Question about Samsung Televison & Video
I have a samsung hlt6176x/xaa tv. the picture weny ouy so i replaced the lamp. the picture came back on for about 3 minutes and went out again. bad lamp?
What can i do?
  • 395 Answers
SOURCE: JVC TV lamp indicator light blinking new lamp
if you purcased a LTI lamp then the possibilty of a bad lamp may be the case. LTI lamps are cheap and are poorly manufactured. if it is a JVC lamp then you may have further problems such as lamp balast, or thermal sensor. clean the fans and filtersfor better air flow. keeping the lanp cool is important for the life of the lamp.
Posted on Apr 19, 2008
  • 304 Answers
SOURCE: samsung model # HLP5063WX/XAA 3 lights blinking
It can be the Lamp Ballast as well as the Color Wheel.
Posted on Jul 16, 2009
ladywinn
  • 5138 Answers
SOURCE: Replaced lamp Mitsubishi WD-52531 worked for one day
Ballast Board may be Bad it is what turn Lamp on Call Encompass for parts 1-800-638-3328 or look for one on E-Bay they have good deals on Parts.Also CK Fan to Lamp it maybe defective .Call Mats for Fan 1-800-628-1118 they have lamps also.
Posted on Sep 27, 2009
  • 3 Answers
SOURCE: I have a Samsung TV # HLP6163WX/XAA. A loud
I also have a Samsung HLP6163W 61in TV,had the same problem had to replace the color wheel. Went on youtube showed us how to do it our self. Saved a lot of money very easy. Good luck!
Posted on Jan 19, 2010
  • 8457 Answers
SOURCE: Samsung TV: lamp out
Yes,tries websites like Tvrepairworld.com,Partstore.com,Ebay.com to buy a projection lamp for the replacement.Tv have "LAMP"indication LED light is flashing or staying on.If the projection lamp on the tv now,been in used 4 or 5 hours a day watching the tv.The projection lamp has not been replace the last 1 1/2 or 2 years on the tv.The projection lamp life is over,require changing.The tv also making clicking noises,the Ballast board also dead,require changing too.The Ballast board help to ignite the projection lamp.
Posted on Aug 02, 2010
TV lamp has been replaced, still won't come on, no picture. When turned on, I can see a blue, kind of sparking light and noise starts and does this about three times. TV powers down and does this again....
Samsung DLP TV Repair - No Picture - Replacing ...
? 2:41
https://www.youtube.com/watch?v=pBTgk_C5FVU
Jun 11, 2012 - Uploaded by ShopJimmy.com
DLP TV Repair No Picture Bad Lamp Bad Bulb TV Won't Turn On DIY Samsung DLP TV Repair How to replace Faulty LampTutorial Click Here to ... Rating is available when the video has been rented. ... is a replacement for the following DLP Rear Projection TV models: ... SAMSUNG HLR6167WX/XAA
Samsung DLP problems - Help! - ecoustics.com
www.ecoustics.com > ... > Home Video Forum > Projection TV Forum
Oct 26, 2009 - I have attached a picture of to show where the "Light Tunnel" is located. Upload ... So now I have a Samsung HLN5065W/XAA that I am willing to part out or sell as is. ... I replaced the ballast but the TV still won't turn on. .... The lamp has been sitting on a shelf until two weeks ago, when the TV went dark. Samsung DLP Light Ballast
Apr 10, 2009
Archive through October 26, 2009 - Samsung DLP problems ...
Apr 8, 2009
Samsung DLP Flashing Standby light
Jul 1, 2006
More results from www.ecoustics.com
Jan 19, 2016 | Samsung SELECT HLR6167WX/XAA Rear...
Hi. I have a samsung HLP-6163WX/XAA projection tv. Recently I asked a question, but I can't seem to add more details to it so I am asking again. After running for ten minutes the tv picture will turn black...
The glue is just protection as far as the lamp gone if you bout an after market on that probably the problem I went threw 5 of them before I to it to a TV repair shop he put in a oem lamp and it's work fine ever since hope this helps
Feb 05, 2015 | Samsung Televison & Video
Sound but no picture on samsung tv HLT5687SX/XAA
I unscrewed the panels on both sides of the tv to find out that the lamp was not turning on. What I did was I got my broom, tapped the lamp with it about 3 times when it was turned on, turned it off, tapped the lamp 3 more times, turned the tv on and it started working again.
Sep 01, 2013 | Samsung DLP HL-P5663W 56" TV
Samsung HLS5086WX/XAA made popping noise and shut off, then made whirring noise.
When my TV did this in the past it ended up being the color wheel. I had someone replace it and it worked fine. I asked it if had to be calibrated after it is installed and he said no. Also make sure the door switch is pushed down when you install the back bulb door. Sometimes this switch can go bad as well.
Jan 10, 2013 | Samsung HLS5086WX/XAA
Lamp light flashes then stops. no picture. samsung HLS4266WX/XAA
Was the trouble exactly the same before lamp and wheel were replaced?
If lamp comes on for 3 minutes what do you see on the screen?
the more you tell me the better I can assist you.
Mar 14, 2012 | Samsung HL-S4266W 42" HDTV
I have a Samsung HLM617WX XAA DLP TV purchase in 2004. I replaced the lamp (BP96-00224J) in 8/09. Other than this the TV has operated perfectly. This week the screen went blank and the three LEDs flashed...
If the lamp is failing, the sensor on the ballast unit will shut it down. Check with a new lamp and ensure the cooling fans are clear and filters are clean.
Mar 31, 2017 | Samsung HLN617W 61" Rear Projection HDTV
Replaced lamp, still having picture problems.
take it to an authorized samsung service center, your color wheel may be broken or your dmd maybe damage.
Apr 29, 2009 | Samsung HLR5067WX 50" Rear Projection HDTV
Televison & Video Logo
Henry  Thomas
Henry Thomas
