Question about Rokenbok Motorized Conveyor
Does not move blue/red balls at all.
Motor does not work
Blower does not activate when a/c mode but works fine without a/c
on your fan motor. red is low speed ,blue is med speed, black is high, red for heating . blue works good for cooling. black is high speed. re look where the forth speed was hooked up. put blue there.
Apr 16, 2010 | Honeywell L4064B2236 Fan/Limit Control...
Tip
BOWLING TIPS
<b>How To Scare The Crowd:</b> <br /> <br />Start the regular bowling motion, and let go of the ball on the back swing. The ball will fly backwards, and the crowd will jump and scream.<br /> <br /> <b>How To Throw Your Ball Down The Wrong Lane!</b> <br /> <br />You can start the ball on another track by holding down the A button, and dragging to the right as you can. The ball will go in the alley side of their own.<br /> <br /> <b>How to Amuse the Crowd When You Bowl:</b> <br /> <br />You can make the crowd laugh. Move to the sewers in your lane, turn into the opposite lane, and bowl the ball has crossed the barrier between the lanes. The ball will go by the wayside in the opposite lane, and people laugh.<br /> <br /> <b>How To Get A Special Bowling Ball:</b> <br /> You must get to the pro-level to unlock the bowling ball that has diamond designs on it.<br /> <br /> <b>How To Change The Color of Your Bowling Ball:</b> <br /> <br />When the screen goes black for bowling, hold down the control key positions in the following colors specified bowling ball: Control Pad Up Blue Ball Control Pad Right: Gold Ball Control Pad Left Red Ball Control Pad Down Green Ball .<br />
on Jan 02, 2011 | Video Game Consoles & Games
I have an a/c unit that is blowing on high speed.There are 3 wires:black, red,blue,white(and 2 brown for the capacitator)To reduce the speed from high to medium do I just disconect the high speed...
The reason the a/c is on the high speed is to move the air because cold air is harder to move, slowing down the speed may cause your a/c to freeze-up. You can try changing the speed by reading the wiring schematic, take your time to become confortable with the schematic, and it will tell you which wire color conforms to each speed, locate the high speed wire color, and you will find that connected, locate the medium speed wire color, then disconnect the high speed and reconnect the medium speed wire in it's place. Be sure to tape the end of high speed wire so that it is insulated from the cabinet. ABOVE ALL MAKE SURE THE POWER SWITCH IS OFF BEFORE ATTEMPTING THIS
Jun 23, 2009 | Heating & Cooling
I've got a 2000 grand am all windows work except front passager side but when i push it to go down i can here the motor working check the fuses there fine i dont know what it could be ?
the regulator is most likely broke from the motor. you can take off the door panel fairly easily, and look inside to be sure before ordering parts. some of those use teflon balls to commutate the motor to the regulator, and they just get eaten up over time. i have in the past replaced those teflons balls with ball bearings of the same size without any more trouble. those windows are hard to knock off track, and if it is not moving by brute force i would say the problem is either where the motor connects to the regulator or the regulator itself. hope this helps... dustang
May 09, 2009 | 2001 Pontiac Grand Prix
Puzzles 130 Too Many Queens 5 --- 132 Princess's Escape
puzzle 130:Assuming on a chess board 8x8 that each square is numbered 1-64 top left to right.Place a queen on each of these squares 3,13,18,32,33,47,52 and 62 bobs yer uncle
Mar 09, 2009 | Nintendo Professor Layton & the Curious...
Stuck on puzzle 94 (Get the ball out) 4 Can anyone help. Game Nintendo DS Professor Layton and the Curious Village
094 Get the Ball Out! 4
1. If you're persistent in your efforts, you'll eventually get the ball to
the hole, but there are tricks to streamline the process.
The large block in the puzzle is relatively limited in range of
movement, so you're going to have to do more work with the smaller and
more maneuverable blocks. If you focus on them and plan out a route,
things should go smoothly.
2. If you move the green block on the right down, you can fill the space
you create with a purple block from the right. If you can pull that off,
you'll be able to move the blue block in the upper left, which will
allow you to move the red ball out of its slot.
It may seem complicated, but give it a try.
3. There is no set solution to this problem.
Here's one way to start out. Move the lower-left purple blocks, then
slide the lower blue block to the left.
Next, drop the green block on the right down.
The rest is up to you.
However, I have found the following sequence if you can follow it to get it done in 21 moves:
Purple block = P
Yellow block = Y
Green block = G
Red ball = R
(l)eft (r)ight (u)p (d)own
P[d],P[l],B[l],G[dd],P[dd],P[rd],B[rr],R[dr],G[uu,Y[l],P[rd],
B[d],R[rru],B[ul],R[ddl],P[uuu],R[rd],P[u],R[l],G[uuu],R[rdd] = 21 moves
Thanks and please take a moment to rate as fixya.
Feb 23, 2009 | Nintendo Professor Layton & the Curious...
Where is puzzle 120
http://www.wikicheats.com/index.php/Professor_Layton_and_the_Curious_Village_(DS)/Walkthrough#Puzzle_No._078
Go here for all puzzle walkthroughs
Puzzle No. 120 Tap the open manhole above from the Sewers below.
Get the Ball Out! 3: Slide the bottom-right blue block over to the right and drop that lower purple block in the slot with the hole. Now, drop the big yellow block down. Drop the top purple block down one and then reposition the top two blue blocks so they are touching end-to-end directly under the red ball. Raise the left green and the big yellow block up into the center. Slide the bottom-right-most blue block all the way to the left. Drop and slide the other right-hand-side blue block as far left as it can go now. Drop the green block on the right down and into the right-hand nook. Slide one of the top blue blocks to the far right along with the yellow block and the right-hand blue block on the bottom. Drop the red ball all the way down to the bottom row. Move the left-hand green block up into the ball's starting slot and slide the yellow block all the way to the left. Move the bottom-right blue block up and the small purple one that blocks the hole. Now simply put the red ball into the hole.
Jan 04, 2009 | Nintendo Professor Layton & the Curious...
Trackman wheel....ball fell loose, now actin weird
Dust has a tendancy to collect under the ball at the 3 contact tips (you should look under the ball)and it is possible enough dust collected when the ball was removed, that the dust particles became a large dust ball and lodged under the ball making it impossible to move!
Remove the ball and clean the area and replace the ball and it should work fine.
Aug 29, 2008 | Logitech Cordless TrackMan Wheel...
Ceiling fans..
Are you talking about the receiver? If so connect wires from fan, White, black,blue to receiver white, black, blue. White to white and so on. Then connect the two wires from other side of receiver, white and black(or Red) to corresponding colors from ceiling. Then store receiver just above the ball in the ceiling mount plate, you will have to move the wires to the side and push it in. Hope this helps
Aug 16, 2008 | Dryers
Rokenbok Motorized Conveyor Logo
98 people viewed this question
Top Rokenbok Toys Experts
ray gallant
Are you a Rokenbok Toy Expert? Answer questions, earn points and help others
