Question about Sport & Outdoor - Others
Instructions for Noma TM1702 outdoor timer
Hi. Cannot find instructions how to set outdoor heavy duty timer (for our pool). Thank you
SOURCE: lost instuctions to program Model N1560 Noma outdoor timer
Use the top button to adjust the current time & then push the bottom button once to save. Next is the time you want the lights to turn on & push bottom button once to save. The last setting is the time you want the lights to turn off. Don't forget to use the . (period) indicator for the pm setting. (I had the same problem and had to search the net to find someone else who had posted the instructions.)
Posted on Dec 14, 2008
SOURCE: I have a noma outdoor timer N1506 I lost the
Normal 0 MicrosoftInternetExplorer4 st1\:*{behavior:url(#ieooui) } /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0cm 5.4pt 0cm 5.4pt; mso-para-margin:0cm; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} 1- Plug in the timer.
2- Set the time of the day (on the hour, example. 2. Pm) using the top TIME button. For pm there will be a dot to the lower right of the 6.
3- Once the time is set push the MODE button, this will replace the 6pm with a flashing P.
4- Push the TIME button again to set the time you want the timer to come on. (Remember for 6pm there will be a dot to the lower right of the 6.
5- Push the MODE button once the desired time is set, an E will appear.
6- Push the TIME button again to select the time you want the timer to go off (example 10.pm).
7- Push the MODE Button again. The time of day 2. (Pm) will be displayed. If the timer loses power just repeat the above steps.
Posted on Dec 07, 2009
  • 3 Answers
SOURCE: Westinghouse 3-Outlet Outdoor Heavy Duty Digital Photocell Timer
http://www.thencc.com/westinghouse/LS/Instruction/28499_TimerManual.pdf This is the manual that you seek!
Posted on Jan 06, 2010
SOURCE: I have Noma outdoor timer
Page showing UPM timers including ET525C outdoor.
http://waterheatertimer.org/UPM-timers-and-manuals.html
Manual for ET525C
http://waterheatertimer.org/pdf/UPM-ET525C-heavy-duty.pdf
Posted on Nov 27, 2010
SOURCE: instructions for NOMA N1507 timer for programming -pls.
N1507 manual:
http://waterheatertimer.org/pdf/N1507-programmable-outdoor-timer-manual.pdf
Add a comment and let me know if these instructions are accurate
Posted on Dec 05, 2010
Noma Timer Model #ET525C - Require Instructions
ET525C is UPM timer
UPM ET525C Manual
Instructions are 14 pages. It is impractical to re-write 14 pages of instructions.
If you have a problem, add a comment and say exactly which programming you want to set, and I will respond.
-Timer can be programmed for ON and OFF times, for Dawn-Dusk, for Countdown, for Daylight countdown, for daylight saving, and for Random. Each different programming option has 8-12 steps shown in manual.
Nov 28, 2010 | Solar Noma 7 Day, 6 Event Outdoor Timer -...
How do you set a older outdoor noma light timer only 2 buttons
Hi.
See the instructions below in PDF format, instructions are for Noma two buttons heavy duty outdoor timer. Some model may be different in shape:
24-Hour Heavy Duty Outdoor Timer
Regards.
Ginko.
Jul 21, 2010 | Home
How to install and set timer tm1702
TM1702 is a Woods timer
http://waterheatertimer.org/Woods-timers-and-manuals.html#1702
If link above does not show your timer, then add a comment with description of timer.
I have extensive files on timers and can probably identify the timer.
Instructions according to TM1702 manual are as follows:
Maximum load 500 watts, used for indoor or outdoor
Set current time, rotate dial until current time lines up with black triangle.
Around outer edge of dial are segments.
Pull up all segments for times you want timer OFF
Leave segments down for times you want timer ON
Locate switch on timer.
Push switch toward the 'V' shape that is pointed down.
(Some timers do not have the switch mentioned above)
Plug timer into wall outlet, plug lights into timer.
Lights must be turned on.
If above instructions are incorrect and you don't want to add a comment or identify timer further, then you can take advantage of fixya phone support.
Fixya expert will walk you through the steps for a price.
May 22, 2010 | Woods INDUSTRIES 59383 OUTDOOR MECHANICAL...
Instructions on woods outdoor timer wth pins
go to Woods heavy duty timer and there is three tabs below the advertisement, one will say "specifications" and at the bottom of the tab page is instructions in green highlight. use the instructions given for pin timer , it works on earlier models as well.
Dec 12, 2009 | Woods INDUSTRIES 59383 OUTDOOR MECHANICAL...
Sport & Outdoor - Others Logo
628 people viewed this question
Top Sport & Outdoor - Others Experts
Marvin
Marvin
Bill Eager
Are you a Sport and Outdoor - Other Expert? Answer questions, earn points and help others
