Question about Epson GT-S50 WorkForce Pro
Epson gt-s50 needs power cycled after it sits or it will not scan
Epson Error Code 0x9A
0x9A Circuit error (include blowout of a fuse F1 on mainboard). Main board failure.
Mar 18, 2014 | Epson WorkForce Pro GT-S50 Scanner, 600...
We would like to connect our Epson GT-15000 scanner to our new Imac 29inch. Although we do have the scanner connected to a G5, we seem not to have any sfotware for Mac, only the Windows CD. Where can we...
No additional drivers are necessary. Your Epson GT-15000 is listed in "Printer and Scanner software available for download,"http://support.apple.com/kb/HT3669 .
To add your scanner, simply plug it in. If it does not appear in Apple Menu > System Preferences > Print & Scan, you may need to run Software Update (also from the Apple Menu, second item down), and then click the plus ( + ) button in the lower-left of Print & Scan, select your scanner, and then add the printer.
The default scanning application in OS X is Image Capture. After completing the above steps, open Applications > Image Capture and you should see your scanner listed on the left.
Aug 28, 2013 | Epson Office Equipment & Supplies
I am able to print again but cannot scan . Can someone help me ? I have the disc and have uninstalled and re installed the program...
Since you have a USB connection, try a new USB cable or connecting to a different USB port. Make sure that you have the Epson utilities and drivers for your version of Windows 7 installed. (To check if you have the 32-bit or 64-bit OS, click Start > Control Panel > System and Security > System. If the version title ends with x64, you have the 64-bit OS. Otherwise it's the 32-bit version.) You can find the drivers for printers from Epson.com. Click on the Drivers and Downloads tab at the top of the page. Then select your printer. (I've seen two versions of your request - one listed the printer as the ESP 3 and another added it was the 310. The only 310 all-in-one that I was listed at Epson was the Workforce 310. Please clarify this.)
If you installed a generic OS driver, you may only have a printer driver. Unplug your USB cable and uninstall this generic driver before attempting to install the Epson software. To launch scans by pressing the buttons on the scanner, you will need the Epson monitoring software running and the destinations for the buttons set up. Start your scans from your computer first.
Windows Fax and Scan and Paint are included in the Windows 7 software (except in the Starter version) and will acquire scans if the scanner driver is installed. Fax and Scan: New Scan. Paint: File > Import from Scanner or Camera > New Scan. Photo Gallery in the Windows Live software can also acquire scans. Trying one of these alternatives may give a better idea of what your error is.
Windows may not think a scanner is installed or a communication issue may be at fault.
I hope this helps.
I hope this helps.
Oct 12, 2011 | Kodak ESP 3 Multifunction Printer/ Copier/...
How do i scan with a tx100?
In order to scan with the that printer you must use the software provided with it.
You may have an item on your desktop labeled EPSON Scan, but if you do not then you will need to go to Start > All Programs or Programs > EPSON > EPSON Scan > EPSON Scan.
If you still have difficulties you can refer to the manual online here.
I hope this helps.
May 02, 2011 | Epson Stylus Multifunction Inkjet Printer/...
Will not scan. Error C:\ProgramFilesEPSON\escndv\es006c is displayed. Shows also ESCNDV.Exe
Do a complete reinstall.
1. Click Start, go to Control Panel, click System.
2. Click Hardware > Device Manager (XP). Click Device Manager (Vista and 7)
3. Look for Imaging Devices, right click on your Epson scanner and click uninstall.
4. Disconnect the usb cable from the printer.
5. Go to Control Panel > Add/Remove Programs (XP) Control Panel > Programs > Programs and Features (Vista and 7)
6. Look for Epson Scan and click Change/Remove/Uninstall.
7. Restart your computer.
8. Download the SCANNER software from the Epson website. If you have the disc, you can also run it.
9. Connect the usb cable back to the printer and computer.
10. Try scanning.
If that does not resolve your issue, you might need to remove Epson Scan from the Registry and reinstall the software again.
Nov 22, 2010 | Epson Stylus Multifunction Inkjet Printer/...
