Question about Cellularline Interphone Motioncam01
Will not charge
Will work when connected to charger but shuts off when disconnected
Is the charger to be "on" while charging it; then on while hooked to battery?
The portable charger should NOTE be connected to a battery while the battery is connected to a vehicle! Charge the battery off the car, then disconnect the charger and put the battery into the vehicle to start it! If the charger is not working check the fuse! If that is ok then probably damaged the circuitry!
Jan 02, 2015 | Cars & Trucks
I have got apple macbook pro unibody , my charger light is blinking and not charging battery while my laptop is on but when i shut down my laptop its connecting and disconnecting for 10 seconds interval
Try charging your laptop with a spare charger. If your laptop is still under warranty, make an appointment with a genius bar representative at a local Apple store to diagnose your laptop's issue and replace the charger.
Warning!
Do not use the USB ports to charge any external devices from your laptop! Instead use the chargers they were packaged with.
If the spare charger doesn't work after an hour of charging you will have to reset the System Management Controller with the Mac turned off:
Press Shift-Control-Option-Power key combination.
Release and press the power button.
If resetting the SMC doesn't work try resetting the PRAM. Keep in mind that you have to enter the key combination before the grey screen appears!
Reboot your laptop.
Immediately hold down Command-Option-P-R combination.
A reboot sound should confirm the reset.
Aug 26, 2013 | Apple MacBook Pro Laptop Computer with...
Works when connected to charger but no power from battery changed battery still the same
if you disconnect the charger and the battery died then that means that your laptop battery is broken and it won't work untill you get a new one.
Apr 10, 2012 | Panasonic Toughbook CF-27 Notebook
Battery will not charge.plugged in not charging
Does the computer start anyway, but it's just that the battery won't charge? If that's the case, it's probably a bad battery.
A procedure to do before assuming a bad battery is to (1) remove the battery, (2) disconnect the power supply from the computer, and (3) press and hold the power button for about 30 seconds. This resets the logic circuits in the internal power handling section. If that doesn't help either, then the battery is probably bad.
If the computer isn't starting, however, it could be that the power supply has failed. Check the voltage output on the power supply.
Hope that's helpful.
Jan 12, 2011 | IBM ThinkPad T30 2366 Notebook
Hello my laptop isn't charging properly. It is plugged in and all of the cables are connected. There is power in the plug socket but it doesn't seem to be charging. Help!
Hi! Drain the power charges of the laptop by shutting it down and by unplugging both ac adapter (charger) and battery from the computer.
Press the power button for like 10 times while the battery and charger is disconnected to drain the power of the board.
connect back the battery first then connect the charger to the computer. Make sure that the charger is connected to a stable power outlet while charging the system.
Please leave a comment if you have any other questions.
Cheers!
Jun 10, 2010 | Computers & Internet
My samsung phone has been fully charged. I try to turn it on, it says "initializing," then shuts down. When unplugged, it won't turn on at all. When plugged in, it shuts down, then blinks to the charging...
Are you sure it was fully charged before? Could you see the full battery bars?
It sounds like your AC adapter (the charger) has likely gone bad. The phone battery probably wore down, and when you plugged it into the charger, the charger couldn't charge it, so the battery remained dead.
Since the battery is not charged, you can't turn the phone on at all when it's not connected to the charger. And when you do connect it to the charger and turn it on, you get the intermittent charging because something inside the adapter has a faulty connection -- sometimes it works, sometimes it doesn't.
You can easily verify if the charger is the problem by getting a new charger (they're not too expensive) and seeing if the phone will work and/or charge with the new charger.
If the new charger doesn't fix the problem, post again here and we'll go from there, but I think the new charger will take care of it.
Hope that helps!
Jan 13, 2010 | Samsung SCH-u550 Cellular Phone
7200t thinks it's connected to computer when charging
Bad charger - not powerful enough, Use a Gomadic charger with tip # 24. Works for me.
Aug 29, 2009 | Navigon 7200T GPS NAVIGATOR PERPW/ FREE...
My Sony Vaio PCG-z1wa suddenly shuts off if the battery is not attached. In other words, I have to be constantly charging the battery or it would shut off all of the sudden. It obviously seem like it is an...
there are a lot of cuase on auto shut off the laptops..
posseble if..
1. if the battery not inserted on laptop... it means you using the charger when you disconnect or loss the connection, auto shut off.
2.if the battery inserted and full of charge.. then make auto shuto off.. this problem,, sometime overheating,, A. fun not working properly..B. shortage of cheps.
try to check the charger and battery,,, use another charger to test observe atlest 30minuts.. the problem the sam auto shut off.. check the cpu fan.. or processor
note" if under warranty don't open it. bring to warranty..
May 31, 2009 | Sony VAIO PCG-Z1WAMP1 Notebook
Phone does not charge
When my phone is connected to the charger, it says fully charged. But as soon as I disconnect the charger, the battery shows empty. When I connect the phone to the charger, it starts charging but after 10 seconds it says fully charged.
Aug 08, 2008 | Sony Ericsson K600i Cellular Phone
Cellularline Interphone Motioncam01 Logo
388 people viewed this question
Top Cellularline Measuring Tools & Sensors Experts
Vuk B
Tom Chichester
Are you a Cellularline Measuring Tool and Sensor Expert? Answer questions, earn points and help others
