Question about Kodak i4200
Getting error 4769
The following error was encountered while scanning a batch 4769 command failed-check log
2 Suggested Answers
  • 59 Answers
SOURCE: I am getting an error message stating...
INSTALL YOUR NEW SOFTWARE AGAIN IT WILL NEVER COME
Posted on Oct 21, 2009
The scutum50 NDIS protocol driver service failed to start due to the following error: The system cannot find the file specified.
1. add /BOOTLOG flag to your C:\boot.ini to get a startup log in %SystemRoot%\NTBTlog.txt 2. check %SystemRoot%\NTBTlog.txt for driver errors 3. run from a command prompt sc queryex type= all state= all bufsize= 30000 > services.log 4. check services.log for the scutum service 5. evtl. unregister the scutum service with sc del Scutum50
Mar 08, 2013 | Computers & Internet
Tip
0X7E Blue Screen error triggered by Microsoft KB977165 XP update and a malware...
  1. Boot to your Windows XP CD, and enter the Recovery Console (HTTP://support.microsoft.com/kb/314058)
  2. Type the following command: CHDIR $NtUninstallKB977165@\spuninst then press <enter>
  3. Type: BATCH spuninst.txt and press <enter>
  4. Type: EXIT and press <enter> and the system will reboot.
  5. Go to HTTP://safety.live.com and run the full service scan to find/remove any rootkits found.
on Feb 16, 2010 | Computers & Internet
My HD SAMSUNG HM500JI not work any more bad sector that cany be fix...!!!
Well.. I'm SAD to inform you..your drive has encountered a serious error.
There's a couple of options..none of which you will like.
Drives (SMART) report errors, but sadly don't fix anything. Once a bad-sector has been encountered, its usually an indication of major failure (google/39% of all drives w/bad sectors major failure..etc)
Your options.. Is your data super important--if so, STOP using the drive, send it to a DRC (Data recovery Center), expect to spend $600-1k for the data.
If you've backedup, good news-- drives are cheap.. buy another, plus your drive into tthe 2nd slot, copy off what you can..
the drive itself is having a major failure (meaning it cannot relocate the bad sectors any longer, hence the smart failure)-- meaning-- drives "TRY" to relocate (when they detect failures, they'll move the data else where, mark the bad area, and use a new spot)... Your drive has probably done that.. ALOT. And now... it's gone critical.
BEST solution for you, to save $$ and time.. but a drive ($80-150 bucks)... install your os... put the other drive on the other cable, copy off what you can..and call it a day.
A DRC won't do much more to be honest... if its SUPER critical, contact www.deepspar.com and see if they will recommend you to a DRC locally to you, or do it them selves...again $$$
Oct 16, 2012 | Samsung HM500JI 500 GB SATA Hard Drive
Kodak i1440 scanner error 4769
Hi the error isnt one that corresponds to a scanner error number , you should run the scan validation tool and get the error from that , having said that check the image guides are clean and undamaged this is a major cause of faults
Sep 09, 2011 | Kodak i1440 Pass-Through Scanner
I cant log on because i forgot my password
If you have any other user account with admin rights then only you can change the password..else you have to reinstall the operating system.
If you have a different account with admin accounts.
go to start then in run type in cmd\
you will see a black window.
Then follow the below steps:
To change a user's password at the command prompt, log on as an administrator and type:
net user user_name * /domain When you are prompted to type a password for the user, type the new password, not the existing password. After you type the new password, the system prompts you to retype the password to confirm. The password is now changed.
Alternatively, you can type the following command:
net user user_name new_password
When you do so, the password changes without prompting you again. This command also enables you to change passwords in a batch file.
Non-administrators receive a "System error 5 has occurred. Access is denied" error message when they attempt to change the password.
Aug 18, 2011 | Compaq Presario 1800 Notebook
When i tried to to install service pack 2(twice) it downloaded to 24% and stopped . With the error code 8E5E0442 windows update encountered an unknown error .
Perform the following steps to reset the Windows Update component.