I need to scan A document using an epson RX425 printer how do I do it #
It depends somewhat on your OS and the software installed you have installed. With a Automatic Document Feed, the pages need to be face up and the top edge forward in the feeder. On the glass platen, put the documents face down.
Open a TWAIN-compliant scanning application (XP, Vista and Win7 all have Paint which can acquire scans). Vista and Win7 also have Windows Fax and Scan. If you installed other software (such as that which came with the scanner), you would use that - Epson Smart Panel or ArcSoft Photo Impressions. Next open Epson Scan (this doesn't work with the Mac software so look at epson.com for Mac info). This runs the scan (and any specific resolution adjustments you make). It will generally launch when you hit Scan in the application. You can run Epson Scan alone if you do not want to edit the documents right away. Click Start > All Programs > Epson Scan > Epson Scan to use Epson Scan. In the Epson Smart Panel, you would click Scan and Save to start scanning or Scan with Options to adjust the settings prior to scanning.
If the Epson Smart Panel is installed and set up for it (including having a monitor running), you can also initiate scans from the scan button on the unit. Scan problems most often occur when there is a block in two-way communication. Try a new data cable and a different port. If you have a USB hub or print server, try a direct connection. The cable should be under 6' long for best results.
I hope this helps.
Jun 10, 2010 | Epson Stylus RX425 Multifunction...
Does the Epson tx100 actualkly have a scan function? I cannot find a button or way of working it.
Hello how are you.
Yes it have scanner on your printer but to use you need to do from your pc and go to users options and there you can see to use.
Hope this good for you thank you.
Usai
Mar 10, 2010 | Epson Stylus Multifunction Inkjet Printer/...
I cant seem to find a scan option on my epson
Once all of the drivers are downloaded and the printer is connected to your computer, you can initiate a scan of a document two ways.
First, you can select Copy on the printer and it will copy the document placed on the scanner.
Second, you can scan a document to your computer by going to: Start > All Programs > Accessories > Paint.
When the Paint program opens, (in the upper toolbar) click: 'File' and scroll to 'From Scanner or Camera'. Then, select your device (Epson scanner) and click, 'OK'.
Continue with the prompts and your scan will be imported into the Paint Program. To save your scan, Click, File > Save As > (name your document) and select a folder for your scan to be sent to.
If you found this information helpful, please give me a big thumbs up when you rate my answer. Thanks.
Feb 03, 2010 | Epson Office Equipment & Supplies
Can you scan photos on the Epson DX6000 and save the image to the computor? If possible how do I go about it?
Starting a Scan With EPSON Scan If you want to scan an image and save it directly to a file, you can start EPSON Scan as a “standalone” program.
step_1.gif Place your document or photo on the scanner. See Placing Documents or Photos for instructions.
step_2.gif Do one of the following to start EPSON Scan:
    Windows:
    Double-click the EPSON Scan icon on your desktop.
    Or select Start > All Programs or Programs > EPSON Scan > EPSON Scan.
    Mac OS X:
    Open the Applications folder and click the EPSON Scan icon.
    The EPSON Scan window appears.
step_3.gif If the Mode setting in the upper right corner of the window is set to Full Auto Mode, click the Scan button. For instructions on selecting optional settings, see Using Full Auto Mode.
01.gif mark_no.gif Note: 01.gif 01.gif To change scan modes, see Changing the Scan Mode.
step_4.gif The File Save Settings window appears. For instructions on selecting options, see Selecting File Save Settings.
cj35003e.gif step_5.gif When you are finished selecting File Save Settings, click OK. EPSON Scan starts scanning in Full Auto Mode.
step_6.gif The scanned image is automatically saved in the specified location.
    If the Open image folder after scanning checkbox is selected in the File Save Settings window, Windows Explorer or the Macintosh Finder automatically opens to the folder where the scanned image was saved.
Please follow this link for same manual with screenshots:
http://support.epson-europe.com/onlineguides/en/dx6000/html_s/scan1_1.htm
Hope it helped.
Nov 22, 2009 | Epson Stylus CX6000 All-In-One InkJet...
Epson GT-S50 WorkForce Pro Logo
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
