Motor nit functioning properly
SOURCE: replacing batteries in a 6705x norelco shaver
To open up your shaver, remove the lotion cover and remove all 5 screws
with a small flat head screwdriver. They have a star head, but also a
flat notch. Since they shaver is water tight, the first time you open
it up it will be difficult, but if you pry off with your screwdriver it
should pop off.
Towards the head of the shaver the batteries are soldered to the
circuit board. Pull the tail end of the batteries out of the plastic
holder and cut them at the top end as close to the batteries as you
can, or CAREFULLY bend it back and forth to snap the metal. Dispose of
the batteries responsibly as you would any batteries.
Hope it helps you.
SOURCE: How to replace batteries in Norelco 6826 XL
Amazon has a number of reviews that tell how to do this. See
http://www.amazon.com/Shaver-Battery-Norelco-models-others/product-reviews/B000FP63M4/ref=dp_top_cm_cr_acr_txt?ie=UTF8&showViewpoints=1
SOURCE: Replacing Heads for 8140XL Norelco shaver
Same thing happened to my father's shaver. After working on it for about 30 mins, this is how I fixed it. You need to start with the top silver piece/cover. Turn it over so you see inside of it. Drop the 3 screens into the holes upside down (so they face out). You need to rotate the screens until they sit as low as possible. Now drop in the 3 blades, again sharp side down. There should be a triangular piece with 3 circles attached to it. One side is gray, and the other side has a black triangular piece. If you look closely each leg of the black piece has a tiny picture of a lock and an arrow. Rotate the black piece in the opposite direction of the arrow. Place the gray side down lining it up with the three blades. Now rotate the black piece, it will lock into position, and hold the blades in place! Finally, the silver head has a little hinge on one side. This hinge is flexiable. Bend it to a 90 degree angle, and slip it into the notch on the top part of the main body of the shaver. Close the head part, in my father's shaver I had to press a lever in the front to snap it into place.
Hope this helps!
SOURCE: where can i find replacement heads for a norelco
The type of heads you need have been discontinued by Norelco for several years. It would be virtually impossible to fing a new set made by Norelco.
There is an aftermarket version available. You will find these at shaveroutlet.com. See link below.
http://shaveroutlet.com/norelco-philips-1912-3-type-heads-also-fits-remington-and-more.html
