Question about Carrier Heating & Cooling
Aircon stops after few minutes without having the room cooled the correct temp.The compressor does not start .We have to wait for a long time after shutdown and restart for it to cool again. If not
Old unit split type
  • 3 Answers
Most possible reason in this case is defective compressor(it overheats),or not enough freon in the system. Solution 1.change compressor;2.Recharge the system with freon.
Posted on Apr 02, 2014
2 Suggested Answers
  • 588 Answers
SOURCE: RV air conditioner. Compressor running, fan stops before cool
The fan motor is getting hot and going off on the internal overload in the motor.
This is caused by either a low voltage, a bad capacitor, or tight or dry bearings in the motor.
To check the bearings turn the power off to the unit, then spin the fan blade if it spins freely then the bearings are ok.
To check the capacitor you will need some kind of tester or you can buy a capacitor and replace it, that's what a lot of people do. They usually don't cost very much.
To check the voltage you will need a voltmeter and measure the volts at the unit.
Posted on Jun 09, 2009
How do I get my maytag side by side refrigerator model# msd2756geq to cool down below 50
first turn your refrigerator temp setting to 1 then wait for the compressor to kick off, this will send the unit into defrost mode, and most units take between 1 to 2 hours to acclimate(get tempered) correctly. after a few hours gradually turn your unit towards 9 until the compressor kicks on, when it does , stop turning the knob, it will acclimate again, 1-2 hours (some units can acclimate in 15 minutes) check your unit temp and do not use the unit if it won't cool down to 43 or less degrees, you run the chance of food poisoning. hope this was helpful.
Aug 01, 2014 | Maytag Refrigerators
Split type aircon
It sounds to me that the air con is on auto fan, as the room gets hotter or colder the fan will slow down and stop. keep the fan on low,med or high fan speed
Apr 02, 2014 | Carrier Heating & Cooling
Compressor fails to restart
indicates that the compressor is not communicating with the program board in the inside unit
could be a relay problem
call in the service technicians for a proper diaganosis
Sep 12, 2017 | Honeywell Heating & Cooling
Our Hitachi EC119Sa will not start if the temp is lower than 60. It also kicks out the restart button
Easy test to determine problem. Plug compressor directly into outlet without extension cord. Start compressor with no air in the tank. It it starts, fill to 50-60 psi and unplug from wall to stop. Wait few minutes and plug the compressor back in. It it starts, most likely problem is too heavy oil or the use of extension cord. If it does not start after few minutes wait, most likely not unloading due to leaking intank check valve or bad cold start valve (see reference # 47 on your parts list). The cold start valve should release air from discharge tube after few minutes. If the intank checkvalve is leaking, the cold start valve will not work and stall the compressor. If all test ok, then just replace oil with 10 - 15 - or 20 wt. Good luck
Dec 26, 2012 | Hitachi EC119SA Twin-Stack Air Compressor...
Intermittent colling in Samsung Window AC
so your reported figures show that the unit is operating as planned
the closer to ambient temp the shorter it runs for
the further away from ambient temp the longer it runs for
when the desired temp is reached , the compressor will stop but the fan will continue to run to circulate air past the thermostat so that it will switch back on when the room temp reaches too high temp
and that is why it is recommended to set the temp at 25 C as that is the most economical temp to run it at
Oct 30, 2017 | Heating & Cooling
I had the aircon thermostat on cold then my friend just transfered it to warm without turning the aircon off because it was too cold. in the afternoon when i tried to use the aircon theremostat to...
Problem is the thermostat.The heat/cool selector switch might not be making try back and fourth from heat/cool to make a good contact.In heat mode make sure the temp is set LOWER than your cooling temp.If it is too cold in the future just RAISE the cooling temp up and not the heat/cool switch.
Jun 04, 2011 | Heating & Cooling
No cool and compressure not coming on
Please follow the steps one by one.
1.Check room sensor by ohms. ( Disconnect sensor from PCB and measure resistance. 8 kOhm at 30C and 13 kOhm at 20C if not replace sensor). 2. Keep cool mode and set temp minimum three degree less than room temp. 3. Wait for 3 minutes. Check compressor starts by sound. 4. Keep hand on discharge line near to compressor , is warm. Hope helpful. If still problem not solved, please write clearly what error code is there. Thanks.
Jan 27, 2011 | Mitsubishi Heating & Cooling
Aircon is only blowing ambient air with no cooling effect. the indoor and out door unit appear to be operating normally. am I out of gas or is the compressor not running? what could cause this to suddenly...
First of all check your compressor is working with correct amps. If yes, service your unit to improve better cooling. If compressor not working find out the root cause for it. Please call repairman to find the fault.
We can only give solution by having particular cause or error code is stated by you.
And also follow these tips always:
To get proper cool, keep the tips as follows:
1. Check air filter is cleaned. 2. Check indoor coil is cleaned. 3. Checkindoor blower motor is working. 4. Keep in cool mode. 5. Set temp minimum 3degrees less than room temp.6.Check compressor is working with correctpressure.
Thanks. Helpful?
Jan 16, 2011 | Fujitsu 18C1 Air Conditioner
Aircon runs for a few minutes then shuts down and timer light flashes
when we start the AC indoor working and out door unit compressor working but fan motor not working and indoor timer light blinking
Dec 16, 2010 | Mitsubishi MSZ-A24NA Split System Air...
Kenmore refridge/freezer just stops working. I
. Cut everything off for a few minutes then turn it back on and listen for a click from the compressor relay as the compressor tries to start.
Is the compressor motor running.If no check starter/overload relay.
Check to see if the condenser fan at the back underneath near the compressor is running. If no check fan.
Are the condenser coils near there warm or room temp. should be warm
How to check stuff>
http://www.acmehowto.com/howto/appliance/refrigerator/refrigerator.php
Sep 20, 2009 | Refrigerators
Heating & Cooling Logo
127 people viewed this question
Top Carrier Heating & Cooling Experts
Dan Webster
Dan Webster
Bill Long
Are you a Carrier Heating and Cooling Expert? Answer questions, earn points and help others
