Question about Samsung Office Equipment & Supplies
Scx 4632f Paper Jam in exit area, I cannot see any paper in exit area.
  • 3422 Answers
SOURCE: Samsung SCX-4521 "Paper Jam 2" won't clear
Hi there have you tried the door at the back of the machine as there maybe a piece stuck in the fuser unit. If not open the back door and check that there is a small black lever in the middle of the two rollers sticking up as this is the sensor arm that determines that there is a paper jam or not. If this is still there then the paper will be stuck just after the paper cassette within the paper path.
Hope this helps you.
Goodluck,
please don't forget to rate me as fixya..
Posted on Feb 01, 2008
I had this problem too. For me the answer turned out to be the paper sensor in the back part of the machine, behind the little back door just under the top part of the machine. This sensor hangs down from a thin rod that runs across the width of the machine, and is held in place by a small spring that encircles the same rod that supports the finger. The finger had apparently gotten moved so the spring was dislodged from its proper place. I was able to rotate it around the rod with my finger & get the spring moved back to where it should be. This seems to have cleared the problem--I'm keeping my fingers crossed.
Posted on Feb 04, 2008
ginko
  • 19396 Answers
SOURCE: paper jam
Pull out power cable and, disconnect priter from power outlet, put cable back in.
If you still have led on after this, open all doors and check again fo intrusion. Pull out paper tray and check that there isnt a paper sheet stuck underneat the printer.
Open front door, pull out toner and chech under toner, put toner back , restart and try.
Open back door and check if there is a second paper sheet stuck inside
regards.
Posted on Mar 21, 2008
  • 685 Answers
SOURCE: paper jam on hpc7280 printer noise from duplexer area NO PAPER JAM
Follow the instructions in this video. If you follow those instructions and still get the message, you may need to replace your printer or the rear door.
Posted on Jun 17, 2009
SOURCE: Paper jammed at exit rollers of Canon D860. Paper
You can download the repair manual for a similiar Canon printer, the iR1200-1500, on Ebay for $ 3.00 to $ 5.00 and this will tell you how to take apart the printer. I had the same problem and the manual allowed me to remove the fuser assembly and clear the jam. If you prefer, Canon sells the Image Class D860/880 repair manual for you printer for $54 plus shipping. The Ebay dealer also included the parts maunal, which is a sepatate charge from Canon.
Posted on Jul 18, 2010
My samsung scx-4623f always "paper jam in exit area" every time i print even though i always put out the jammed paper in the exit area.
While Samsung SCX-4623f printer always "paper jam in exit area" you get paper checks or trigger sensor paper cup
cong ty bao ve support
good luck
Jul 07, 2014 | Samsung SCX4623F Laser All-in-One Printer
Goodluck,
Feb 01, 2008 | Samsung SCX 4521F All-In-One Laser Printer
Scx 4632f
hi, your printer papper out senser is damaged or papper out senser liver is damaged please check
Apr 02, 2014 | Samsung Office Equipment & Supplies
Paper jam in exit area
Hi
Disconnect it completely from power and re-connect again.
Sep 16, 2012 | Samsung SCX-4300 Monochrome Laser...
My Samsung scx 4x20 printer shows paper jam in the dsisplay but there is NO paper jam. Can not get the error away and the printer refuses to print. What to do?
I suppose that the exit paper sensor in fusing section is broken (ussually when you pull out paper jam you can brake this little black or blue pawl). You can order and buy only this paper sensor pawl (very cheep).
pifonski
Feb 23, 2011 | Samsung SCX 4200 All-In-One Laser Printer
The paper jam icon comes up, but there does not seem be be any jam!
there is a paper exit sensor in the middle of the paper exit module kindly check whether it is fixed properly or permanantely actuated if it is actuated adjust it your problem will be solved
Jan 21, 2011 | Samsung SCX-4500 Laser Printer
Paper jam 2
Check inside of paper exit area. You can lift the top bits (not the scanner cover) and you will see the paper jammed inside. Hope this helps!
Nov 28, 2010 | Samsung SCX-4300 Monochrome Laser...
I have a samsung scx 4200 am getting the papaer jam error even when theres no paper jamed up there
Good Day Sir,
when paper jam occurs, Paper jam appears on the display.
Message Location of Jam
[Paper Jam 0] - In the paper input tray
[Paper Jam 1] - In the fuser area or around the toner cartridge
In the manual feeder
[Paper Jam 2] - In the paper exit area
hope this will help you. god bless
Nov 06, 2009 | Samsung SCX 4200 All-In-One Laser Printer
I am getting an error on my Samsung SCX 6320 saying that there is a paper jam when there is no visible paper in the machine. It had jammed, I removed the paper with no tears or rips, but it still has the...
its may be the problem related to Two causes....
pls. check the Main Frame paper feeding gear was brokned or not ?
check the paper exit Pully in the exit area....
Jul 09, 2009 | Samsung SCX-6320F All-In-One Laser Printer
Paper Jam
Good day, Check the table below about the problem of paper jams.
Display and Meaning
[Paper Jam 0] - Paper has Jammed in the feeding area of the paper input tray.
[Paper Jam 1] - Paper has jammed in the fuser area or in the manual feeder.
[Paper Jam 2] - Paper has jammed in the paper exit area.
hope it will help you.
Jun 04, 2009 | Samsung SCX 4200 All-In-One Laser Printer
19 people viewed this question
Top Samsung Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
HEMANT GROVER
CheckitRight
CheckitRight
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
