TOP DRAWER WASHES AND DRAINS PROPERLY. AT THE END OF A CYCLE, AFTER DRAIN IS FINISHED, THE TOP DRAWER IS OPENED TO UNLOAD CLEANED DISHES. WHEN THE DRAWER IS STANDING OPEN, HALF A QUART OF WATER DRIPPS ONTO THE FLOOR DIRECTLY BELOW THE PUMP IMPELLOR AREA FROM THE UNDERSIDE OF THE DRAWER. ARE THERE REPLACABLE SEALS FOR THE PUMP? NO OBJECTS HAVE BEEN FOUND IN THE PUMP AREA, BUT THE CLEANING LADY SOMETIMES DOESNT REINSTALL THE PUMP AND COVER CORRECTLY. THIS PROBLEM HAS BEEN ADDRESSED AND THE DRAWER IS CORRECTLY ASSEMBLED WHEN THE LEAKS OCCUR. IF THE DISHWASHER TILTS FORWARD AT THE TOP MORE THAN AT THE BASE, ONLY A 1/4 INCH OUT OF TRUE SQUARE, WILL THIS CAUSE WATER TO RIP AFTER THE DRAIN HAS RUN?
SOURCE: The dishwasher top drawer is leaking all over the
Fisher and Paykel design a air gap kit to prevent the water back flowing to the other while one is running. it really works and worth of your money. You need to change the lid seal and a pair of actuators from the top drawer. Because of the leak then the floor switch activated not allowing a complete cycle. Need to dry out the wetness from the bottom housing of both top and lower drawers by pulling the tubes out and accessing from the left side with small tower until it completely dry. Here is a link to buy air gap kit http://www.fisherpaykelparts.net/product/WT50/WT50-Dual-Air-Gap-Kit/
SOURCE: top drawer retains about 2
Here is a tip that I wrote that will help you with your dishwasher not draining problem...
Dishwasher Problems - Water will not drain out
heatman101
