Question about Onkyo Remote Control RC-764M p/n:24140764
How to reset the onkyo RC-764m remote
Tow to change id
5 Suggested Answers
  • 239 Answers
SOURCE: remote code for sony playstation 3
you cannot control a ps3 with that remote because the playstation 3 only works with bluetooth. I'm sorry to have to tell you. you can purchase a remote that works with your system at any that sells your system.
hope this helped
please rate well.
Posted on Mar 06, 2009
dunnbiker
  • 8546 Answers
SOURCE: Need Remote Codes
The manual on Page 10 says that with these modes (DVD,CD,MD,CDR,HDD) on the Remote you can control an Onkyo DVD player and CD/MD/CDR/HDD player/recorder.
For DVD, on page 12, it says to just push the DVD button (top right) and the following buttons will functions as stated.
ON/STANDBY button
This button sets the DVD player to On or Standby.
Number buttons
These buttons are used to enter title, chapter, and
track numbers and to enter times for locating specific
points in time.
DISC +/– button
This button selects discs on a DVD changer.
TOP MENU button
This button is used to select a DVD’s top menu.
Arrow [UP]/[DOWN]/[LEFT]/[RIGHT] & ENTER buttons
These buttons are used to navigate DVD menus and
the DVD player’s onscreen setup menus.
RETURN button
This button is used to exit the DVD player’s
onscreen setup menu and to restart menu playback.
Playback buttons
From left to right: Pause, Play, Stop, Fast Reverse,
Fast Forward, Previous, and Next.
SUBTITLE button
This button is used to select subtitles.
AUDIO button
This button selects foreign language soundtracks
and audio formats (e.g., Dolby Digital or DTS).
DISPLAY button
This button is used to display information about the
current disc, title, chapter, or track on the DVD
player’s display, including the elapsed time, remaining
time, total time, and so on.
CLR button
This button is used to cancel functions and to clear
entered numbers.
MENU button
This button is used to display a DVD’s menu.
SETUP button
This button is used to access the DVD player’s
RANDOM button
This button is used with the random playback function.
REPEAT button
This button is used to set the repeat playback functions.
PLAY MODE button
This button is used to select play modes on a component
with selectable play modes.
Posted on Apr 03, 2009
SOURCE: Onkyo remote won't control Samsung components.
I got an Onkyo RC-717M remote control. It is the remote that comes with the Onkyo TX-SR706 receiver. It is a learning remote. When i entered the cde for the Samsung Blu-Ray it did the same thing as the other remotes I got from Onkyo, the pause, next / previous track buttons wouldn't work for the Samsung BD-P3600. I used the learning function of the new remote and programmed it to work. It works ok now but it sure was a hassle to get it done. In fairness i should have called Onkyo support but their support hours don't match my schedule.
Posted on Sep 13, 2009
mlapres
  • 757 Answers
SOURCE: The Vol button on my Onkyo RC-588M remote doesn't work
It probably can be fixed. Dirt and such gets on the contact pads...take it apart by carefully unscrewing it and remove the top half with the buttons facing you. You will likely see that the buttons are made of molded sheet of silicone, lift that off. Beneath where the mold was for the volume control you will see the actual buttons that control the volume, inspect it to see if it simply got pressed down too far and try to operate it that way and clean anything that needs it while you have it open. If it works without the silicone button cover panel on it, then you can take a small peice of paper wad and tuck it into the mold for the volume button so that when you press on it, it always makes contact.
Posted on Dec 14, 2009
Can you use an Onkyo RC-771M remote control to operate Onkyo receiver TX-SR502 ?
Unfortunately, the RC-771M remote doesn't control the TX-SR502. It will only work with these Onkyo models: TX-NR1008 and TX-NR808. The RC-567M is the one for the TX-SR502; replacement remotes that are exact replacements are still available from various places including Amazon.com .
Since the TX-SR502 was released in ~2004, that replacement remote probably won't control other devices that were released in 2004 or later. Onkyo changed its IR code programming before the TX-NR1008 was released in ~2010 and the RC-771M can't communicate with the older receiver. The manuals for the receivers listed above are still available from Onkyo on the product page under the Downloads tab.
