
After you get to the web admin page, use the current admin username and password to login. If you don't know it, try the default, usually admin/admin or admin/password. Once you're in the router, you can change the settings as you wish.
Hope this helps and feel free to ask questions if need more help!
Mar 30, 2011 | Computers & Internet
How to change administrative user name and password?
if you know the password then log in via the admin and goto control panel > user accounts> administrator> and click change my password.
Enter the new password twice and way you go.
if you have forgot your admin password then:
if there is already an other administrator on your PC then you can log in to that and type
net user administrator *
in command prompt then enter the new password twice.
Note this command can only be valid if you have admin authority.
Mar 18, 2011 | Computers & Internet
I want to put a new password into my linksys. I
Upon typing the address of your linksys router (usually by default it is 192.168.0.1) your default Username and Password Admin:admin or Admin:password (depends on the model). Then, when you are able to view your router's control panel, click on "Administration" tab. From there type in your new password and confirm it by re typing. Click "Save Changes" button to apply the new password.
Nov 11, 2009 | Linksys Wireless-G Broadband Router
I cannot set password
There are 2 users in this router, 'admin. and 'user', default password is blank. admin can change password of user without having old password, user can change his own password, admin can change password of his own by supplying his old password then new password twice. To log in to this router, default address is http://192.168.0.1 user name admin and password blank. You may now change password from tools menu.
If you forgot user password then log in as admin and change password, If you forgot all password then only way is to reset router from rare pin hole. Pressing reset for 20 seconds.
Jul 15, 2009 | D-Link AirPlus DI-524 Wireless Router
How do I change the administrative/user password on my router?
Step 1 Open a web browser and enter the IP address of the wireless router in the address bar (default is 192.168.0.1). Press Enter. Step 2 The default username is admin and the password is blank (nothing). Click OK. Step 3 Click the Tools tab and then click Admin to the left. Step 4 To change the administrative password, enter a new password in the Admin section. To change the user password, enter a new password in the User section. Step 5 Click Apply then click Continue to save the settings.
Feb 16, 2006 | D-Link Express EtherNetwork DI-604 Router
Computers & Internet Logo
15 people viewed this question
David Payne
David Payne
