Question about Sunbeam 2485 MixMaster Series Hand Mixer
Need diagram for Sunbeam Hand Mixmaster #2486
Need diagram so I can put it back together. I'm having problem spring, I'm not sure what you call it, it looks like the part on wooden cloths pins.
3 Suggested Answers
SOURCE: Sunbeam hand mixer. One beater not working
That spring does not turn the beaters. It is part of the beater release assembly. Probably one of the gears is worn.
Posted on Jun 05, 2008
SOURCE: beaters
changed my mind
Posted on Jun 24, 2009
The pin that connects my kitchen aide mixer to the base. I am unable to put it back in. Something seems to be blocking y. The hole looks like it is aligned
The hinge pin is normally locked in place by a screw. If that screw is not loosened enough the pin will not be easy to put back in place.
Put the mixer on its side and look through the base. You should see the screw, Loosen it and the hinge pin can be slid into place (make sure the pin's hole in the case and the one in the head line up). Once the hinge pin is in place, tighten the screw to secure the pin.
Dec 31, 2017 | Food Mixers
Can not get second gear in my Hobart mixer
Dear anonymous
When you say you can't get 2nd gear in I assume you took out to replace grease and now you are having issues with putting it all back together. With that in mind let me tell you what you may have done. Looking at the diagram of gears and shafts side by side (found on Internet under a200 manual) you need to find the older model a200 manual. Inside the shifting yoke is a divers key and that has to fit inside the yoke then carefully put back on the shaft while depressing that inner shaft spring I think you have left this out or out of place this keeping it from going back together and your getting 2nd gear on
Feb 18, 2015 | Hobart A200 Stand Mixer
How do I tighten the speed control dial on a vintage Sunbeam Mixmaster PowerPlus?
There is a cover plate over the screw that you need to tighten. This cover plate is held in place by two spring latches, 180 degrees apart. Use a small flat-tip screwdriver to depress first one latch, then the other. Don't use too much force - the latches are plastic and will break if treated roughly.
Jan 27, 2015 | Sunbeam Food Mixers
What are the two plastic screws in the side of a kitchen aid for ?
They are the motor brushes, you do not need to fiddle about with them. Take them out again, look at them, one corner is missing from the carbon block. Look in the hole with a torch, right at the bottom there is a small blocker in one corner, line up your missing corner on the brush with the blocker and put it back together. Stop fiddling about and make a cake.
Mar 15, 2014 | KitchenAid KSM150PS Artisan Series Stand...
While putting a new handle on my mixer a small spring and small bracket in the back came off. I can't find a diagram that shows the placement of these small pieces. Is there a diagram for this area of the...
Call the manufacturer of the mixer. If it's a replaceable part they would know and they might even stock it. If it's still under warranty they'd probably replace it.
Feb 17, 2014 | Sunbeam 2360 Deluxe Mixmaster Mixer
Mixer won't turn on
Just recheck that you really have put the brushes back in the right way, use a torch and look in the hole. The brushes can each go in 4 ways, only one of which will work. Look for the blocker and line it up with the cut off corner on the brush. It's normally at the back, one side at the top the other at the bottom. After that you need to be looking at everything you have done for a booboo. I doubt it will be water ingress. Make sure the switch contacts come together when the lever moves to position 1.
Mar 18, 2017 | KitchenAid KSM90 Ultra Power Series Stand...
Mixer won't turn on. I had the pin problem everyone describes. Finally was able to get the pin back in with some serious hammering of the pin and then tightened the set screw on the bottom. Fabulous!...
They are the brush springs. The brushes get caked up with burned flour. Remove the brush caps and pull the brushes out by their springs, being VERY careful to note the position of them since they only go back in one way. Measure the free length of the spring before pulling it out. It is critical that you write down the length sticking out with very slight pressure on it so that it is seated against the armature when you measure.
Clean the curved surface of the carbon brushes with a sharp knife being careful not to scratch the curved surface. If you have them installed wrong they will not go all the way in and will not contact the armature and it will not run. Measure the length, as done above, of the spring to make sure it is in correctly!! If it is not in correctly the spring will stick out 1/4 inch longer than it should.
Apr 17, 2010 | KitchenAid KSM150PS Artisan Series Stand...
KichenAid mixer parts problem
http://shared.whirlpoolcorp.com/assets/pdfs/literature/Repair%20Part%20List%20-%208212057.pdf
has a diagram of the locking mechanism item 9. The screw you removed was probably item 8. Look at the parts and you should be able to figure out how to get it back together.
Mar 27, 2010 | KitchenAid KSM90 Ultra Power Series Stand...
Sunbeam 2485 MixMaster Series Hand Mixer Logo
61 people viewed this question
Top Sunbeam Food Mixers Experts
Oloyede Monsuru
Oscar Netto
Oscar Netto
Are you a Sunbeam Food Mixer Expert? Answer questions, earn points and help others
