Question about Husqvarna Sewing Machines
My Viking 6370 squeaks when I sew
Why does my Viking 6370 squeak when I sew.
  • 43 Answers
SOURCE: Where do I oil the sewing machine?
OILING
FACTORY LUBRICATED PARTS WILL PROVIDE YEARS OF HOUSEHOLD SEWING
WITHOUT ROUTINE OILING. HOWEVER, WHENEVER THE MACHINE tS BEING
SERVICED, CHECK TO SEE IF ANY PARTS NEED TO BE LUBRICATED.
OIL
APPLY GOOD QUALITY SEWING MACHINE OIL TO THE POINTS (A, B, C, D, E)
INDICATED BY BLACK ARROWS.
GREASE
WHITE GREASE IS RECOMMENDED FOR USE ON GEARS AND CAM SURFACES.
IT IS AN IMPROVED GREASE, AND IT CAN BE USED ON THE METAL AND PLASTIC
PARTS WHICH POINTS ARE INDICATED BY THE WHITE ARROWS (F,G, & H).
HOW TO ORDER
PARTS NO.
EM / 40M
DESCRIPTION
SEWING MACHINE OIL
WHITE GREASE
Posted on Apr 12, 2009
  • 980 Answers
SOURCE: Hand wheel on Kenmore model 1345 sewing machine
Take the bobbin and bobbin case out first of all and check for any minute pieces of thread stuck, lightly poil with WD40, find out where the squeak is, very important otherwise the machine may seize and it will cost a lot of money, oil all moving parts lightly
Posted on Jun 27, 2010
sewinsnap
  • 135 Answers
SOURCE: new sewing machine is squeaking
YOu may have bent the needle. Put in a new needle and re-thread the whole machine. See if that works.
Posted on Aug 19, 2010
hazelgrace
  • 340 Answers
SOURCE: My Singer overlocker is making a squeaking noise
Try contacting Singer, maybe they can email you a diagram for oiling your overlocker.
http://www.singerco.com/company/contact_us.html
Posted on Sep 04, 2010
Tally Girl
  • 1122 Answers
SOURCE: it squeaks when u sew.
Squeaking or popping sounds could be a blunt needle so make sure you change it regularly, 4-6 hours sewing time is rule of thumb.
To find where to oil this machine download the manual from http://www.singerco.com/accessories/manuals.html, just type in your model number into the search field and click 'Search', most of the manuals are there as a downloadable pdf file.
The manual will show oiling points for your machine. Use sewing machine (clear) oil only, a little drop only but oil and clean regularly to get the best performance. Brush out any lint and dust first (don't use compressed air to blow a machine out, much better to brush out carefully with a little brush and remove the lint from the machine).
You can also put a drop of oil onto a piece of waste fabric then rub this up and down the needle bar (the metal part that goes up and down holding the needle) to keep this clean and lubricated.
Posted on May 05, 2011
Husqvarna Viking model 6370. Where can I buy a bobbin case?
Try a Viking dealer store. One can also be purchased online from some of the sewing machine vendors.
Feb 26, 2016 | Sewing Machines
Husqvarna Viking rose 605, Embroidery Arm not working
SORRY but when we have no make model listing we can not help look for problem
Jan 17, 2016 | Sewing Machines
I AM LOOKING FOR A MANUAL FOR A Husqvarna SEWING MACHINE mODEL 6370
It's easier to download one. Here is one website, but I'm sure they have them on ebay.
http://www.sewingmachinemanual.net/Sewing_Machine_Manuals/viking/Viking_6370_Instruction_Manual.htm
Mar 03, 2015 | Husqvarna Sewing Machines
Ok go
have an authorized Viking repair dealer check it out it be one of several easily fixed problems.
May 13, 2014 | Husqvarna Sewing Machines
Squeaking husqvarna 445
You do not oil Viking machines.
Apr 12, 2014 | Husqvarna Sewing Machines
Husqvarna making squeaking noise
try changing the needle
try a different bobbin--make sure the bobbin is turned the right way
in the bobbin case
also try a different thread
make sure the top has not come off the thread take up lever
also the machine may have a timing problem and need to be
serviced
Dec 08, 2012 | Sewing Machines
New sewing machine is squeaking
Jun 28, 2010 | Husqvarna Viking 1
Squealing noise Husquvarna 3310 sewing machine. Still sews ok but noise must be harming the machine. Anyone know what I can check?
My Designer 1 started squeaking recently and, like you, I was concerned even though it sewed like usual. I emailed my tech. and he suggested either feed lifter mechanism or feed cam were the most likely causes - simple to repair but I would need to bring machine in for him to hear because there could be other reasons for the squeak. Well I did not have time to go then and there. Next day when I sewed, the squeak was gone!
At the time it squeaked I was sewing through several fairly thick layers (making a pot holder) and sewing very slowly. The next day I sewed normal cloth at normal speed but no matter how slowly I sewed, I could not get it to squeak. I will get it checked eventually but as long as it is squeak-less I'm not going to be concerned.
If yours squeaks all the time no matter what you are sewing then, yes, I think you should get it looked at. Be sure that nothing is rubbing against the body of the machine i.e. accessory tray and making the noise.
Sep 28, 2009 | Husqvarna Viking 1
Squeaking huskylock 905
The internal cams need lithium grease. You might want to take it to an authorized husqvarna viking dealer for service. You can locate a dealer near you by visiting the husqvarna viking website and clicking on the Dealer link on the left-hand side of the page - http://www.husqvarnaviking.com
Good luck.
Jan 10, 2008 | Husqvarna Huskylock Computerized 910
Sewing Machines Logo
19 people viewed this question
Top Husqvarna Sewing Machines Experts
Douglas Plant
Douglas Plant
Tally Girl
Tally Girl
Derek Massey
Are you a Husqvarna Sewing Machine Expert? Answer questions, earn points and help others
