Question about Husqvarna New Combination Trimmer 128DJX
How do I remove string trimmer head to install blades
String trimmer head
steve_lima
  • 181 Answers
SOURCE: what are the timing specs on a Husqvarna 36-r string trimmer
there is no timing spec . the air gap is .010 to .012. or .254 mm to .305 mm.open the gap all the way up and tighten the screws.bring the flywheel magent to the coil making sure that both sides of the coil is on the magnet.slide the gapping tool in and the magent will hold it in place.once it's there release the screws holding the coil and the magents wiil pull the coil to it.once it's there retighten the screws and your done.
Posted on Mar 12, 2009
  • 42 Answers
SOURCE: Husqvarna 324LDx 4 cycle string trimmer. Have
Probably needs a carb kit, check main jet and main fuel inlet jet, is the spark crisp, fat and powerful, try running it with a borrowed coil as this may have an intermittent fault. Is fuel cap breather working or blocked, these small carbs are very sensitive. Make sure all is well with gaskets and diagrahms. Good luck the Yeti
Posted on May 17, 2009
SOURCE: how to change blades
Use a large pair of pliers to hold the turning metal ring above the T35 trimmer head. I used a medium-sized pair of Channel Lock pliers. Then, turn the trimmer head counter-clockwise and it should unscrew from the mount. There's no need to open the trimmer head for this operation. Then, follow the parts diagram in the trimmer user manual to install the blade parts in the right order.
Posted on Jun 08, 2009
  • 81 Answers
SOURCE: Homelite trimmer runs, but can't run attachments very fast.
Doesn't sound like piston and ring problem. Sounds more like the flex shaft that connects to the engine may have an end that is worn not allowing for the extra load when you connect the attachments. Check the ends of the top flex shaft.
Posted on Jun 19, 2009
MNfisherman
  • 11896 Answers
SOURCE: removeing string head assembly
Pry the plastic cap off, then you will have access to the bolt. Other kinds have a nut that you unscrew. If you are just going to restring it, you can push in and turn the head for it to come off.
Posted on Jun 27, 2010
How to transfer from the string to a blade
There is a nut in the center. It likely unscrews backwards for removal of the string and install of the blade.
May 31, 2015 | Garden
I purchased an 8 inch heavy-duty brushcutter blade for my Ryobi 30 cc four cycle powerhead how do I attach it to the string trimmer head
You can't use the blade on most string trimmers unless you have a brush cutter style then you would unscrew the trimmer string head and attach the blade with the adapter that came with the unit.
Oct 23, 2014 | Garden
How to feed trimmer line on y25 yard trimmer gas
Depending on what type of string head you have. If it's a "tap and go" style head, just rev it up full throttle and tap it on the ground. It should feed the string out and the blade on the shield will cut off the string to the correct length.
Sep 22, 2012 | Yard Machines Gas String Trimmer Y25
I have a Echo Gas trimmer SRM-210 Rapid feeder dual line. I need to know how to remove the entire drum for the string spool? NOT how to re-string but how to replace entire head/spool, as if I was going to...
In your manual under section 12: Line Head Installation. You will do the opposite of what it says here. The key is to LOCK the gear drive so the flex-drive shaft won't turn WHEN you are removing the trimmer head. They use a special tool (maybe you have it). But a small-shafted Phillips screwdriver or the like can be put in the drive hole to lock the gearing up as well. Look for the hole in the upper plate and align with the notch in the drive housing and grasping the entire string head unit, remove it. Here is your manual, see Section 12
http://dl.owneriq.net/8/854215d5-44e4-4b5d-b773-77b331fd73b3.pdf
Jul 17, 2011 | Echo Rapid Loader, Trimmer Head
HOW DO I INSTALL A NEW STRING IN A PRO CUT 11 for Ryobi RLT30CD trimmer
LINE REPLACEMENT (Fig. 8) (For Reel EasyTM Head) Use 2.4mm monofilament string. Use original manufacturer's replacement string for best performance. n Stop the engine and disconnect the spark plug wire. n Cut one piece of string approximately 7.6m in length. n Rotate knob on string head until line on knob aligns with arrows on top of string head. n Insert one end of string into eyelet located on the side of the string head and push until string comes out through eyelet on the other side. Continue to push string through the string head until the middle section of the string is inside the string head and string outside the string head is evenly divided on each side. n Rotate the knob counterclockwise on the string head to wind the string. Wind the string until approximately 20cm remains protruding from the string head. INSTALLING STRING IN PRO CUT II STRING HEAD Use monofilament string between 2.4 mm and 2.7 mm diameter. Use original manufacturer's replacement string for best performance. n Stop the engine and disconnect the spark plug wire. n Gather two of the pre-cut lengths of trimmer line provided or cut two pieces of trimmer line, in 28 cm lengths. n Insert the strings into the slots located on the sides of the string head. String should be pushed in until approximately 2 cm protrudes from the holes on the top of the string head. n Remove old string by pulling it from the holes located on the top of the string head. http://www.screwfix.com/sfd/i/cat/pdfs/89/p4763889.pdf
Oct 29, 2010 | Ryobi 30 Cubic Centimeter Curved Shaft Gas...
Installing a blade and need to remove the head assimble
For safety sake and proper installation of a blade, please see p. 21 of this safety manual.Read carefully;
http://dl.owneriq.net/6/69340357-bb10-44af-b005-20afbe8f5125.pdf
For installation procedure, please see section 9:
http://dl.owneriq.net/a/a19727c4-b4e6-466f-8b8e-635e716636c1.pdf
The instructions state that the string head is fastened with a left-hand threaded nut (turn left to tighten and right to loosen). This may be the reason you are having problem removing the head.
Oct 18, 2010 | Echo Rapid Loader, Trimmer Head
How do i install the blades on my weed eater so i dont have to use string anymore
There are many options out there but pretty much all of them require you to completly remove the line trimming head and screw on an aftermarket device. I use the bruch hog, the line trimmer and one with three nylon blades that are replacable (from Menards) and all work well but you do have to replace the blade too so it will not be the end all. If you are going through a lot of line may I suggest you run the trimmer at about 1/4 speed or just enough to do the job, it really saves a lot of line and frustration.
Jun 03, 2010 | Poulan 25cc 2-Cycle Gas Powered String...
Require Manual for Ryobi PTL 2543 25cc line trimmer
Or sometimes you unscrew a retaining bolt set into a plastic "lug", the spool drops out, refill t with line, replace it putting line through holes in the spool casing, refit the "lug" and tighten it again. I think I have the manual for this though and if so maybe I can send you a link to images on MSN Homepage to help you..
Feb 22, 2009 | Ryobi 15" Electric Factory Reconditioned...
Husqvarna New Combination Trimmer 128DJX Logo
20 people viewed this question
Top Husqvarna Garden Experts
Jim Parker
Jim Parker
Phil Walker
Phil Walker
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
