Please use OKI B2200 printer driver. OKIPAGE 6w is not supported natively in Vista. Do not use Plug'n'play - do it manually!
Use Windows Xp driver.
If you got this message "The parallel port driver has not been installed. Run thePrinter driver setup.exe on the setup disk to install it" There is a file called OKIPAR.DAT installed with the driver. It should be edited, changing the AddServices section as follows:
[AddServices]
StartType=3 <- Change to this. And You can print on okipage6w in vista:-)
