Question about Frigidaire GLTF2940ES Front Load Washer
E47 will not drain and no fast spin.cleaned trap
  • Frigidaire Master
  • 5,323 Answers
Check hoses and water pump for blockage
Posted on Mar 31, 2015
Our Frigidaire Affinity washer has error code E47
the error code E47 means your door latch/lock assembly is bad.
Jun 12, 2012 | Electrolux Washing Machines
Frigidaire GLTF2940ES3
I believe E47 is a door lock code.
You probably just need to replace the door latch.
Common problem with those units.
Sep 03, 2009 | Frigidaire GLTF2940ES Front Load Washer
All programmes stop before last rinse & spin.
I would suggest you check the filter.
Remove rear panel completely, locate and remove large black hose fastened to bottom of tub.
Remove and clean plastic filter inside hose,, check drain hose for partial obstruction, refit filter and hose.
Make sure drain hose is not kinked or trapped, and make sure outlet is not obstructed.
Refit rear panel, and test.
Please leave a fixya rating for my suggested solution.
Thanks.
Feb 11, 2009 | Hotpoint Aquarius WD63 Front Load...
Drum does not spin fast anymore
there s a"button trap" located on the side of your pump assy, behind the lower acess panel ( youll need to remove 3 torx 20 screws from the from bottom of machine ) after emoving the panel oull see the clean out directly in forn t of you. BE WARNED THERE WILL BE WATER behind that acess point grab a towle!!!!
cloges with debris and such preventing good draining!!
Jan 19, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet HT Has F error & won't drain & spin
I agree a F code of 21 or 2 I would clean the pump and check the bellow behind as well the pump entry from the trap for debris or a broken impeller.
Sep 08, 2008 | Whirlpool Gold Duet GHW9400P 3.8 Cu. Ft....
Kenmore 44092500 Won't complete spin cycle
AllExperts.com gave me the answer I needed at no cost.
Jul 29, 2008 | Kenmore Energy Star 44092 Front Load...
Washer won't spin fast, only slow
tyr removing the lower acees panel from the uint , ther is a "button trap" located there to catch debris from entering pump assy, chances are its clogged and if it cant drain all the water it wont go into high speed spin, also you MUST use an HE detergent. HE detergent specifically designed for front loading washers
Apr 28, 2008 | Kenmore 44102 Front Load Washer
Clothes wet, doesnt spin fast
Check the drain spigot, where the drain hose attaches to the drain trap under the sink/tub.There may be a blockage in the spigot which is causing the water to drain very slowly and therefor not allowing the machine to spin at normal fast speed.
Oct 22, 2007 | GE Energy Star WCVH6260F Front Load Washer
Will not drain or spin
There is another posted problem similar to this one if you look at GE front-loading washers.  I can tell you right now, though, that we just cleaned the filter (had the same problem as you) and everything is working perfectly now.  The bottom panel (on the front) of your washer comes off by removing 3 screws.  Our filter was full of lint, change, barrettes, etc.  I would highly recommend looking for that other post (has more information) or trying to clean the filter.  Hope this helps!
Oct 11, 2007 | GE WSXH208A Front Load Washer
Frigidaire GLTF2940ES Front Load Washer Logo
23 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Jason Harris
Jason Harris
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