I wish that I had better news for you.
Jan 31, 2016 | Onkyo TX-SR502 Receiver
Tip
Onkyo RC-682M Remote Codes
Download Onkyo RC-682M Remote Codes
4 Digit Onkyo Remote Codes
Models: RC-682M / TX-SR605 / TX-SA605 / TX-SA8560
Have you misplaced your Onkyo RC-682M Remote Owners Manual?
Would you like a digital, searchable, pdf version of the Onkyo RC-682M Remote Users Guide?
Follow this link to download a pdf version of the operations manual.
I hope that helps.
_________________________________________
Download Onkyo TX-SR605 Users Manual Here.
on Apr 20, 2010 | Onkyo TX-SR605 Home Theater Receiver 7.1...
Tip
I hope that helps.
on Apr 20, 2010 | Onkyo TX-SR605 Receiver
How to reset RC-569M remote controller to factory defaults.
Not sure if it's the same, but for the Onkyo RC-799M controller the reset sequence is:
To reset the remote controller to its factory defaults,
while holding down RECEIVER, press and hold down
HOME until the remote indicator lights (about 3
seconds). Within 30 seconds, press RECEIVER
again.
Jan 05, 2015 | Onkyo Audio Players & Recorders
Will remote control rc-764m work onkyo tx sr605 7.1
If it has set-up code/s to Onkyo, you can. If you wish to get more; check the sites linked here. It has set-up code list & set-up procedure to many popular brand remote controls. One among it has general set-up codes to check with TVs and other devices are given, in the order of the 'device's brand name list' in alphabetical order. Pull up older posts. Search the sites by type in the brand name to your device in its search box at the top right part of the display window. It will help you to find the document easily.
http://remotesearch.blogspot.com/
http://electrohelponline.blogspot.com/
Dec 08, 2014 | Onkyo Audio Players & Recorders
ONKYO TX-DS484: \r\nI am not getting any sound out of my left speaker on stereo. I cannot find a balance adjustment. I do not have the remote control. Thanks
It sounds like you also need the manual.
http://www.retrevo.com/support/Onkyo-TX-DS484-Receivers-manual/id/365dj182/t/2/
The remote is an RC-4278. You WILL need it.
$25.10 on eBay expiring tonight so jump on it. 3h 35m 40s (Sep 06, 201120:16:46 PDT)
http://www.ebay.com/itm/ONKYO-RECEIVER-REMOTE-CONTROL-RC-385S-RC-373M-RC-371M-/290597112430?pt=LH_DefaultDomain_0&hash=item43a8f00a6e
As far as the left speaker goes, swap it to decide if it's the speaker, wire or the amp channel. There are no control settings that would make one of the front pair go silent.
Sep 06, 2011 | Onkyo TX-DS484 Receiver
Need a manual for onkyo rc 427s
I don't have a separate manual for the Onkyo RC-427S. However there are several pages on this remote in the TX-DS484 receiver manual.
See page 30 of the manual here: http://www.intl.onkyo.com/downloads/manuals/pdf/tx-ds484_manual_e.pdf .
I hope this helps.
Aug 04, 2011 | Onkyo RC-375DV Remote Control
Philips TV 42pfl9664 remote control interferes Onkyo
HI it is entirely possible that the function you are using on your tv has the same command that your Onkyo uses for selection of GAME-mode. You should be able to prove this by using the Game-mode button on your Onkyo remote and it should affect your TV.
If Not then try shielding the remote receiver on your stereo with something thick ( a piece of paper is transparemt to IR - use a book or pillow) and see if the problem clears.
If this test proves correct, then the only solution is to see if you can change the remote command ID on the stereo and remote (if it supports it). The philips will most probably not have this feature. otherwise the only solution is to upgrade 1 device for a different brand.
Mar 21, 2010 | Philips Televison & Video
Onkyo Remote Control RC-764M p/n:24140764 Logo
301 people viewed this question
Top Onkyo Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you an Onkyo Audio Player and Recorder Expert? Answer questions, earn points and help others
