Question about Miller Bobcat 225NT 8000 Watt Generator Welder
Fuel runs for a few minutes the sputters an finally dies
My car is sputtering and dying. If I try to restart it, it will immediately go into sputtering/dying mode. If I wait a while an hour or so it will start up and drive fine.
When was the last time that the carburetor was stripped and cleaned? Also have you checked the fuel filter? Finally, the problem seems to come and go as the engine is run (and it gets hot) check that the fuel line and any electrical cables are well away from the hot engine as far as is possible.
Jun 16, 2015 | Cars & Trucks
Sputters dies after 5 minutes
If it runs at all, then it is not the spark, so it must be fuel. Flush the tank and put in new clean fuel. If it still does not run right, then you probably need to rebuild the carbureator.
Aug 27, 2014 | Honda Eb3500 Eg3500 Em3500 Ew140 Generator...
96 dodge ram sputters and dies whem you give it gas
you need to check fuel pressure with a pressure gauge to see if its within specs.it should be around 35psi and no lower then about 32psi.your problem sounds like a fuel pressure problem and the pump should be changed as well as the filter, but check to make sure the fuel filter is not plugged as this can also cause a pressure problem.
Nov 29, 2013 | 1996 Dodge Ram 1500 Club Cab
Sputters after driving a few minutes, tries to stall out.
1st move is to ck the fuel PSI & emissions. Possible cooling system cause.Scan computer & check sensor readings & the emissions readings are the first moves. Check spark plugs, ignition spark etc. Good luck
Mar 25, 2017 | 1999 Volkswagen Cabrio
Suburban dies at highway speed
It sounds like a fuel pump getting weak and hot. First check the ground wire at the fuel pump pigtail. and replace the fuel fiter.
Jul 27, 2009 | 2003 Chevrolet Suburban 1500
Lawn mower dies
Find the fuel air mixture screw and while the mower is running turn so mower almost stops then turn them back till the moter is running smoother.Give it some throtle to see & hear how it is running
Nov 02, 2008 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
JEEP coughs or sputters and dies, and then won't restart.
I have the same problem did you find what to fix.
Sep 30, 2008 | 1987 Jeep Wrangler
Miller Bobcat 225NT 8000 Watt Generator Welder Logo
18 people viewed this question
Top Miller Electrical Supplies Experts
Craig Butler
Craig Butler
janman
Lawrence Oravetz
Are you a Miller Electrical Supply Expert? Answer questions, earn points and help others
