Question about Sony Audio Players & Recorders
How do i hook up my sony vgp-sp1 speakers and subwoofer to my pc
The "dc in" prong is damaged (on the right speaker)and i took the screws out but havent been able to wrestle the speaker open to get to the prong to fix it.
  • Sony Master
  • 3,320 Answers
Opening speakers will irreparably damage it. The interior volume is calculated to provide optimum performance. For this reason they are essentially sealed with tape and are not meant to be opened.
Posted on Apr 04, 2014
SOURCE: Rattle Problem w/ subwoofer
See the rear cone, spider and voice coil junction at rest and when cone is manually lifted outward/forward.Then you can easily tell if the spider has separated, as there is little pressure needed to move the cone manually, in and out of the gap. Compare that pressure to your good sub. If there is a notable difference in physical pressure to move either cone, you can rest assured that the spider is not moving or providing resistance to cone manipulation. This is a sure sign of spider/coil joint failure and can easily be sees as you conduct these tests. If that is what you see then repair it or change with new one
Posted on Jan 25, 2008
SOURCE: help with opening them
A215 has a detachable front (grey) cover. It is attached on 4 coaks (pins). Just push a flat screwdriver under it and turn slightly - the cover will go out a little. Do it around the cover - and it will be detached. You will see 6 screws (or 4 in the left speaker). You need to unscrew them all.
Posted on Aug 07, 2008
SOURCE: How to open the case of the speakers?
this may help?
in between the bottom of the right speaker casing, theres two tones ( black and grey ). [personally i didnt care about the speakers seeing as how i got them for free.] i cut in between the two tones with a hand saw to make an opening. then used a flat head screwdriver to wedge it open which was pretty easy after an opening was created.
be wary of the volume knob cause in opening it, theres soldered wires underneath. good luck
Posted on Oct 27, 2008
SOURCE: Right speaker doesn't work
I had this very same problem and I had my system for about 2 weeks. I have seen a lot of similar posts on this site so it seems that this problems happens a lot. For some reason my right speaker just stopped working so i came to this site for help. I looked at alot of posts and nothing fixed the problem. when i switched the right speaker to the left input it started to work so I knew the speakers were fine. So i finally decided to unplug everything and restart my laptop. Once my laptop rebooted I plugged the sub back into the wall after about a minute of it being not plugged in. Then I plugged all the the wires and volume control back into the sub and turned the switch back on. Make sure the volume control is down when you plug everything back in. Then plug the wire into the device, which in my case was a laptop, and start to play some tunes. Right away everything was working perfectly fine again and no problems ever since...for me atleast.
HOPE THIS HELPS
Posted on Feb 18, 2009
sergiomc1
SOURCE: Want to use only subwoofer of HK695
The problem is that you need the satallite speakers , they have the volume control on them which thats why you only hear the subwoofer.. yes , i tried other speakers to it and no sound either.So you will need the satellite speakers it come with.. good luck!!
Posted on May 09, 2009
IS SONY SPEAKER VGP SP1 INPUT CONNECTION DIFFERENT FROM VGP SP2 SPEAKER CONNECTION
There may be many different power supplies that will work for your speaker system, but they must comply with the following:
1. The output voltage of the power supply should be correct as what the speaker system requires. (seems like 12 V in your case)
2. The specified maximum current output of the power supply should always be a higher value than the Amperage spec of the speaker system.
3. The output wires or pins of the plug on the power supply should correspond to the (+) and (-) on the power input of the speaker system.
A multimeter will come in handy to determine a power supply's output voltage and polarity.
Jan 25, 2016 | Sony Computers & Internet
I have a Sony STR-DE597 FM/AM Receiver .It has audio out plug and i have a Jensen js650 100 watt Subwoofer. how can i hook them up. Thanks.
The reason you may find it difficult to connect the Sony Receiver to the Jensen JS650 is that the JS650 does not have a line level input (RCA) to match the RCA subwoofer output of the STR-DE597 receiver. In this case, all you need to do is connect an extra set of speaker wires from the "Speaker B" Left and Right speaker connections on the back of the Sony to the speaker input connectors on the Jensen. On the front panel of the Sony, select speakers A+B settings so that the subwoofer is on in parallel with the front speakers.
I hope this answer is helpful to your home system set up.
Feb 15, 2015 | Sony STR-DE597 Receiver
VGP-sp1
just do as I did cut the cable and attach to a store bought power adapter works good. I am only using a 12v power adapter and it seems to work fantastic
May 13, 2012 | Sony Audio Players & Recorders
Ok i just got the sub from a sony sswg450 i want to know is there some way to hook it up to my Pioneer home Receiver
Did you get a manual with it? According to the Sony site this speaker originates in Sony MHC-GX450.
"This product bundle includes the following models:
HCD-GX450 - STEREO MINI SYSTEM
RM-SC3 - REMOTE CONTROL for Shelf Mini Systems
SSRG444 - FRONT SPEAKER FOR MHCGX450
SS-WG450 - SUBWOOFER FOR MHCGX450"
Find the manual here and learn a bit about your seprated sub...
http://esupport.sony.com/US/perl/model-documents.pl?mdl=MHCGX450
See page 7.
As can be seen, the subwoofer has two connections to the mothership, very unlike the standard speaker level (+/-) speaker wire or RCA-Line-Level subwoofer out that 'normal passive or active subwoofers use, respectively.
Not knowing which of those your unspecified Pioneer receiver supports, it is impossible to say. Does your Pioneer have that control jack?
Mini-systems are generally not designed to be pieced out and used with grown-up gear. The absence of standardized connections is the clue.
Apr 17, 2011 | Sony MHC-GX450 CD Shelf System
I would like to receieve the specs for this unit
Go to below website to see the specification,It is posted on the right hand side of the page
http://reviews.cnet.com/pc-speakers/sony-vaio-vgp-sp4/1707-3179_7-31768268.html
Thank you
Jan 18, 2011 | Sony VGPSP4 2 Speakers
Need connector to a sony sa-va1 right and left speakers
Are you looking for connectors on speakers or need wires that hooked in speaker and home theater system?
Please intimate model number that is written on main home theater system to provide you info about speaker wires.
Jul 11, 2009 | Sony SA-VA1 Rear Speaker
Lost instructions
The 'Subwoofer' output on your receiver is used to connect to a powered subwoofer with a built in amplifier. Your KLH speakers use what is called a 'passive' subwoofer, it gets its power from the receiver and then passes the higher frequencies to the left and right front speakers after taking out the low frequencies for the subwoofer. A speaker system with a passive subwoofer is good for casual listening, but a powered subwoofer is required for really hearing low frequencies and rumble in movies. The KLH speakers you have were highly rated in their time for their price. The four satellite speakers and center channel speaker have very good sound compared to the little 'midget' surround sound speakers most people buy today.
Here's how you hook them up:
- The left and right front channels from your receiver terminals should go to the terminals on the subwoofer marked 'From Amplifier'
- Your left and right front speakers are then connected to the subwoofer terminals marked 'To Speakers', they do not connect directly to your receiver.
- Your center speaker is connected to your receiver terminals marked 'Center'
- Your rear speakers are connected to your receiver terminals marked 'Surround'
That should get you up and running. If the bass isn't good enough with the passive subwoofer, you can get a decent powered subwoofer like the Velodyne VX-10 for about $150 and 'kick it up a notch'. Good luck and enjoy....
Jan 07, 2008 | KLH HT-9900 System
162 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
