Question about Camping, Backpacking & Hiking
Broken hairdrier hair dryer
Sunbeam 1400w hair dryer doesn't blow out any heat
This is a hair dryer correct? Only two things can be the problem here.
1) a wire is disconnected or broken that provides power to the Heating element. Or 2) the heating Element is burned out. Do to UL regulations these hair dryers are not supposed to be repaired by anyone not having sufficient electrical knowledge or Factory training. A wire or a n Element burns out FOR A REASON, normally excessive heat causes failure of the unit. They are cheap enough to replace without being put out by extreme costs. Do yourself a favor buy a new one.
Apr 06, 2014 | Dryers
What is special about ionic hair dryers?
I read a review top ten hair dryers which is the best and professional blow dryer for healthy hair. everybody can choose one. 10 Best Hair Dryers 2014 Review Buy it for curly hair
Feb 04, 2013 | Health & Beauty
If my Remington T Studio Collection Tourmaline-Ceramic AC Motor Dryer Hair Dryer does not put any heat out anymore, does that mean its: 1) Broken and not fixable - just buy a new one. 2) Broken but...
Hi! How long have you been using this? The heat coil might be worn out. If it is, it's best to buy a new one rather having it repaired. Repair will cost you more and will take longer than buying a new one.
Jan 08, 2011 | Remington Ceramic Hair Dryer with Color...
Green led flashes but wont turn on , will work after blowing hairdrier over back of tv
That is the sign of bad caps, open up the back and look at the caps in the power supply, when caps have high ESR, the ESR will go down when it is heat up. I use hair dryer for a lot of troubleshooting for 30 years. Bad caps can look normal with no sign of leaking/bulging.
Make and model?
Basic LCD monitor and TV troubleshooting guide:
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r7406380-tv_training_manuals
Failed TV and Monitors: http://s807.photobucket.com/albums/yy352/budm
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Parts: www.shopjimmy.com
Capacitors kit: http://lcdalternatives.auctivacommerce.com/Default.aspx he can make you a set of caps.
Or www.digikey.com, just make sure to use caps with low ESR, 105c, high ripple current and long life rating such as PANASONIC FM or FC series.
Please post back what you find.
Dec 31, 2010 | Panasonic Televison & Video
My phone got put in the wash, I dried it with a hair dryer real good, but when I put the battery in the red light comes on and that's it. Is it trashed?
never ever use a hairdrier to dry a phone. you should have put it in a bag of rice, for one, not turned it on for quite a few days, and third of all, not have put the phone in the wash at all. your phone is trashed because of the chemicals in teh detergent, the water, and the fact that you used a hairdrier. go get a new phone. i hope you got phone insurance(like my parents made me get, because of my track record with bringing phones in the shower.) good luck.
Oct 16, 2009 | RIM BlackBerry Pearl Flip 8220 Cellular...
Hair dryer runs but isn't hot
inside your dryer there is a cmall thermo fuse this normally burns out if your rear vent gets cloged with dust replace the thermofuse cost aprox 2.00 dollars in a electronic shop or you may have a broken wire to the ellement but most likly its your thermofuse thanks from gilles
Mar 15, 2009 | BaByliss PRO Nano Titanium Hair Dryer
Fridge part is not cooling; freezer is frosting up
your ref. has a defrost problem.you will need to take back panel off inside freezer and take your hair dryer again and defrost the system.then you can check your heater,thermostat which is located at top of coils that were defrosted.sometimes the thermostat will pop and not allow it to go into defrost and you need to check defrost timer.
Mar 12, 2009 | Refrigerators
2001 jimmy cranking no start in cold weather
It might be distributor cap, coolant temperature sensor. Try to warm the engine head with hairdrier
espetially distributor cap, plugs connections etc
If it will help look the solution where. Sometimes usefull to check battery and replace oil and fuel
Good Luck
Dec 18, 2008 | 2000 Chevrolet Blazer
Camping, Backpacking & Hiking Logo
53 people viewed this question
Top Camping, Backpacking & Hiking Experts
Tom Chichester
ray gallant
Are you a Camping, Backpacking and Hiking Expert? Answer questions, earn points and help others
