Question about NetGear WNDR3800 N600 Wireless Dual-Band Gigabit Router - Premium Edition
How to fix conflict other service netgear
When i try to put in ports it says its been used by another service and it wont let me use the ports. Lately I have witched routers is that the problem if it is how should i fix it?
3 Suggested Answers
  • 121 Answers
SOURCE: Port conflict with other service with netgear
It's telling you that there is already some type of service configured with the port you are trying to use. Confirm that the port number you are trying to forward is not listed elsewhere in the already-configured rules. or in the defaults of the router. If so, you will need to adjust the port you are using to something that does not conflict, or disable the existing rule.
Posted on Feb 20, 2010
bunnydawg
  • 5158 Answers
SOURCE: netgear router is showing error."port
http://kbserver.netgear.com/kb_web_files/n101145.asp this should give you an understanding to help you set it up properly
Posted on Dec 23, 2010
How do i port forward?
My Netgear has a Port Forwarding/Port Triggering tab when I log into it. You click on add custom service and put the ports in. Your device needs to have a fixed IP address vs. DHCP. It's fairly simple once you fix the IP's and log into your router.
Carl
Jan 24, 2011 | NetGear WNR2000 Wireless Router
Install netgear wireless g router wgr14 v9
connect it to your modem with the WAN port and connect your computer to its LAN port and turn off everything. Then start modem, after 30 seconds the router and after 30 seconds the computer. No configuration should be necessary unless your modem is using an IP address and your router need another and you only have one from your ISP. Then you will need to contact your ISP to get another one or have them figure how it will work on their site. Use DHCP for your computer if possible so there will not be a subnet conflicts or IP conflicts or something.
Oct 07, 2010 | Computers & Internet
I have a netgear wgr614 v9 router but have problems with slow speed to my ps3 desk top and wireless laptop i have virgin 10meg broadband but have connection conflicts
you to port forward. call Sony tech support to ask what port to be forwarded using Netgear router. Then follow this steps below...
Port Forwarding
A. Determining the IP Address and MAC Address of a Computer:
Note: Please use the computer for which the Ports are to be opened:
For Windows 2000/XP users:
1. Please click on Start and select Run.
2. Type in cmd and click on OK.
3. In the Command Prompt, please type ipconfig/all then press Enter or Return key.
4. Please make sure that the Ethernet adapter has an IP Address that is the same range as the router (e.g. 192.168.1.2 for the computer and 192.168.1.1 for the router).
5. Please note down the IP address and Physical address.
B. Reserving an IP Address:
1. Please open any web browser like Internet Explorer or Mozilla Firefox.
2. Connect to the router by typing http://routerlogin.com/basicsetting.htm or http://192.168.1.1 in the address field and click Enter or Return key.
3. A window will prompt for a username and password. The default username is "admin" and the default password is "password".
Note: Username and password are case sensitive. If it does not take password as the password, you might have changed it when you ran the NETGEAR Setup CD so please try other passwords.
4. When the setup page opens, click on LAN IP Setup under Advanced tab.
5. Click on Add under Address Reservation.
6. Under Address Reservation window, please select the radio button of the computer you wish to add from the Address Reservation Table.
7. If the computer you want is not on the list, please click on the Refresh button to update the table.
8. If the computer is still not on the Address Reservation Table, please type in the IP Address, MAC Address (Physical Address), and Device Name of the computer you wish to add.
9. Click the Add button when done.
C. Opening Pre-Defined Ports for Internet Services:
1. Click on the option with the name Port Forwarding/Port Triggering under the Advanced menu.
2. Please select the service type Port Forwarding. The router pre-defined services are listed there.
3. From the Service Name pull down list, select the service that needs to be hosted.
4. Enter the IP address of the computer in the Server IP Address box.
5. Click the Add or Apply button.
6. Repeat all steps to open more ports.
Note: If the name of the Internet service does not appear in the drop down list, you may manually open the ports for that Internet service. Please follow the steps below:
D. Opening Ports for Games, Applications or Custom Ports:
1. Click on Add Custom Service button.
2. Type the service name in the Service Name box and the lower range numbers in the Starting Port box.
3. If the application uses only a single port; type in the same port number in the Ending Port box.
4. If the application uses a range of ports; type in the higher range numbers in the Ending Port box.
5. Type the IP address of the computer in the Server IP Address box. Click Apply button.
6. It will then refresh to the Port Forwarding page, and will show the list of all ports opened in tabulation.
7. Repeat all steps to add more ports for more services.
E. To Edit or Delete a Service Entry:
1. Click on the Radio Button that needs to be Edited /Deleted, under the Port Forwarding page.
2. Modify the information from the Service Name, Starting Port, Ending Port, and the Server IP Address, and then click the Apply button.
Apr 21, 2010 | NetGear WGR614 Wireless Router
How fix wireless drop. why does my netgear wireless router seem to drop or just no connection to my laptop? I'm currently using this model NETGEAR- RangeMax Dual-Band Wireless-N Router with 4-Port...
Try turn OFF DHCP, START>>RUN>>service,msc enter, scroll down to DHCP, set to OFF & Disabled, also further down Windows Zero configuration, again OFF & Disabled.. reboot,try that.
Feb 28, 2010 | NetGear RangeMax WPN824 Router
Feb 20, 2010 | NetGear WGR614 Wireless Router
Computer is right next to netgear router
A change in speed and connection stability like that could be caused by a number of things. If you've upgraded any major component of your computer lately (monitor, power supply, etc) that could account for the change. It could also be conflicting with another wireless router outside the home, from a neighbor perhaps. But age could also be a factor, since you mentioned it's already 3 years old, it may just need to be replaced. Try moving it farther away from the computer, 10 feet minimum, no more than 30. If that doesn't work, check with your computer if there are other wireless networks it can detect. If so, it could be the two conflicting with one another. If both of those don't help, it may be time to get a new router.
Sep 19, 2009 | NetGear WGT624 Wireless Router
Wifi wont pick up internet netgear adapter does
there is a kind of conflict that has to do with the driver. If it worked when you just got your system, them a system restore would get it working.
Apr 07, 2009 | Computers & Internet
Hardware conflict
You might have your internal modem set to the same com port as your com ports that are on your motherboard. You can try to go into BIOS and disable all com ports OR you can try to configure your internal modem in windows to use com 3 or com 4. Remember, that if your computer does have com ports in the back, then is is probably set to the same address as your internal modem so something needs to be moved.
Feb 11, 2009 | Hiro V.92 56K PCI DATA FAX VOICE MODEM...
I have a netgear wg111v3 adaptor and a netgear wireless router. both setup fine and get on net ok. but when i turn my computer off then on again i have to re install my wireless adaptor. can u help?
hello!
-- try to install the adapter to a diff slot/ port
-- try to uninstall the driver and use updated driver downloaded from the netgear website to reinstall the driver
-- unistall old driver or other adapter on the computer to avoid driver conflict
May 02, 2008 | NetGear : WG111 54 Mbps Wireless USB 2.0...
NetGear WNDR3800 N600 Wireless Dual-Band Gigabit Router - Premium Edition Logo
Top NetGear Computers & Internet Experts
Prashant M
Prashant M
Are you a NetGear Computer and Internet Expert? Answer questions, earn points and help others
