Question about Maytag PYE2300AY Electric Dryer
Where is the thermal fuse located on a pye4557ayn maytag dryer. thanks, Gary
  • 6,784 Answers
The fuse is usually located on the vent duct, inside the dryer.
Posted on Jun 15, 2009
Locate thermal fuse on maytag neptune dryer model # mlg2000aww
The thermal fuse is located on the front cover over the blower wheel housing in the front of the dryer, the part # is 33001762,good luck
Aug 24, 2015 | Maytag Dryers
I have a Kenmore Dryer, Model 96292110. It runs, but it does not heat the air. I have checked the circuit breakers. They are fine.
If your Maytag dryer has mysteriously stopped producing heat, a blown thermal fuse may be the cause of your problem. In Whirlpool dryers,thermal fuses are safety switches that are designed to disrupt the flow of electricity to your dryer's heating mechanisms once the dryer reaches a predetermined maximum temperature, usually somewhere around 180 degrees F.
Thankfully, troubleshooting the thermal fuse in a Maytag dryer is easier than it sounds.
Instructions And Things You'll Needed.
  • Screwdriver,Towel,Electrical tape,Replacement thermal fuse, if necessary.
1 Clean out thelint screen in your Maytag clothes dryer. Lint buildup can cause your dryerto overheat, triggering the thermal fuse to disrupt power to your dryer'sheating mechanisms. Take the lint screen out of your Whirlpool dryer and washit in warm water. Dry the screen thoroughly before replacing it.
2 Look behindthe dryer to check its flexible exhaust hose for kinks or obstructions.Disconnect the exhaust hose from the back of your dryer and clean out any lintthat has built up.
3 Go outside andcheck your Maytag dryer's exhaust vent for obstructions. Lint buildup, birdnests or other obstructions in the outside exhaust vent can trigger yourdryer's thermal fuse.
4 Disconnectyour dryer from its power source before attempting to access its thermal fuse.
5 Access the thermal fuse in your Maytag dryer byremoving the back panel. Remove the screws that hold the back panel in placeand it should easily come free.
6 Look betweenthe dryer's blower housing and exhaust to locate its thermal fuse. The thermalfuse in a Whirlpool dryer looks like a white plastic strip that has two wiresconnected to it.
7 Bypass the thermal fuse in your Maytag dryer whileyou perform a quick diagnostic test. Use electrical tape to tape together thetwo wires connected to the thermal fuse. Reassemble your dryer and plug it backin. Set the dryer to a timed heated drying cycle and press "Start."If the dryer produces heat with its thermal fuse bypassed, it means the thermalfuse needs to be replaced.
8 Replace a blown thermal fuse in your Maytag dryer.Disconnect the power and remove the back panel. Remove the electrical tape thatyou used to perform the diagnostic test and disconnect the wires from thethermal fuse. Remove the screws that secure the thermal fuse to the dryer anddiscard the blown fuse. Attach the replacement thermal fuse by replacing andtightening the screws. Attach the wires to the new thermal fuse.
Thanks for using fixya.
Jul 31, 2011 | Kenmore Dryers
Rex4635eq2 electric dryer. all switches and fuses check out. Nothing comes on and the timer doesnt move or make a clicking noise when i push the start button. what do you think? Timer? Gary
You need to check your door switch and thermal fuse. The thermal fuse is located behind the back panel at about 6 oclock. If the thermal fuse is bad, you need to make sure the vent is clean.
Mar 26, 2011 | Roper REX4634KQ Electric Dryer
Location of Thermal Fuse
The thermal fuse is located near the heating element. The part number for the replacement kit is LA-1053. You can view an illustrated parts break down of your dryer at searspartsdirect.com. Just type in your model number and locate item 5 under the "Heater" section. Pay close attention to the instructions in the thermal fuse replacment kit. One thermostat is for a GAS dryer, one is for an ELECTRIC dryer. Read the instructions and make sure you use the correct one. If you have any questions, please let me know. I hope this helps you.
Jan 06, 2010 | Maytag PYE2300AY Electric Dryer
Maytag Dryer getting hot and then shutting off
if will heat for a short time its not a thermal fuse but the vent tube or hose is crushed or plugged put unit on air only go to the location where it exits the vent if you feel no or low air then find the area of the vent system that is affected.
Jan 01, 2010 | Maytag MDE9206 Dryer
MAYTAG DRYER PYET444AYW HAS NO POWER...IS THERE AN INTERNAL FUSE?
There is an internal fuse. It is called a Thermal Fuse. It is not resetable it is only replaceable. It is located in the back of the dryer. Unplug the dryer and locate the thermal fuse and replace it. Two wires conect the to it. Also I would check the breaker to the dryer. Thanks and good luck. I you need futher assistance let me know and we will get through this together.
Aug 24, 2009 | Maytag Dryers
Where is the thermal fuse located?
In the back of the dryer. Look for the coiled heaters and follow the lead wires back to the fuse.
Apr 30, 2009 | Maytag PYE2300AY Electric Dryer
Dryer won't start
HI thanks for the question the part thats more likely at fault is the thermal fuse located at the back. pull dryer away from the wall. remove the back panel clean all the lint thermal fuse is on the left at the air duct. replace this part. thanks the appliance doc. please rate my answer please.
Oct 08, 2008 | Maytag Dryers
Will not come on
hi thanks for the question i would check the thermal fuse located in the front of the dryer remove the front panel , and the thermal fuse is located on the air duct thanks the appliance doc
Jul 14, 2008 | Maytag Atlantis MDE7400AY Electric Dryer
Maytag PYE2300AY Electric Dryer Logo
130 people viewed this question
Top Maytag Dryers Experts
Tim Whalen
Marvin
Marvin
Sal De
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
