Question about Avaya Definity 6424D+M Corded Phone
6416D+M programming 16 buttons
2 Suggested Answers
  • 651 Answers
SOURCE: How do I program my speed dial buttons for an Avaya 6416D+M phone that has 16 presets. My menu only goes up to AD8.
those are controlled by the phone system admin you may not have permission to provision those.
Posted on Feb 02, 2018
Feb 02, 2018 | Avaya Lands Phones
Is this compatible with Avaya 6416D+M phones?
The Avaya 6416D+M Telephone is compatible with Definity R6.1 or higher if you have this then yes it is
Jan 17, 2014 | GE Universal All-in-One Stereo Headset...
Programming the cn101a timer
CN101A programmable weekly digital timer
Buttons
C = Master Clear, erases all program settings and current day/time.
C/R = Control/Reset, used to access programming mode and to clear individual programs.
You must press and hold this button for approximately 4 seconds to enter programming mode if there is a lower case "a" to the left of the time display. The system will revert back to active mode (with the lower case "a" to the left of the time display) after 30 seconds with no buttons pressed.
If this button is momentarily pressed while viewing a program, that program will be erased, but ONLY the On or Off program that is being viewed will be reset. The corresponding On or Off program in that cycle will NOT be reset.
Clock = In programming mode, this button is held depressed at the same time as one of the D+, H+, or M+ buttons to set the current day and time. When editing the programs, this button is used to exit when done.
P = Program select, each press will advance through the On and Off programs (presets). There are 16 On/Off cycles available (1 On, 1 Off, 2 On, 2 Off, ... 16 On, 16 Off).
D+ = Used to change the day when setting the time, or day(s) when changing a program.
When changing a program,
the following 15 different day combinations are available using the "D+" button.
MO; TU; WE; TH; FR; SA; SU; MO/WE/FR; TU/TH/SA; SA/SU; MO/TU/WE; TH/FR/SA; MO/TU/WE/TH/FR; MO/TU/WE/TH/FR/SA; MO/TU/WE/TH/FR/SA/SU.
H+ = used to change the hours when setting the time or a program.
M+ = used to change the minutes when setting the time or a program.
Manual = This button will cycle the output relay from AUTO to Manual OFF, back to AUTO, then to Manual ON, and finally back to AUTO. Programming mode must first be accessed using the C/R button to use the Manual feature. The manual On or Off settings will override all programs until switched back to AUTO.
There is a Lithium Ion battery which is intended to keep the clock going for up to 3 years during loss of external power, but the output relay will not work on internal battery power.
Jan 17, 2012 | Hardware & Accessories
I need to program the speed dial Buttons on my phone. It is a NEC DTerm Series i - 16 button.
Press Feature, press the button you wish to program, dial the number and press Feature.
Apr 15, 2010 | Lands Phones
Avaya 6416D+M, rings half ring, then goes straight to voice mail
you might status the phone to make sure that send all calls somehow is not on. :)
Oct 28, 2009 | Avaya Definity 6408D Corded Phone
How do i change the channel?
Programming a Frequency to a
Selected Channel:
1. Press and hold down the Push-To-Talk
button while turning the radio on, wait for
approximately 5 seconds then release the
Push-To-Talk button.
2. Use Scroll button to select one of the 8
frequencies. Figure 16.
3. On a Spirit GT+, press the Monitor button.
4. The current channel will flash, press scroll
button to change channel.
5. After the second channel is selected, press Monitor button again, current
frequency for second channel will flash. Figure 16.
6. Use Scroll button to select new frequency.
Exit Programming Mode - 3 Ways
1. Press Push-To-Talk to exit completely.
2. Allow the Menu time to expire (10 seconds).
3. Press Menu button to go to code programming.
Here is a link to the user manual: http://www.motorola.com/mdirect/manuals/Spirit_GT_User_Manual_E.pdf
Jun 25, 2009 | Motorola Spirit GT Pro (2 Channels) 2-Way...
Programming instructions for a 1999 Chrysler 300M remote fob
Manual Programming Procedure (non scan tool)
1. Connect pin 1 of the 16-way data link connector to chassis ground or to pin 4 of the 16-way data link connector.
2. Close all doors, turn ignition key to off.
3. Turn ignition key to Accessory.
4. Turn ignition to off, door locks will cycle once (in programming mode).
5. For each key FOB, press any button 3 times in a row to program code. When programming is complete, the door locks will cycle once.
NOTE:
IF A SECOND KEY FOB REQUIRES PROGRAMMING, IT MUST BE PROGRAMMED WITHIN 1 MINUTE OF PROGRAMMING
THE FIRST FOB PROGRAMMING. PRESS ANY BUTTON ON THE SECOND FOB 3 TIMES TO PROGRAM ITS CODE. WHEN PROGRAMMING IS COMPLETE, THE DOOR LOCKS WILL CYCLE ONCE.
6. The programming mode finishes after the following:
a. Programming of two key FOBS is completed.
b. One minute has passed since programming.
c. Pin 1 of 16-way data link connector is removed from ground connection.
d. Ignition switch is turned on.
e. Any of the doors are opened.
Apr 09, 2009 | 1999 Chrysler 300M
Running c graphics program in windows vista
Maybe try to put the completed exe on the desktop.
Then click to the program with the right button and then
set the Windows compatibility mode.
Jan 09, 2009 | Microsoft Windows Vista Ultimate Edition
Euro style 18d how to program memory keys
The Avaya website (www.avaya.com) is loaded with manuals, you just have to know where to look.. Here's one http://support.avaya.com/elmodocs2/partner_acs/r7/518457701_2.pdf
Page 13 tells you how to program a button (ie FEAT 00 button dial the number and press FEAT 00 again to exit). Page 16 tells you how to program personal speed dial number from the 20 bins 80-99 allotted to your phone.
Carl
Nov 11, 2008 | Lucent PARTNER18 Corded Phone
Avaya Definity 6424D+M Corded Phone Logo
37 people viewed this question
Top Avaya Lands Phones Experts
Oloyede Monsuru
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you an Avaya Lands Phone Expert? Answer questions, earn points and help others
