Question about ASUS DRW 24B1ST Disk drive DVD RW ( R DL) DVDRAM 24x24x12x Serial ATA internal 525" Burner
Asus 24x DVD-RW SATA Optical Drive DRW-24B1ST doesn't autoplay in Win7
Have checked auto play settings in the control panel of windows. It is set for "use autoplay for all media and devices." Have rebooted system, checked to make sure I have latest firmware. Works if started manually after disc is loaded. Big problem if I want to autoload a program like Win 7 on system boot.
SOURCE: DRW-1814BLT compatibility with IDE hard drive
With A8M-VM series Mother Board the Asus DVD Writer Model No.DRW-1814BLT Lightscribe Not supporting.
Posted on Feb 04, 2008
  • 11800 Answers
SOURCE: My P5QL-E Mobo won't let me use my Western Digital
You have to enable AHCI in 7. Follow this:
http://www.ithinkdiff.com/how-to-enable-ahci-in-windows-7-rc-after-installation/
Posted on Dec 08, 2009
Testimonial: "Thanks, I've already figured it out, but you're right. Cheers "
  • 1015 Answers
SOURCE: hello i have a lightscribe
The LightScribe feature of DVD burners with this capability requires that you are using burner software that has this function. Verify that the software you are using is lightscribe compatible. The software that comes with this drive(Nero) should be lightscribe compatible. After you burn the disc you do need to fip the disc over and the re-insert into the drive so that a label can be etched into the disc. The lightscribe discs look identical on both sides so only one side you can burn info and the other side is for the label so make sure that it is inserted on the right side for each process. If you put the disc in on the wrong side the initial data burn will not work. Also sometimes burners will have issues with certain brands of discs so you may also want to try a different brand and see if that helps. And another thing that you can try is updating the drive to the latest firmware. The firmware is to the drive kind of like what Windows is to your PC. Sometimes updating this file will fix problems like this. Here is a link to the firmware of your model. http://support.asus.com/download/download.aspx?SLanguage=en-us
You can download the file and run it to update your firmware. Caution: Before running the firmware make sure it is the correct file for your drive! There are a couple of variations to your model number and this one might not be the correct one. If you install the wrong file you could damage your drive inoperable or defeat some of it's features. I hope this information is of help with your problem and thanks for using FixYa.
Posted on Aug 20, 2010
  • 222 Answers
SOURCE: I CANNOT LOAD WIN7 I cannot get my system to
try to reset bios if does't work try using a usb dvd drive (external dvd drive) remember you do not will be able to read a dvd CD(WINDOWS 7 CD) using a cd burner.
you will need a dvd drive.
Posted on Feb 07, 2011
bronk50
  • 27725 Answers
SOURCE: Installed DVD BRN ASUS/DRW-24B1ST.
click start control panel admistrive tools,computer management,device manager scroll down cd dvd rom drives right click you will see options to update driver,roll back driver,or
select properties general troubleshoot, select driver click to reinstall drivers click update driver or uninstall then reinstall
make sure that the cd-dvd burner is getting enough power test all leads that are attached to the dvd drive including electrical extensions and make sure they have a secure connection or just replace them there might be bad/faulty or
if this does not fix the problem it might be a registry problem
Close all open programs
Click on Start, Run, and type regedit and press Enter
Click on the plus signs (+) next to the following folders
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
{4D36E965-E325-11CE-BFC1-08002BE10318}
This folder is the DVD/CD-ROM Drive Class Description in the registry. Look for any of the following names in the right hand column.
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
If any of the above keys shown in step 4 are listed, right-click on them and choose Delete
After deleting the keys, close the registry editor
Reboot your computer
Open My Computer and check to see if your CD or DVD drives have returned. You may also want to open Device Manager and verify that the yellow exclamation and error code on the CD or DVD drive is gone.
hope this helps don
Posted on Mar 14, 2011
Sata adapter
Please check the Sata cable and the power cable
Jan 24, 2014 | ASUS DRW 24B1ST Disk drive DVD RW ( R...
Asus DRW-241st stopped recognizing any DVD's though it still reads CD's. Other then that it seems to be running just fine.
