Question about Westinghouse LTV-32w3 HD Television
Westinghouse 32" Model No. SK-32H2405 plays 10-15 Min, then begins rolling and/or patchwork; sometimes corrects after 30+ min, mostly not.
Most of time must turn off for 30+ min and restart. Sound OK.
Ajkill
  • 2035 Answers
SOURCE: Westinghouse LTV-32w1 32 in. HDTV-Ready
The fly back unit as failed resolder the flyback side,most of problem is cause by loose contact only, or if your not tech person need to get it serviced it would cost 50 $ to 100 S.............
Posted on Jun 08, 2008
SOURCE: Westinghouse SK32H240S 32'' LCDHDTV Picture appears and Disappears
This problem is caused from a problem with the main board. The main board will need to be replaced. It runs from $100.00 to $150.00.
Posted on Jun 10, 2009
  • 1779 Answers
SOURCE: Westinghouse 32" TV randomly shuts off
It is a good possibility that you have 1 of your inverter transformers going bad. I wouldn't wait to have it looked at. It can cause more damage if the bad one let's go all together.
Posted on Oct 01, 2009
SOURCE: I have a westinghouse tv model number SK-32H240S no picture
It seems that your unit has some sort of Video side, PSU fault, or a problem to the Video section that is shutting down the Power Supply Unit, PSU. This happens so that no further damage, and possible fire will occur.
You need to take the unit to a reputable service centre/man and ask for a firm "Quote" for the work to be done.
Posted on Jan 21, 2010
  • 16 Answers
SOURCE: TV Turns on picture comes on for 30 seconds then
This is not the fix for this TV. I guarantee that none of the capacitors exhibit the common bulging characteristics of a faulty capacitor. The common answers to everyone's questions are to replace the capacitors. Most likely the culprit is the inverter board.
Posted on Mar 23, 2010
Westinghouse dishwasher sb916sk runs 22 minutes then cuts power
Is it on a dedicated circut? A dishwasher needs to have a 12Ga two conductor with ground line that is dedicated to ONLY the dishwasher and possibly share with the garbage disposal.
Also, it should be on a 20 Amp breaker.
Mar 11, 2014 | Westinghouse Dishwashers
5 yr old Westinghouse TV w built in DVD player. DVD player won't play. Tried several different movies, none will play.
First thing I would check is that you are playing regular DVDS and not BluRay. Your TV may be old enough not to accept BluRay. If it doesn't work with a regular DVD then you most likely have a bad reader which can be replaced but you will have to take the tv apart to get to it.
Dec 12, 2013 | Westinghouse Electric SK-32H570D 32 in....
My tv turns on and works well for about 30 min. During those 30 min the picture will blue-green pixelate all bright colors and whites. I have sound and such but lately it has been starting to cut out (may...
What ever you have hooked to it may have a ground fault. I would replace the cables Iam using first or try a device that you know works good somewhere else and if it does the same thing it is the tv or the cables
Jun 21, 2011 | Westinghouse SK-32H240S Television
I have a Westinghouse SK-32H240S 32" flat screen
First when tapping changes the picture you have somewhere a bad connection; in electrical board or wiring.
When the screen goes blank after a while means some capacitor is bad/old.
Mar 13, 2011 | Westinghouse SK-32H240S Television
Westinghouse sk-32h540s TV, VGA input, image can't center.
Hello, two things, one try using the TV with the native resolution of 1366 X 768, and secondly try updating your video card. If you are not having this issue with the TV on the other inputs than most likely it is a settings issue with the laptop. Please rate this comment if it was helpful.
Apr 06, 2010 | Westinghouse SK-32H540S 32 in. LCD TV
Westinghouse 32" lcd tv model # sk-19h210s won't turn on
Try unplugging it . Wait a few seconds and plug it in again.
Mar 23, 2010 | Westinghouse 32" Flat Panel LCD HDTV
Can't progam my direct tv remote to operate my westinghouse 32''tv
I don't have DTV anymore, so I don't remember the exact code I used for my SK-32H240S, However, I do remember that I found one that worked at this site. Scroll down to locate your remote series # - it most likely will be printed on the upper left corner of the front of the remote - as an example, mine says RC64. Click on the corresponding listing, then follow the directions on the site. I tried only a few codes before finding one that worked correctly. Good luck.
Dec 27, 2008 | Westinghouse SK-32H240S Television
Rolling screen
Ahh the old rolling picture problem. If this set has a Picture in picture feature, your problem is on the PIP module itself. There is a kit of surface mounted capacitors that need to be replaced If you have some soldering skills you should be able to do this your self, but if you do not, I advise you to get someomne who does as most of these PIP modules are not available any longer. The kit can be purchased from http://www.mcminone.com/search.asp?keyword=Mitsubishi+PIP+kit&btnSubmit.x=6&btnSubmit.y=7 Good Luck
Mar 28, 2007 | Mitsubishi WS-65413 65" Rear Projection...
Televison & Video Logo
23 people viewed this question
Top Westinghouse Televison & Video Experts
Jaime Hernandez
Are you a Westinghouse Televison and Video Expert? Answer questions, earn points and help others