1. Stop the Background Intelligent Transfer Service and the Automatic Updates service. To do this, follow these steps:
a. Click Start/All Programs/Accessories. Right click 'Command Prompt' and select 'Run As Administrator'. Click 'Continue' on the UAC prompt.
b. At the command prompt, type the following commands, and then press ENTER after each command:
net stop wuauserv
net stop bits
2. Rename the "Catroot2" folder. To do this, follow these steps:
Type the following commands, and then press Enter after each command.
net stop cryptsvc
ren %systemroot%\System32\Catroot2 oldcatroot2
net start cryptsvc
3. Rename the "SoftwareDistribution" folder:
Type the following command, and then press Enter.
ren %systemroot%\SoftwareDistribution SoftwareDistribution.old
4. Register the files that are used by Windows Update and Microsoft Update. To do this, follow these steps:
a. At the command prompt, type the following commands, press ENTER after each command, and then click OK every time that you receive a verification message:
regsvr32 wuapi.dll
regsvr32 wuaueng.dll
regsvr32 wucltux.dll
regsvr32 wups2.dll
regsvr32 wups.dll
regsvr32 wuwebv.dll
5. Start the Background Intelligent Transfer Service, the Automatic Updates service, and the Event Log service. To do this, follow these steps:
a. At the command prompt, type the following commands, and then press ENTER after each command:
net start bits
net start wuauserv
net start Eventlog
exit
Reboot the computer and try Windows Update again. That should get update working gain but your update status may change a bit so you may have to rerun update a few times.
Mar 04, 2011 | Computers & Internet
PhotoShop CS3 Droplet automation
Try the following steps
  1. Choose File => Automate => Create Droplet.
  2. Specify where to save the droplet. Click Choose in the Save Droplet In section of the dialog box and navigate to the location.
  3. Select the Action Set, and then designate which action you intend to use within the Set and Action menus. (Select the action in the Actions palette before you open the dialog box to preselect these menus.
  4. Set Play options for the droplet:
    a. Override Action “Open” Commands Open commands in the action refer to the batched files, rather than to the file names specified in the action. Deselect Override Action “Open” Commands if the action was recorded to operate on open files or if the action contains Open commands for specific files that are required by the action.
    b. Include All Subfolders Processes files in subdirectories.
    c. Suppress Color Profile Warnings Turns off display of color profile messages.
    d. Suppress File Open Options Dialogs Hides File Open Options dialog boxes. This is useful when batching actions on camera raw image files. The default or previously specified settings will be used.
  5. Choose a destination for the processed files from the Destination menu:
    a. None Leaves the files open without saving changes (unless the action includes a Save command).
    b. Save And Close Saves the files in their current location, overwriting the original files.
    c. Folder Saves the processed files to another location. Click Choose to specify the destination folder.
    Note: You can record an action that saves using a specified file name and folder. If you do this and deselect Override Action “Save As” Commands, the same file is overwritten each time. If you record your Save As step in the action without specifying a file name, the droplet saves it to the same folder each time but uses the file name of the document being saved.
  6. If the action includes a Save As command, choose Override Action “Save As” Commands to make sure files are saved to the folder you specified (or to their original folder if you chose Save And Close.) To use this option, the action must contain a Save As command, whether or not it specifies a save location or file name; otherwise, no files are saved.
    Some save options are not available in the Batch command (such as JPEG compression or TIFF options). To use these options, record them in the action, then use the Override Action “Save As” Commands option to make sure that your files are saved where you specify in the Batch command.
  7. If you chose Folder as the destination, specify a file-naming convention and select file compatibility options for the processed files:
    a. For File Naming, select elements from the pop‑up menus or enter text into the fields to be combined into the default names for all files. Elements include document name, serial number or letter, file creation date, and file extension. Starting Serial Number specifies the starting number for any serial number fields. Serial letter fields always start with the letter “A” for the first file.
    b. For Compatibility, choose Windows, Mac OS, and UNIX to make file names compatible with Windows, Mac OS, and UNIX operating systems.
  8. Select an option for error processing from the Errors pop‑up menu:
    a. Stop For Errors Suspends the process until you confirm the error message.
    b. Log Errors To File Records each error in a file without stopping the process. If errors are logged to a file, a message appears after processing. To review the error file, open it in a text editor after the Batch command runs.
Give it a try.........
Jul 30, 2009 | Computers & Internet
Problems with batch scans and with filing using a non-Nikon code system
Did you try saving your choice of settings as user settings ? That way, they will serve as defaults for all subsequent scans.
Jul 21, 2008 | Nikon Super Coolscan 5000 ED Film Scanner
Error 5
hi
check the permission of the share and also you may have to create a user just for sharing
This is a permission issue. If the net view command fails with a "System error 5 has occurred. Access is denied." message, 1) make sure you are logged on using an account that has permission to view the shares on the remote computer.
2) Need to cache credential: logon the same username and password on both computers or use net net use \\computername /user:username command.
3) Make sure the Netlogon service is running
the second question : it is a spyware
check this link in regards to clean t
Feb 13, 2008 | Microsoft Windows 2000 Professional for PC
Kodak i4200 Logo
Top Kodak Office Equipment & Supplies Experts
Are you a Kodak Office Equipment and Supply Expert? Answer questions, earn points and help others