Good day sir, Try to clean it with a CD lens cleaner if problem persist.I recommend replacing your optical disk drive or use it as a slave for reading CD's so that your new ODD will last long. in my opinion most DVDRAM, player etc. can read most formats except Bluray disc. using the device from reading CD,VCD and DVD lessen's the device life span.
sometimes if we rarely use the ODD its already not working.
Jun 29, 2011 | ASUS DRW 24B1ST Disk drive DVD RW ( R...
Nexxteck dvd driver downloads. my dvd is usb pnp rw dvd, it doesn't play movies automatically
This is not an issue with the drive. The drive is not what tells your pc to play movies automatically. Anyhow, I don't know what version of windows you are using, but if you click start-help and then type in 'auto play' it will show you how to change the settings so movies will play automatically. Also, if you don't have it already, install VLC media player.....it plays pretty much any video files.
Hope this helps!
Joe
Jun 04, 2011 | NexxTech DRW-6S160P DVD±RW Dual Layer...
Installed DVD BRN ASUS/DRW-24B1ST. Says there is a Code 19 problem--something about in the registry--doesn't work. Same situation before installing this new hardware.
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
hope this helps don
Mar 14, 2011 | ASUS DRW 24B1ST Disk drive DVD RW ( R...
I CANNOT LOAD WIN7 I cannot get my system to boot from a CD disk (Win 7 Ultimate) I set the BIOS to boot from a CD device - the priority is set for CD first. All other values are default. In...
Feb 07, 2011 | ASUS Computers & Internet
Hi, my asus drw-20B1LT has suddenly stopped autoplay i seam to have latest drivers from MS,gone to properties checked autoplay all ok,put a game ect in nothing(reg prog on my computer/dvd-rom) if i hit...
Try this: Open Registry editor (Start > Run > (Type regedit and press enter) Open the following key (You will have to keep on clicking several keys to get to this starting with HKEY_CURRENT_USER)
HKEY_CURRENT_USER\Software\Microsoft\Windows\CurrentVersion\Policies\Explorer
Double click 'NoDriveTypeAutoRun' key on right and set the value to 'b9'
Close registry editor, restart and try.
Aug 25, 2009 | ASUS (GENEIRC DRW-1608P BLACK)...
I got a ASUS DRW-2014L1T CD-RW and have no driver can anyone tell me pls where i can download a driver or post the link, would be very thankfull ( milojica90@hotmail.com for contacting me )
Here is the link for the ASUS downloads.
Choose Optical storage then DVD RW then your model number
The DRW-2014L1T is a DVD-RW and the drivers are incorporated with windows drivers. Are you looking for the burning software, like Nero or Roxio? Or is the unit not working at all?
My email is jdaniher@verizon.net.
Jun 27, 2009 | ASUS DRW-2014L1T DVD-RAM Burner
Dics Drive Upgrade for Toshiba Satillate.
As far as i know thats impossible. Your optical diskdrive is made just for those speeds that you have on it. You cant change the manufacture settings and speed it upp, or make it to an dual layer disk.
Buy a new one whit the needs that u want and replace the old one. Its easy done and its not that expensive.
Good luck to you
Nic
Feb 04, 2009 | Toshiba Satellite A105 Notebook
D drive lost
Hi and welcome to FixYa,
Initially, pls download this quick fix patch. This addresses problems such as what you are experiencing in both Vista and XP.
Good luck and Thank you for using FixYa. Happy Holidays.
Dec 18, 2008 | Lenovo Thinkpad T60 Notebook
put hard drive as Master. dvd rw as slave!
if DVD comes with sata then just put hard drive as master.
configure it on the bios setting!
if it still don't detect it
try replacing IDE cable and sata cable!
Nov 15, 2007 | ASUS (ASUDVDRWM6N) DVD-RW Burner
Open Questions:
See all ASUS DRW 24B1ST Disk drive DVD RW ( R DL) Questions
ASUS DRW 24B1ST  Disk drive  DVD RW ( R DL)  DVDRAM  24x24x12x  Serial ATA  internal  525"  Burner Logo
49 people viewed this question
Top ASUS Computers & Internet Experts
David
David
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
