Question about Bulova Watches
Set time croton world time watch
How do i set the time
4 Suggested Answers
slp11508
  • 43 Answers
SOURCE: can't get my croton watch to work.
There are a few possible reasons why your watch is not working:
  1. The battery is dead (sometimes even new watches have a dead battery in them).
  2. The plastic piece between the crown and the watch case was not removed (this protects the battery from wearing down until you receive the watch).
  3. You bought a watch with a damaged movement and it just will not work period so you may have to return it, exchange it, or have it repaired
These are the 3 reasons why your watch could not be working. The reason will fall into one of these 3 categories, so I hope this helps!
Posted on Jan 05, 2009
rylee_smith
  • 8619 Answers
SOURCE: reset watch
Hi
Thanks for using FixYa. You can set the time on your accurist watch by following this procedure--
TIME SETTING--
1. Push the bottom right hand button until the mode hand indicator points to TME.
2. Press and hold the upper left button for three seconds. The hour and minute hand will retract to the 12 O’clock position.
3. Select the time zone on the digital display by pressing the upper right button or the lower left button.
4. Pull the bottom right button out one click. The bottom part of the digital display will start flashing. Press the bottom left button to adjust for daylight saving time.
5. Press the upper right button. You will see the seconds flashing on the lower half of the digital display. Press the lower left button to reset the seconds to 00.
6. Press the upper right button. You will see the minutes flashing. Press the lower left button to set the minutes to your current time.
7. Press the upper right button. You will see the hours flashing. Press the lower left button to set the hours to your current time.
8. Press the upper right button. You will see 12H or 24H flashing. Press the lower left button to switch between 12 hour and 24 hour.
9. Push the lower right button back in.
SET THE CALENDAR--
1. Push the bottom right hand button until the mode hand indicator points to CAL.
4. Pull the bottom right button out one click. You will see the month flashing on the digital display. Press the lower left button to change the month.
5. Press the upper right button and the date will begin flashing. Press the lower left button to change the date.
6. Press the upper right button. You will see the year flashing. Press the lower left button to change the year.
7. Push the lower right button back in.
Please do accept the solution if the issue is resolved or else revert for further assistance.
Thanks
Rylee
Posted on Aug 31, 2009
taran_2005
  • 10515 Answers
SOURCE: Ladies watch square face. Batteries only last a
There could be many reasons for the same. Few of them are as follows :-
1. A problem in the circuitry which makes the battery to dissipate energy at a very quick rate.
2. If there is any dust or dirt on the contact points.
3. Use of cheap batteries.
These are the only possible reasons for the same.
Let me know,if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Posted on Nov 16, 2010
Where can i find the serial number on a croton ladies watch?
By removing the back of the case. The serial number is engraved into the movement. That is a pretty watch :>)
Sep 29, 2016 | Croton Watches
Battery for SP299131YLDW
You may have to open it up and find the type number on the battery.
May 16, 2016 | Croton Watches Croton Womans Brass Gold...
Have a nivada grenchen womens watch but it is not running and is missing the dial. Can it be fixed it was my mothers?
Adria it will be very difficult to find the dial and parts to get it going. YOU might be lucky if only cleaning can get it going but without a dial? Also check with manufacturer for help due to sentimental values.
Feb 25, 2014 | Croton Watches Croton Nivada Grenchen Mens...
I need to change the batteries and i cant get thhe back off
mcdevito75 here, Croton, a high quality watch, Best Bet is to look for a small watch repair shop in your area for the battery change, these quartz movements can easily be destroyed with mis-handleing and anyway a battery lasts at least 1 year.
Oct 20, 2010 | Croton 18K Classic Gold & Diamond Markers...
I lost instructions on how to set this watch can you help me? (aqua sport)
mcdevito75 here, Here is Croton"s Contact information, 800-443-7639 9 AM 6 PM EST.
Jul 29, 2010 | Croton MENS AQUAMATIC SPORTS WATCH_ BLUE...
I have a Croton watch. It is a automatic.I can't get it to run.I was informed that the watch had to be wound. The crown{stem} has four settings.I shak it and it runs for about 15 seconds
In the first position (closest to the case but not screwed down if it's a screwdown crown) wind the crown clockwise about 40 turns and it should run fine. The automatic winding system relies on wrist movement to spin a weighted rotor that winds the watch. When you're not wearing the watch or not moving much when you do have it on, it will run down and you have to manually wind it to get it going again. If you wear it everyday and are reasonably active you may never have to wind it but take it off for a day and you will.
Apr 20, 2010 | Croton Automatic Watch Day/Date Swiss...
Changing the time on the rolex, how does the button work
You can download the user instructions by going to their web site "croton.com".
Select "customer service" from the menu at the bottom of the screen,
Select "warranty and instructions" from the menu.
Move the slider on the right hand side of the screen down to the bottom and click on the icon.
A generic set of instructions will appear for their watches.
Jan 27, 2010 | Croton Ladies - LADY'S ROLEX-STYLE DIAMOND...
Can't get my croton watch to work.
Jan 05, 2009 | Croton Watches
Watches Logo
14 people viewed this question
Top Bulova Watches Experts
Geoff
Ansel Alberto
Ansel Alberto
Are you a Bulova Watch Expert? Answer questions, earn points and help others
