Question about ViewSonic PJD6211 Projector
How can i reset viewsonic pjd6211 projector
How can i reset the projector
Bulb not turn
bulb should stationary, not fault.
make sure bulb proper fit, push in hard, screw up, all covers on and screw, all cables correct insert, hours reset if exceed safe limit.
then google viewsonic pjd6251 projector manual
Jan 29, 2014 | ViewSonic PJD6251 Projector
Blue power light frozen, projector won't turn on
Page 47 has nothing to do with this problem! Thanks for wasting minutes of my life
Nov 28, 2012 | ViewSonic PJD6211 Projector
Viewsonic PJD6211, I have white pixels and black ones and some are blinking white now and I have a few black lines going across my image and a white one going up and down. What do I need to do to fix
Clean and verify the color wheel and its sensors. They can get dirty and wheel no longer syncs. The next thing is if the air cooling of the DLP chick got clogged that MAY have damaged the chip. It moght be permanent but check that the air passages for the heatsink of the chip are open.
Jun 26, 2012 | Computers & Internet
Reset button Viewsonic
MaYbe if your voice weren't so annoying you could ask a friend....hee hee hee
Jan 03, 2012 | ViewSonic PJ551 Multimedia Projector
Where is the reset button on a viewsonic pj4200
Hello
There is a reset button on the remote control of this set. OK.
Nov 17, 2011 | ViewSonic PJ551 Multimedia Projector
My viewsonic 3d projector won't turn...but it has
You should replace the lamp it is already damage, when you replace the lamp do not forget to reset the lamp hour meter.
Aug 22, 2011 | ViewSonic Televison & Video
Small white dots all over the screen. Looks like dust
If the dots cant be blown off the lens, or appear rectangular in shape when looked at close up, then you have pixel failure. If so, then the DMD chip probably needs replacing.
Jul 29, 2011 | ViewSonic PJD6211 Projector
My project image is flipped horizontally on the screen, but displays normally on my laptop. How do I fix my projector image?
The projector may have a menu function for flipping the image dependent on whether it is merely set on a desk, or mounted upside down on the ceiling. See the manual, printed or online.
Feb 02, 2011 | ViewSonic PJD6211 Projector
My viewsonic pj400 projector switches itself off
hello
i have the same problem, a clear image, the the projector shuts down, turn the fan on, and "lamp" blinks.
i returned my projector to viewsonic service center, they told me to change the lamp.
the problem is that a lamp is very expensive!
HudgeFR
Jul 13, 2009 | ViewSonic PJ400 LCD Projector
ViewSonic PJD6211 Projector Logo
44 people viewed this question
Top ViewSonic Office Equipment & Supplies Experts
Electro Med Services...
color wheel light...
Are you a ViewSonic Office Equipment and Supply Expert? Answer questions, earn points and help others
